Old 10-10-2005, 10:50 PM   #10591
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
yup, you use the old MR4TC belt car rear diff to make a front 415. mainly most all of it, except using the 415 pulley and diff balls.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 10-10-2005, 11:03 PM   #10592
Turbonium's Avatar
Originally Posted by Turbonium
ok.. here is the best i can come up with right now. using rear diff outddrives from MR4TC, plus the rear cvd's from same car, you can almost get there. as you can see in the pix, the Yoke takes the 6mm i.d. bearing- the Tamiya is 5mm. couldnt find a 6X11, so the best way i could come up with was to use a lathe to turn down the Yoke cvd... (actually, i used a dremel on a junk one to mock it up- lol...) seems like the length is fine, and there is minor shimming on either side of the diff to take up some slack. that F201 idea might work too, but i didnt have any of those to try! pix to follow...
a buddy mentioned to me the other day that he thought the Yoke diff was my discovery, so i had to go check it out... back on page 56-57!
Wes
Team Novak
Old 10-11-2005, 03:03 AM   #10593
TRF415boy's Avatar
Originally Posted by JRRobiso
Thanks for the reply Max (MaxPower) & also on the heads up re the MSX conv kit @ Ultimate Hobbies. Checked out their website & also free shipping for internet & mail orders. The only thing they did'nt have on their website was the lt wt rev susp kits.
I previously installed 415 susp blocks on my 414M (extremely TRF'd hopped-up). I'm still in the process of setting it up to run properly for my asphalt track. I currently have in the front B/X & the rear B/B. I know the 414 has it's own thread but since you mentioned your 414M2, was wondering if you can post or pm me your set-up on your 414M2 when you get a chance.
Thanks again.
Here's Surikarn ITSC setup. It works well but you won't be able to use as much spacers under the blocks as him without dremelling the wishbones. However, you can use the same setup with Evo3/4 blocks and the following spacers :
front end :
front 0
rear 1
turnbuckle : 2.5
rear end :
front 2mm
rear 0.5mm
turnbuckle 5mm
I've tried that setup, it works great on asphalt and on carpet aswell.
regarding the blocks it goes like this :
414M blocks are the lowest, 415 are 1mm higher and Evo3/4 are 2mm higher (than 414M blocks).
TRF415boy is offline   Reply With Quote
Old 10-11-2005, 09:42 AM   #10594
rtypec's Avatar
psst...for those of you looking for an MSX setup with the promodule suspension. DJ's KO GP Setup is actually for the MSX
Anybody getting Socom3 today? It's on!
rtypec is offline   Reply With Quote
Old 10-11-2005, 11:16 AM   #10595
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Mr Canare has just made me think of something. Why wasn't there a new setup sheet enclosed with the MSX conversion kit? There are new adjustment areas that could be filled in, etc such as the upper inner arm mount point on the bulkheads, etc.
Anyone keen to make one up? (tryhard..... )
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 10-11-2005, 11:35 AM   #10596
TryHard's Avatar
i would... if my computer wasn't in pieces alongside me
| THard.co.uk | Xray | MuchMore |
Old 10-11-2005, 01:28 PM   #10597
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
OK TRF'ers..
I am new to the 415. I have the MSX, and have yet to run it. I am desperately trying to find a light weight suspension kit for this pig. Speedtech RC doesnt have all of the individual parts to piece it together..
Does anyone here have the necessary parts to convert this??
PPPLLEEEEAASSEEE???
OUT
Keith Billanti is offline   Reply With Quote
Old 10-11-2005, 01:39 PM   #10598
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
I think you will be able to use a LW Conversion kit for the TA04/05 with some extra parts, someone else can most certainly fill in what parts needed
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Savx - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 10-11-2005, 02:46 PM   #10599
neosan's Avatar
Originally Posted by Keith Billanti
OK TRF'ers..
PPPLLEEEEAASSEEE???
Hi Keith,
Here I think you have all parts you need:
51092 Tamiya EVO IV 46mm swing shaft
53724 Tamiya 46mm Swing Shaft Lw
53500 CROSS JOINTS for Assembly Univ. Shaft Set
51094 Tamiya EVO IV Wheel Axle - 2 sets
51098 Tamiya 2.6x22mm screw pin (2)
51099 Tamiya 2.6x25mm Screw Pin (2)
51100 Tamiya EVO IV Flanged Tube
51101 Tamiya EVO IV Ball Head Kingpin
51103 Tamiya EVO IV C Parts Front knuckles
51104 Tamiya EVO IV D Parts Suspension Arm - 2 sets
51107 Tamiya EVO IV Hub Carrier 4 deg.
cheers
neosan is offline   Reply With Quote
Old 10-11-2005, 02:50 PM   #10600
thanks.. that is everything I figured.. only problem is that Speedtech RC doesnt have everything... does anyone here have the parts??? paypal ready..
OUT
Old 10-11-2005, 02:54 PM   #10601
neosan's Avatar
try R/C Champs http://www.rc-champ.co.jp/. I bought all parts there.
Old 10-11-2005, 02:57 PM   #10602
I was really hoping to find it in the states.. Stella Models has the TA04 parts set and the back of the box looks to have all of the parts.. but again.. they are in HongKong...
need US seller...
OUT
Old 10-11-2005, 05:03 PM   #10603
Send a message via AIM to odawg315
pm me, tell me exactly what you need, i got a plethora of spares, i could hook you up and ill just replenish mine when speetech gets it in.
odawg315 is offline   Reply With Quote
Old 10-11-2005, 05:53 PM   #10604
BritRacer's Avatar
Hi...anyone know any us based stores that have a front one way pulley??
Also I want an ms chassis?? Cant find one anywhere!!
I can only find the pulley precision rc and the shipping is double...if i needed anything else it wouldn't be so bad.
BritRacer is offline   Reply With Quote
Old 10-11-2005, 06:34 PM   #10605
i got a whole one way i wont be using id be happy to trade for a light weight suspension... LOL...
Odawg315 YGPM//// THANKYOUTHANKYOUTHANKYOU
OUT
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
