Old 09-16-2005, 07:19 AM   #10096
Jack2's Avatar
Originally Posted by TRF415boy
Err i don't know where did you see that lube shouldn't be used, but I think it's 100% wrong.
Yes, I agree I dont care what the balls are made from, I will always use AE stealth lube.
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 09-16-2005, 07:23 AM   #10097
Jack2's Avatar
Originally Posted by KORSA
At the thrust bearing you use only Trinity royal oil without any stealth lube?
I used to use a small amount of Stealth lube on the thrust bearing, but I tried just using royal oil and it works just aswell, if not better.
Schumacher Mi4CX
Mugen MTX & MRX
Old 09-16-2005, 07:40 AM   #10098
TRF415boy's Avatar
I use black grease on my thrusts. The pressure in a thrust is much higher than in the diff itself, I found silicon based greases won't hold up as well.
TRF415boy is offline   Reply With Quote
Old 09-16-2005, 08:51 AM   #10099
KORSA's Avatar
Thanks Jack2
KORSA is offline   Reply With Quote
Old 09-16-2005, 09:10 AM   #10100
V12
V12's Avatar
Originally Posted by JRRobiso
Thanks for the reply Ben. Any other takers on my quest to convert my 415 from std arms to rev lt wt arms? Also, any recommendations on which susp blks, hub carrier (2 or 4 degrees) I should use & what's the built-in degree of toe-in for the rear hubs?
Thanks again for any reply.
The rear hubs on the lwt suspension are 1. Cant say anything on setup as Im keeping with the std suspension.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 09-16-2005, 11:08 AM   #10101
maxepower's Avatar
Talking Lt. Suspension!!!!!!!!
Have you looked at Dave Jun's set-up on the Tamiya website.
Although he is using his rear suspension arms in the back. The remaining set up is pretty sound. This is a good start point. I've used it on my son's 415 MS with Dave Jun set up and it is hooked up. I use a slightly modified set-up and it's not as good. But I'm not using his rear suspension either. The light weight arms are good but "just a warning" if you hit a lot of dots while driving the arms will break.
Good Luck!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 09-17-2005, 05:14 AM   #10102
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
I use the ACER ceramic diff balls and Atlas covers. Very big fan of the ACER balls really as even with the Atlas covers, the diff still became gritty. With the ACER balls though, the diff is still good after many runs in Modified with it. I highly recommend ACER for a variety of their products, especially their diff balls should you run a Tamiya car.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 09-17-2005, 08:17 AM   #10103
Can you tell me where to buy Atlas covers on-line?
Tral is offline   Reply With Quote
Old 09-17-2005, 11:05 AM   #10104
Well I didn't guarantee no lube is required. It has been stated at the websites of companies that do these coatings that often lube can be elimated when you have all the surface of two items that come into contact with another, that the coatings provide a coefficient of friction that is way lower and rivals that of some of the best lubricants that you can use before the coatings. The surface hardness is unreal and things go smoothly.
Also a lubricant will also be partly the problem as lubricants attract dust and debris and that is partly responsible for the degrading of the diffs when the ball or ring has it and it stays there grinding away at eachother.
I plan to experiment to see if I can get good diff action and longevity when I get the rings coated. I have already run Acer balls on stock rings dry before and it was close in terms of time between rebuilds as with Stealth lube on them. But I am running the lube for now. Even if I find I have to run a light coating of lube on the balls before assembly the coated rings and Acer balls will definitely run longer as the dirt can't damage the parts.
Indoor season starts soon so I should arrange to get the rings coated for my cars to see.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 09-17-2005, 11:46 AM   #10105
F. Alonso's Avatar
I got mine from Rainbow Ten. Give them a hoy!
Simon Feigl
Old 09-18-2005, 05:58 AM   #10106
Burlap's Avatar
Send a message via MSN to Burlap
Hey Simmo, what's the link to the ACER balls website?
Burlap is offline   Reply With Quote
Old 09-18-2005, 07:02 AM   #10107
F. Alonso's Avatar
Go to http://www.acerracing.com/balls.html to check them out.
Simon Feigl
Old 09-18-2005, 08:06 PM   #10108
Burlap's Avatar
Are Acer the same mob you get your ceramic ball bearings from?
Old 09-18-2005, 09:34 PM   #10109
Good Luck!
Don't worry....I've haven't break the arms yet...!!My MS been with me ever since its out in the market...And I have some mightly big crashes before...
Just be careful when you drive...Don't go fast if you're not confident of that particular setting...And the car will be safe...
Ben.C is offline   Reply With Quote
Old 09-18-2005, 09:40 PM   #10110
I use the 4 deg caster blocks...Give it more exit steering.Less initial turn in.Which is what I want as I'm using a B4 legacy body,known to have a lot of steering,so the 4 deg caster block makes the car less twichier...But still has lots of steering.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
