Old 09-27-2005, 07:23 PM   #10246
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
QUESTION RE LT WT FRONT KNUCKLES & REAR UPRIGHT
Just installed the lt wt rev arms on my 415. After adjusting the camber & toe-out on my set-up station, I installed my race tires to set the ride height & noticed that the front knuckles & rear uprights sort have some slop in them that the std arms didn't have that much. Is it just me or is their a way to lessen the slop?
Any reply would be appreciated since this is the first time I'll be using the lt wt arms when I race @ my LH asphalt track next friday.
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 09-27-2005, 07:33 PM   #10247
JimmyMac's Avatar
Try using the stainless outter hinge pin set. It takes out alot of slop. You may still have to use some motor shims to take it all out.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 09-27-2005, 07:49 PM   #10248
Trader Rating: 37 (100%+)
As Rod indicated Marc's chassis was 4mm prototype for foam. If there is enough demand in north america Tamiya may produce it. Marc also ran a new front diff that Tamiya will be releasing (I just don't know when)
a 4mm foam car with a Tamiya diff....
MAKE and SELL IT TAMIYA!!
count me in if that happens...hopefully enough people chime in so that Tamiya notices there are many diff/foam/carpet racers in the US.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 09-27-2005, 08:30 PM   #10249
JimmyMac's Avatar
4mm carpet chassis for a 415... hell I'm in. I know another guy who'd be interestest as well. Hell, I'd love to have a 4mm chassis for my EvoIV as well!!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 09-27-2005, 08:49 PM   #10250
Martin Crisp's Avatar
Default lw suspension
The foam cars were using HPI knuckles or some other option.
I just use shims to remove some slop in the lw suspension. I like the .1mm axel shims as they are very thin and easy to add. I like the rear alloy uprights as they keep the bearings from moving around more than the stock ones.
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 09-27-2005, 09:07 PM   #10251
JRRobiso's Avatar
Thanks KilRuf & Martin Crisp for your responses re the slop on the lt wt arms.
I do have a question re the upcoming TRF415MSX Refine kit. Should I just get the MSX conversion kit for my 415 or should I just wait for the Refine kit (w/c includes everything) instead as an additional car rather than upgrading the std 415 to it's equivalent?
Any takers welcome.
Old 09-27-2005, 09:25 PM   #10252
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
Tamiya - If you build it, they will come!
4MM CARPET CHASSIS PLEASE.
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 09-27-2005, 09:40 PM   #10253
Jimmy
If there were that many people after one, wouldnt BMI or someone have made one by now?
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 09-27-2005, 09:45 PM   #10254
No because most or maybe a lot of tamiya owners are strictly rubber tire racers and run per TCS rules all year.
It might be a risk for BMI to produce....But for Tamiya if it was a whole kit I believe it would sell.
Old 09-27-2005, 09:45 PM   #10255
C_O_jones's Avatar
Congrats, Martin.
Great race, I hope it was as exciting as Scotty anounced it
Does Rod still talk to you after all the Whoopings you put on him latley???
Fred Forg
Next year, youre buying at IN-N-OUT
Bacon is Meat Candy
C_O_jones is offline   Reply With Quote
Old 09-27-2005, 10:38 PM   #10256
Besercoe I tried working with BMI about a year ago on a carpet chassis and it went nowhere. I sent back a full car for him to prototype off of. Not sure what happened but it took about 3 months to get the car back and went nowhere. At the time I think there were too many other irons in the fire for Jason.
Martin, Corey, Rod and the rest of the Tamiya guys good job wish I could have made it down too many conflicts with the job that pays the bills......
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 09-27-2005, 10:52 PM   #10257
Originally Posted by Ballsie
Thanks for your involvement in this thread Martin.
Did I see Marc running the LWT suspension on his foam car?
How do you foam racers put on such wide foamies on the front ?? i remember i was scrubbing the hub carrier with 26mm foamies ... and to cut it down to 'super narrows' to fit..
Is it done by using 6mm hex hubs and narrowing the track width using various toe blocks???
hapiya is offline   Reply With Quote
Old 09-27-2005, 11:36 PM   #10258
over gear's Avatar
Trader Rating: 15 (100%+)
How can you tell the difference between a 415MS with MSX conversion and a 415MSX ??? ???
over gear is offline   Reply With Quote
Old 09-27-2005, 11:52 PM   #10259
reilly's Avatar
You have to use pro4 steering knuckles and the org. suspension stub axle.
add a 1mm shim between knuckle and c-hub on the top.
4mm chassis! Yes Please!
Alloy diffs front and rear!! For carpet please make the diff screw 3mm
the 2.5 screws tend to break. Corally(2.5mm screw) drivers are have that problem once in awhile. Xrays (3mm screw) never break. Just my 2 cents
Here's pics of the diff's I designed and machined. They use Xray style bellville washers and thrust washer with 3mm screws, and delrin blades I also made (same size as corally blades).
CEFX, Express Motorsports, Parma, Reilly Paint
reilly is offline   Reply With Quote
Old 09-28-2005, 12:48 AM   #10260
Jack2's Avatar
Nice job on the diff dude !
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
