Old 09-09-2005, 02:59 AM   #10006
TRF415boy's Avatar
Originally Posted by TryHard
I do believe that David Spashett and Adam Rogers used them at the KO GP, and Marc R at the euros used the Pro4 Hubs. If you look at there cars, the steering links are in the rearward holes, whilst the hubs themselves distinctly look like the pro4 ones.
Actually waiting on response to the Q about the advantage of them...
HiH
Ed
Since David is quite busy at the 1/8th on road worlds at the moment we won't have a precise answer soon... Still, I'm pretty sure they give more steering, otherwise why would they use them ? The question is, what kind of track are they suited to...
TRF415boy is offline   Reply With Quote
Old 09-09-2005, 07:14 AM   #10007
V12
V12's Avatar
Just found a picture whats included in the 415 MSX conversion set.
http://www.tamiya.com/japan/news/news0510/news1.htm
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 09-09-2005, 07:20 AM   #10008
Bigger one.
ukmaxx is offline   Reply With Quote
Old 09-09-2005, 07:41 AM   #10009
kentech's Avatar
Default TRF415MSX Kit
They also published information on the full MSX kit that will be released in December on the Tamiya Japan site in Japanese. The information was of course published on rcZone last week already but for those that did not believe that or want to see the information from Tamiya directly it's posted here.
Here's a translation of the info posted:
TRF415MS reforming (tentative name)
IFMAR touring car world championship of the worldwide highest peak you win successively, filling the know-how of TRF which controls also European リーディーレース which is held in the June this year. More and more in order that it corresponds to the race/lace which is accelerated highly, the front and back bulkhead modifying the form of the upper deck, the frame of TRF415MS furthermore it is low center of gravity conversion. In addition, the bulkhead front and back adopting 2 piece structures, guaranteeing high maintainability. You can taste the running of the champion.
- 1/10 electromotive RC cars
1/10RC TRF415MS REFINE
* Total length 380mm.
* Equipping the aluminum upper blurring chair which connects the rear bulkhead left and right. As chassis rigidity is raised, improving cooling efficiency, you hold down thermal ダレ of the motor to minimum.
December sale
1 梱 entrance several 4
69,800 Yen in estimate value
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 09-09-2005, 09:03 AM   #10010
Trader Rating: 37 (100%+)
69,800.00 Yen = $636.945 USD
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 09-09-2005, 12:53 PM   #10011
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
That jacked up price is probably just the estimated retail price, it have to land at around 400-450 bucks
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Savx - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 09-09-2005, 02:37 PM   #10012
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Default 42 or 46mm Driveshafts
Ran my 415 w/ std susp last friday @ my LH track & sort of broke the spool (lt wt ver by Speedtech). Had a spare which was the 1st ver that Steve sold but ran out of time b4 the main started, thus losing my chance to win my class (27 stk) & waste my pole position & top qualifying times from the prev heats. But that's already in the past.
Going to the main subject of my post, I ran my 415 w/ front 46mm steel driveshafts & std size driveshafts in the rear. I got the idea of running 46mm w/ the spool from prev posts here to further reduce the chatter issues when running spools. I guess it did help a little or was it bcoz of the new design of the lt wt spool from Steve. But since I re-installed the orig Speedtech spool, should I still run 46 or 42mm drives? I 'm also currently waiting for the Tamiya spool & will give that a try as well but w/ the same concerns w/ the driveshafts & can I use the alum ver or should I run the Tamiya spool w/ steel ones?
Lastly, I'm also waiting for arrival of the Rev Lt Wt Arms Set for the TB02 & TA04, since the 415 version was a limited release and also have plans of getting the MSX conv. When I install the parts from the set - can I still use the std size driveshafts or do I have to switch to 46mm ones?
Any response will be appreciated.
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 09-09-2005, 03:54 PM   #10013
Default Thumbnails?
Not to be off-topic here too much, but how do you put the nice attached thumbnails section that V12 and topgluer have used on this page.
Looking at multiple places on this forum it seems a standard look option.
You can PM me or post a reply here if it is simple. Thanks,
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 09-09-2005, 04:13 PM   #10014
OOPS! I found out how. It is the Addtional option on bottom "Manage Attachments" button in the post creatino page. Sorry!
Old 09-09-2005, 04:38 PM   #10015
Wow cannot wait to get my hands on my MSX kit. Hell i might even have to make time to race it!
Rick Draper is offline   Reply With Quote
Old 09-09-2005, 04:40 PM   #10016
tony q's Avatar
Originally Posted by ukmaxx
Bigger one.
that's all and they are going for $250.00 plus
tony q is offline   Reply With Quote
Old 09-09-2005, 04:52 PM   #10017
FW-05RR's Avatar
Bigger one.
this is the infamous MSX conversion kit????? I't doesn't seem like you get alot for your money Also weren't they going to include a brand new chassis where is it?
FW-05RR is offline   Reply With Quote
Old 09-09-2005, 04:52 PM   #10018
forty6's Avatar
Well, it's only here in the US that it cost that much. If you order from Japan, it only costs around $150. I don't think EMS shipping will be $100 for such a small item.
forty6 is offline   Reply With Quote
Old 09-09-2005, 05:00 PM   #10019
My MSX kit is only costing 83.28 + Shipping which is around $150 US. Not bad at all IMHO.
Old 09-09-2005, 05:05 PM   #10020
TRF415boy's Avatar
That's way cheap if you consider that all bulkheads are included.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
