Old 09-15-2005, 11:48 PM   #10081
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
SUSPENSION BLOCKS & UNIVERSALS
Just purchased a week ago the TB02/TA04 Rev Lt Wt arms & have plans to replace the standard arms on my 415. Would like to know what susp blks do I use & length of universals? I already have the A bridge blk & the other std blks that came with the 415 kit. Also would like to know w/c hub carrier (2 or 4 degress) should I use and what is the toe-in degree of the rear hubs (0, 1 or 2 degrees)? Also wanting to know if someone could share their set-up for med size , med flowing w/ med traction track w/ front spool (Speedtech/Tamiya) & ctr direct pully?
Any help would be appreciated.
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 09-15-2005, 11:57 PM   #10082
John Doucakis's Avatar
I 've been running TAMIYA cars for some time now, and I was never pleased with the ball diffs. It seems that no matter what I do, after 4-5 packs they are no longer smooth. When I was at the worlds in Florida in 2004 I was sitting next to Karn, and Mark R. was sitting opposite to Karn. I wathced how they both changed or rebuilt their diffs quite often, almost after every two runs.
By comparison the Xray diffs can last up to 10-15 runs without any problems.
Have you guys found a solution to this?
John Doucakis is offline   Reply With Quote
Old 09-16-2005, 12:20 AM   #10083
TDO
TDO's Avatar
John,
At R10 you can buy plastic diff sealers for tamiya diff's. The xray diffs are closed and the tamiya diffs are not. So with this sealer you have no more problems of getting dirt into the diff and therefor you can run them much longer.
Product : Diff Protectseal TRF415
Manuf. : Team Atlas
Partnumber : MH7-613
Marc
TDO is offline   Reply With Quote
Old 09-16-2005, 12:24 AM   #10084
Sorry can't answer all the questions as the car's not with me at work.
ANyway about the shaft lenght,its 46mm.
Usually,I'll use a one way for my track's current layout,but its somewhere med size. I'll use yellow all round and yellow anti roll bars all round.With 50 trinity weight oil.Front shock hole is 2nd from the bottom and the rear is the 2nd hole from the top. Rear toe in 2.5 degrees.
This is all I can remember.
I use sorex 40R tires with sorex type C medium inserts.
Ben.C is offline   Reply With Quote
Old 09-16-2005, 02:34 AM   #10085
Another solution to extend the life of the diff is to use Evo3/4 outdrives with two thrustbearings stacked on eachother.
Mr_Orange is offline   Reply With Quote
Old 09-16-2005, 02:47 AM   #10086
Jack2's Avatar
I have no problems with my diff, it stays butter smooth for quite a few runs.
I used the Delrin out-drives (reinforced diff joint), I use the Acer ceramic 3mm diff balls, I only use the standard diff plates, I always make sure the thrust bearing is perfect and lubed with trinty royal oil and lube the balls up and diff plates up with AE stealth lube. I'm usually getting 20-25 or so runs running mod on asphalt without it getting the slightest bit gritty.
I don't use diff cover or seals either.
~Jack
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 09-16-2005, 02:51 AM   #10087
V12
V12's Avatar
John
I also have problems with my balldiffs. For me the balldiffs are the only real bad thing with the Tamiya cars. Even using the Atlas diff covers the diff donīt last much more than 5 runs and after that the car doesnīt handle the same as before. Youīre right the Xray diff works much better maybe these are the best diffs currently. But I also have to say I tried a FK05 and it doesnīt handle to my liking also wasnīt as fast as my Tamiyas but only tried outdoors.
Regarding the Tamiya diffs I think the thrust bearing and the diffrings are not good quality. Iīm currently using HPI carbide thrust bearings what helps a little but I think better diffrings may help even more. I know the ones from Yokomo will work but had not the chance testing them.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 09-16-2005, 03:33 AM   #10088
TRF415boy's Avatar
~Jack
I back this up, and I add, Acer Ceramic balls are a MUST HAVE on any tamiya diff (that's for you V12, you should get a set of those they make a HUGE difference in consistancy of the diff throughout the runs).
TRF415boy is offline   Reply With Quote
Old 09-16-2005, 05:01 AM   #10089
Well I am thinking of getting the Diff Plates coated in Titanium Nitride or Graphit IC (Diamond like Carbon) coating and experimenting with that. You should not have to lube the diff balls or plates when combined with Silicon Nitride diff balls from Acer.
At least the MSX conversion will calm down the aggrivation of changing the diffs now.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 09-16-2005, 05:59 AM   #10090
KORSA's Avatar
~Jack
At the thrust bearing you use only Trinity royal oil without any stealth lube?
KORSA is offline   Reply With Quote
Old 09-16-2005, 06:21 AM   #10091
V12
V12's Avatar
I have to say I bought some ceramic diffballs here from Marc Rheinards father so I think should be not too bad. Used aluminium diff halves also together with the HPI carbide thrust bearings. This was at the last indoor race last winter and this was working much better for about 5-8 runs (donīt remember the exact number of runs) but didnīt run the 415 after this again. Itīs my indoor car donīt wanted running the 415 outdoors in the dust and fiddling around with the bad access to the diffs.
Outdoors Iīm running the old EVO3 what still is a very fast car but the same problems with the diff but at least much easier to replace during a race. Now outdoor racing is over for me and back to indoor next month.
I know one driver here using a complete Pro4 diff just with the 415 pulley and this worked much longer for him.
Old 09-16-2005, 06:47 AM   #10092
V12
V12's Avatar
Donīt know if this really would work but if you ever have seen Xray diff plates you know how they should be. Hardened and grinded(?) so they are completely plain. XXX-S diff plates were similar. Then 12 diffballs instead of 8 running on a larger circle than the small circle as with the Tamyia diffs and additional a great thrust bearing as used with the (old) Xray or Losi XXX-S, this would be a perfect diff.
Before the Tamiya cars I was running a XXX-S and the diffs worked at least for 3 month without touching them and this was just with carbide balls not ceramic. The Tamiya diffs donīt hold for one complete race, at least with carbide balls. Thatīs not only for me I know alot of people having this problem. I like running the Tamiya cars but they really should improve the diff design.
Old 09-16-2005, 06:55 AM   #10093
JRRobiso's Avatar
Thanks for the reply Ben. Any other takers on my quest to convert my 415 from std arms to rev lt wt arms? Also, any recommendations on which susp blks, hub carrier (2 or 4 degrees) I should use & what's the built-in degree of toe-in for the rear hubs?
Thanks again for any reply.
Old 09-16-2005, 07:04 AM   #10094
TRF415boy's Avatar
With Acer balls and atlas covers I run outdoors without rebuilding my diff more often than once every 20/30 runs. The thrust bearing needs checking, but you don't need to take the diff out to take the thrust bearing out and clean it, so it's not an issue IMO I usually clean it after 5/6 runs outdoors on very dusty tracks.
Old 09-16-2005, 07:08 AM   #10095
TRF415boy's Avatar
Err i don't know where did you see that lube shouldn't be used, but I think it's 100% wrong.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
