Old 09-11-2005, 05:57 AM   #10036
Ballsie's Avatar
Originally Posted by TryHard
running the X blocks on the rear allows the car to rotate faster. Most of the UK TRF drivers are doing this at the moment, using XD/X, with 1 deg rear hubs.
HiH
Ed
Is that with the standard suspension Ed or with the LWT setup?
Ballsie is offline   Reply With Quote
Old 09-11-2005, 08:15 AM   #10037
TryHard's Avatar
lwt
| THard.co.uk | Xray | MuchMore |
Old 09-11-2005, 11:15 AM   #10038
HiH
Ed
no,most TRF drivers are using eighter 1d and 1a with 1 degree hubs or 1d and 1x with 0degree hubs or on technical tracks we tend to use 1a and and 1xd.
its one of either of these options.
on fast tracks,we go with the 1st option,on technical tracks we go with the 2nd.
the 1st option puts stability in the rear,and more predictable at high speed.
the 2nd option we use on slower tracks,this gives us better turn in.
of course these are for low-medium grip ashphelt.
i try and saty close to adam rogers and we have both neva used the 1x 1xd opton.seems too narrow
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 09-11-2005, 12:07 PM   #10039
TryHard's Avatar
I have it from David himself (along with Pics from the euros and his setp sheet from the KO) that with the MSX they are mostly using the narrower rear end, with the 1 deg hubs, and XD/X on the rear.
I was told that (by david) that this helps to improve the speed of rotation of the rear of the car, at it is equates to around 185mm wide on the rear of the car.
Old 09-11-2005, 01:03 PM   #10040
i said most of the TRF drivers,the ones i have talked to,[i havent spoke to david yet]all use the 1a option or 1d option.
i have not got my aluminium 1degree hubs yet but wen they come i will try this option.
also,most TRF drivers,incl. myself,aere using the pro4 knuckles only,not the hubs.
we put a 1mm shim above the nuckle and hub.
adam is using pro4 driveshafts,iam using the standard suspension driveshafts with a lot of shiming.
these hubs do improve steering a lot more.were using the back most hole and not the forward one like on standard lwt set up
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
Old 09-11-2005, 01:13 PM   #10041
Which rear hubs are in world champion set? 0 or 1 degree?
Tral is offline   Reply With Quote
Old 09-11-2005, 01:23 PM   #10042
0 degrees.
the prob with these is that there is too much of a variation bt the rear most suspension mount to the front one.
5 diffrernt suspesion blocks to get 2.5degrees.
ie,to make 2.5degrees using a 1d at the rear most you need a 1x.
inboard toe is too much to take all of it,the outboard needs to contribute to it.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
Old 09-11-2005, 01:36 PM   #10043
So should i use my stock rear hubs 1 degree or alloy 0 degree? Today i ordered World Champion set for my 415MS but now i think that is wasn't good idea. Who produce alloy rear hubs 1 degree and alloy steering blocks?
Old 09-11-2005, 02:16 PM   #10044
tamiya make 1 degree hubs.the world champ set will help,will give you more tuning options.
i dunno who makes aluminium stering blocks
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
Old 09-11-2005, 02:57 PM   #10045
Which spool is better? Tamiya or Shooters?
Old 09-11-2005, 03:58 PM   #10046
TRF415boy's Avatar
Tamiya makes 1 and 0 degrees hubs.
Square make 0.5 1.5 read hubs, and alloy font hubs.
TRF415boy is offline   Reply With Quote
Old 09-11-2005, 04:56 PM   #10047
what are they running up front or better yet does someone have a link to a good high bite asphalt set up
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 09-11-2005, 05:38 PM   #10048
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
Default 415 LW Conversion
If anyone has a 415 LW conversion kit forsale, please let me know.
Thanks,
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 09-11-2005, 06:47 PM   #10049
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Smile
Thanks,
Jimmy
You can purchase the parts needed coz you can't find the set anymore for sale since it was a limited release & I don't know if someone will sell theirs as well. Or another alternative is to purchase the TB02/TA04 Lt Wt Rev Set. The set pretty much has all the parts needed just like the one for the 415, just labelled as a hop-up part item for the TB02 & TA04 kits. Then you can download the PDF manual for the 415 off from Tamiya USA website. I recently bought the TB02/TA04 set & going to print the manual as I mentioned before & determine which car I'm going to put it on (TRF415 or TRF414M SSG Fully Hopped-up). The kit number for the TB02/TA04 rev arms is 53794.
Hope this helps you out.
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 09-11-2005, 07:32 PM   #10050
g12314's Avatar
Thanks Jun. I found the TB-02 kit after posting. Looks the same except I didnt see that the MS shock towers were included, but I can get those seperate.
Jimmy
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
