Tamiya TRF415
#9888
Originally Posted by Customworksking
any info on the MSX kit yet and whats with the price 269.00!!!!
Just a quick note for clarification: The current price we have for the TRF415MSX conversion is the latest MSRP price we have on the kit. The final Speed Tech R/C discount price will be determined once the conversion kit arrives, and we will notify all pre-order customers right away.
If you have already paid by paypal, you will be refunded the difference when the discount price is announced.
Thank you all that have pre-ordered
Steve Wang
#9889
Also, in reference to the Pro-Module suspension, according to David Jun of Tamiya USA, he is not sure if the Tamiya Japan released version will have all the necessary hardware to fit it on the TRF415 (the extra spacers and hardware screws) and also he is not sure if the tuned spring will be included as well. The next batch we receive from Tamiya USA might be the last batch that will included all necessary hardware and tuned spring.
Steve Wang
Steve Wang
#9890
I think that Tamiya Japan would be pretty silly to release a hopup part, that you couldn't put on the car without buying other bits and pieces, that are specific to the arms really (anyone seem 100mm spacers on a car before). I agree that it may not have the spring set, but we'll see.
#9891
Originally Posted by Barry_Hughes
I have been using a mates spare 415MS car and liked it so just got a 415 2nd hand.
the 2nd hand car has 4mm shims under the ball joints on the steering linkage plate, where as everyone at the club I run at uses 1mm spacers.
Can anyone give my any idea as what the increase in spacers has?
Anyway, from what I gather your saying, on your steering link plate, there is 4mm of shims under the ball joint. Now depending on how you have the rack setup, and which car and suspension type, this alters the bump steer characteristics.
Firstly, what suspension type do you have? is it the Lightweight (a la the MS and Evo4) or the Standard suspension (a la TA04 etc)?
I actually alter the amount of bump steer, depending on the suspension type I'm running. With the 4mm you mention, it sounds like the car has been setup with the lower steering rack mod, the Marc R ran at the worlds.
Have a look at this pic, and let us know if the three spacers on the post are all above the steering arm (like in the pic), or are they two above, and one below (which is the std setup).
http://www.thard.co.uk/rc/TRF415/images/415g.jpg
If it's in the lower position (like the pic), 4mm is spot on for the LWT, but for the STD suspension, use 3mm. If the rack is in the higher position, put 1mm under for the LWT, and none for the STD.
This means you'll have zero bump steer for each suspension setup. I have actually run the wrong setting before (4mm with stock susp, lowered rack), and it made the car incrediably nervous and unpredictable to drive.... and that was with only 1mm difference.
HiH
Ed
#9892
so what about the DJ pro setup, is this something aimed at carpet or outdoor racing?
Has anyone run it on carpet, and if so what are the opinions?
#9894
Hi all,
I just picked up a nicely loaded 415. Came with aluminum rear hubs, low friction belts, and a locked one way middle shaft.
I have a few questions.
1. Does anybody have a good starting setup for running a mid-low traction asphalt parking lot track?
2. Are there any modifications to be done (ex. In the Pro 4, you have to do the upper deck mod).
3. Where do you guys place your Personal Transponders?
4. Lastly, what does the middle locked one way shaft do?
Thanks!
Thanks!
#9895
Hi Ed,
Yep made the transition!
The car is a 415 with MS chassis, the arms are standard 415's ie not lightweight.
It has two shims above the the arm and 1 below, whilst your picture has all 3 above. This " above 1 below seems the standard set up at Ipswich. amongst the 4 415's running, soon to be 5 with me, plus another 2 on there way.
I have just bought a true MS version as well, just waiting for it to be delivered! Hope it comes before next weekend as I am at Barham for the STCC.
#9896
Registered User
how much you paid for your 415ms?
#9897
the 2 above, 1 below, is the std setup from the manual.
The three above was spotted as a mod on Marc R's car at the last worlds, and personally, I've used it ever since.
BTW if you want to take some slop out of the steering, take 6 of the 0.1mm thick axle spacers, and place them on the steering posts (I tend to split them above and below the steering arms), 3 per side. It stops the arms moving vertically on the posts, which takes out a lot of slop on the car.
I might be at the STCC Barham meeting... if so, I'll pop over and say hi (I've moved back to kent now, after completing uni.)
HiH
Ed
HiH
Ed
#9898
Originally Posted by DOMOisCOOL
Hi all,
One other thing to try is using a longer grub screw on the spur holder. I found it a pain in the arse using a small one when I first got the car, so I took a spare droop screw, and used that instead. The end protrudes a little from the holder, and makes it much easier to loosen the spur holder.
If you used just the front one-way unit, off-power the front belt would be rotating, and as a result any difference in free wheeling of the bearings in the unit would be exaberated [sp?], which could lead to a pull left or right
off power, as one bearing is tighter than the other.
If you run both, this doens't reall occur, as the front belt and pulley are free to rotate off power. So if theres is any tightness in the bearings, this is absorbed by whole front section free-wheeling.
Hopefully that makes sense.
Thanks!
Ed
#9899
Does nobody mount the transponder on the top deck under 2 top chasis screws? Or will this generate tweak?
#9900
transponder.
in my cars i have them either mounted in a cutout portion of the front bumper. i use a long body clip that spans the length of the two body posts...this captures the transponder securely.
in car two i use strong velcro and have it on the top deck. this second car i swap transponders with another i have so it's a nice non-permanent solution.
domo.
i can type up a pdf. of what i ran recently on asphault if you want to try it.
domo.
