Old 10-07-2005, 10:16 AM   #10501
Send a message via AIM to odawg315
Originally Posted by TryHard
Look closely, and you'll find the damperstays are needed.
The new ones are different, as the mounting points for the the towers on to the bulkheads has been raised, necessarly because of the quick access bulkheads.
Still not sure on the difference of the steering plates though... if any.
Personally, I quite like my t-shirt... very comfy
Regards
Ed
my bad, it made a huge difference in the way the car sits, i just glanced at them at first... now i have ms damperstays that are usless, between this my pro mod and spare parts maybe ill build an ms and sell it to make back the money for the msx kit!!
odawg315 is offline   Reply With Quote
Old 10-07-2005, 11:17 AM   #10502
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
If you got MS parts you want to get rid of, I'll all ears . I need to stock up on spares.
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 10-07-2005, 11:50 AM   #10503
Trader Rating: 37 (100%+)
has anyone encountered problems installing their lightweight suspension on their regular 415?
i can't get the holes on the rear block to line up with the chassis. the instructions ask for spacers to be put under the rear block. but i wish to have it sit flat on the chassis.
front rear block /3mm spacer/2mm spacer/suspension arm/3mm spacer/rear block.
Are you just saying you bought the LW suspension and want to mount it on your stock 415?
If so it should fit fine. I have gone back and forth with LW and stock suspension on both the 2.5 and 3mm chassis. Only difference when going from chassis to chassis is the number of shims on the inner hingepins and the length of the hingepins.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 10-07-2005, 12:06 PM   #10504
rtypec's Avatar
Can someone please provide a screw count from the instruction manual of the conversion kit. I'm at work and umm yeah...can't get to my stuff. Thanks in advance.
rtypec is offline   Reply With Quote
Old 10-07-2005, 01:07 PM   #10505
maxepower's Avatar
Talking screw count in MSX kit!
3x10mm round head=5
3x8mm round head=19
3x6mm round head=10
3x10mm flat countersunk=1
3x8mm flat countersunk=13
2x5 mm cap screw=2
3x10mm grub screws=4
There you go Rod!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 10-07-2005, 04:34 PM   #10506
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
So in the front, I want the D-D block.. in the rear, according to ,Martin Crisp, i was D-A... is the D in the front of the rear or the rear of the rear?
I ask, because I swear I have toe out with the D in the front and the A in the rear...
//KBpower
OUT
Keith Billanti is offline   Reply With Quote
Old 10-07-2005, 04:52 PM   #10507
Jack2's Avatar
Ed, the only difference in the steering plate is the MSX version has been machined out so the flanged bearing sits flush inside the plate.
Not a big difference... but still a difference, and not something I would like to have to do myself...
~Jack
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 10-07-2005, 05:10 PM   #10508
TRF415boy's Avatar
//KBpower
Well you would have, to be more precise 1 toe out is what you have. Have a bit of common sense and compare the blocks... A is narrower than D (they go in 0.5 steps, so A-D would give a 2 difference), so you put D on the rear/rear and A on the rear/front. Make sure also that you have the hubs the proper way around, as they have 1 toe too. There's a L/R sign on the side of them.
TRF415boy is offline   Reply With Quote
Old 10-07-2005, 05:20 PM   #10509
Default Toe Blocks configuration
Keith,
Goto Ed "Thard" Clark's page and the link to see a useful spreadhseet of the block configurations are found on his page in the excel links section. Lot of other useful stuff too:
http://www.thard.co.uk/rc/TRF415/TRF415pages.html#excel
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 10-07-2005, 05:24 PM   #10510
TryHard's Avatar
//KBpower
Generally when I talk about suspension blocks, I go from thefront of the car to the back, ie:
Front-Front/Front-Rear Rear-Front/Rear-Rear
For example
C/A on the front would mean, a C block at the front, and an A on the rear
And yes this gives toe-out
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 10-07-2005, 06:05 PM   #10511
//KBpower
Keith...I see you found a car :P
I ran M.Crisp's setup....it's D/D and A/D in that order. It worked pretty well at my local track that is new Ozite. For a oneway setup it was very smooth.
Old 10-07-2005, 07:12 PM   #10512
ya, no thanks to you
I have never met anyone more firm on a price.. LMAO...
haha///
Keith
OUT
Old 10-07-2005, 10:00 PM   #10513
racer's Avatar
which set of inner hingepins do you use when converting your lightweight suspension?
racer is offline   Reply With Quote
Old 10-07-2005, 10:33 PM   #10514
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
you should use the same ones that fit your particular chassis before the swap... the only thing that changes is the amount of spacers on either side of the arm.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 10-08-2005, 05:25 AM   #10515
TryHard's Avatar
Ran my MSX for the first time last night, and at the moment, I'm very pleased with it.
Was running on high grip carpet, and given i was running it with a 2.5mm chassis, it performed very well. I deffiently think i need to go stiffer on the springs (I was running white/blue F/R, transition wise it was a bit slow), and try and dial in a bit more initial steering. But apart from that the chassis was very smooth, and does seem to generate more grip than my other car (which i also ran).
I've decided that for tomorrows meeting, I'm gonna run the MSX, and have the other car in reserve. Need more track time at the moment, and 30mins between each round left me a little breathless, especially when needing to switch some electronics between cars, and then setthem up....
More later
Regards
Ed
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
