Old 10-03-2005, 03:07 AM   #10381
Originally Posted by AKARA
How are the new aluminum pieces? Do they tweak easy? (The motor/gear area)
The new alu pieces fits quite well...But from that sort of impact its quite sure that any car would develope a tweak.
Ben.C is offline   Reply With Quote
Old 10-03-2005, 03:35 AM   #10382
Jack2's Avatar
Had it happen to me about 3-4 months ago. Lucky it was only practice !
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 10-03-2005, 03:50 AM   #10383
Kenneth Tan's Avatar
flower bud???
Kenneth Tan is offline   Reply With Quote
Old 10-03-2005, 08:37 AM   #10384
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
In my opinion, like Burlap said, the Evo4 is a better car for Stock racing and perhaps 19T also. I just find that its a bit more efficient and is very stable at those speeds. Perhaps on a lower grip surface though, the 415 would be a better choice due to its extra flex options.
I have run both and this is what I've found. Without doubt the 415 is the car to have for Mod.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 10-03-2005, 08:48 AM   #10385
Trader Rating: 37 (100%+)
Martin Crisp.
Thanks for posting your IIC setup. I ran about 90-95% of it at our local track that has the same carpet. The car worked really well in 19T and stock.
Tryhard...did you make a pdf...just wondering because if not I have some of it already down in a pdf.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 10-03-2005, 08:55 AM   #10386
badboy's Avatar
Trader Rating: 14 (100%+)
Does anyone know the part number for the 2.5mm TRF 415MS chassis? Thanks!!!
slow is fast . . .
badboy is offline   Reply With Quote
Old 10-03-2005, 10:24 AM   #10387
Trader Rating: 45 (100%+)
Originally Posted by Martin Crisp
Hey Rod - Thanks! btw - you learn fast, considering you don't run rubber tire/carpet. Awesome job in 19 turn.
Some folks were asking for my vegas setup. I ran the same setup for both mod and 19 turn....
Tires : glue half of front sidewall
Front:
Front one way : yes
Center one way : no (locked)
Droop : 24mm to top of axle
Springs: white
Oil: 60 orion
Shock pos:
-outer hole on shock tower
-outer of two holes on arm
Inside Upper links : 2mm spacer
Ackerman : front holes on knuckles
- swept back bell crank
Blocks : d and d - no spacers
Wheelbase: 3mm forward
Caster : 2 degrees
Swaybars : none
Toeout: none
Wheel hub spacers : 1mm
Belt : position 1
Ride height: 5.5 to 5
Lw suspension
Camber: 1
Rear:
Droop : 25mm to top of axle
Springs: blue
Oil: 60 orion
Shock pos:
- One hole in on shk twr
- Outer of two holes on arm
Inside Upper links : no spacer
Outside upper link: 0.7
Upper link length: outer hole on upright
Blocks : d and a - no spacers
Upright : 1 degree allum (total 2.5 toe in)
Swaybars : none
Belt : position 2
Lw suspension
Camber : 1.5
Mod Motor : 8x1
Gearing : 102 and 25
19 turn :Orion Element
Gearing : 104/38
This setup had just a little push in mod but perfect in 19 turn. For 19 turn I ran the same setup of tires for all four qualifiers and the main. In mod I ran 2 sets of tires one on the first day of qualifying and the other for the second day of qualifying and the main. For mod I would probably make the following changes to add a little more steering.
* not glue front tire sidewall at all
* lay down front shocks one or two holes
Martin - Is this setup for the MSX chassis or TRF415 chassis?
Apex is offline   Reply With Quote
Old 10-03-2005, 10:56 AM   #10388
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
im not Martin , but i saw both his cars, and neither was a MSX. dunno bout the MS tho, as i didnt notice.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 10-03-2005, 10:59 AM   #10389
Martin Crisp's Avatar
Default which chassis
Apex - both of my cars were the MS edition. I just got my MSX conversion the week after vegas....can't wait to try it.
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 10-03-2005, 12:46 PM   #10390
geeunit1014's Avatar
does anybody carry outdrives for the shooters spool? i may need some i cant help it when the pipes jump out in front of me
also, just an opinion question, will my car w/ double spools be ok on carpet(ozite in particular). i have standard 415 w/ lightwieght arms & ms shock towers
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 10-03-2005, 02:30 PM   #10391
Jack2's Avatar
Precision R/C - The complete spool is $28.95 and the outdrives are $15.45
Schumacher Mi4CX
Mugen MTX & MRX
Old 10-03-2005, 04:04 PM   #10392
Ballsie's Avatar
Here are the first pics of my 415MS Upgrade Parts Set equipped MS.
Tamiya TRF415-dscn0643-large-.jpg   Tamiya TRF415-dscn0637-large-.jpg   Tamiya TRF415-dscn0644-large-.jpg
Ballsie is offline   Reply With Quote
Old 10-03-2005, 04:07 PM   #10393
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
im jealous.. I want one.. some one sell me a 415..
OUT
Keith Billanti is offline   Reply With Quote
Old 10-03-2005, 04:43 PM   #10394
My MSX kit is currently sitting at the customs office at coventry and is not been reliesed as the bloody invoice is missing Best they let me have it soon.
Rick Draper is offline   Reply With Quote
Old 10-03-2005, 04:50 PM   #10395
TryHard's Avatar
argggh mine too !!!!
Hmmmm.... it arrived in customs at 11:24am this morning, so why haven't i heard anything yet??
| THard.co.uk | Xray | MuchMore |
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
