Old 08-26-2005, 09:05 PM   #9841
I don't believe Tamiya makes 0 degree hubs. At least not for the EVO IV anyway.
John Warner is offline   Reply With Quote
Old 08-26-2005, 09:25 PM   #9842
Csaari77's Avatar
Trader Rating: 34 (100%+)
Tamiya does make 0 deg. rear uprights for the LW suspension. They come standard in the Evo 4 MS and are available seperately.
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 08-26-2005, 09:41 PM   #9843
Thanks for the information. See... ya learn something new every day!
Old 08-28-2005, 03:37 AM   #9844
I run a D6 12 turn on my 415, can anyone help with the rollout figures for this motor, or suggest a suitable gear ratio, I am running a 102 tooth spur and 32 tooth pinion
thanks
junn is offline   Reply With Quote
Old 08-28-2005, 07:18 AM   #9845
What amount of spacers are people running behind the arms at the fron when using the 3mm chassis and the LW arms? The same goes for the back as well how many spacers between the block and the arm at the front of the back.
Rick Draper is offline   Reply With Quote
Old 08-28-2005, 08:01 AM   #9846
TRF415boy's Avatar
Hi Rick,
I'll give yo a better answer. On the MS chassis, they moved only the blocks facing the centre of the chassis.
So, just keep the same amount of spacers you had on the MS for the back of the rear wishones and the front of the front wishbones and shim the other side in consequence.
On my car i've got the following :
rear wb : back 3 mm, front 5 mm
front wb : back 6 mm, front 1.5 mm
hope this helps
TRF415boy is offline   Reply With Quote
Old 08-28-2005, 10:28 PM   #9847
BritRacer's Avatar
I need help again!
I have the lightweight suspension, and I broke the front knuckles.
I thought I had some, but I had ordered the wrong ones.
Can someone tell me a part number or direct me to the right place so that I can order some
are these the right ones?
BritRacer is offline   Reply With Quote
Old 08-28-2005, 11:09 PM   #9848
Jack2's Avatar
BritRacer, yes they are the correct knuckles.
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 08-28-2005, 11:12 PM   #9849
BritRacer's Avatar
Thanks!!
Also, should i be running the 46mm drive shafts on the front with the lightweight suspension?
Only the 42 popped out during my race....I guess I could be answering my own question here.
Old 08-28-2005, 11:17 PM   #9850
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
46mm is what comes with the 415MS (LW Suspension)
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 08-28-2005, 11:56 PM   #9851
thanks
That should be around that gearing.Depends on your track.If its small and technical,maybe could drop a teeth on the pinon.
Ben.C is offline   Reply With Quote
Old 08-29-2005, 01:10 AM   #9852
TENCHO's Avatar
Default Jipped
JDM_SIR jipped me out of a whole bag full of blue aluminum 415MS parts. He told me that he could them annodized a different color, so i belived him. I gave him the parts 5 months ago, and haven't heard from him since. Geez, just when you think someone is your friend,....DAVE I WANT MY PARTS BACK!
TENCHO is online now   Reply With Quote
Old 08-29-2005, 02:44 AM   #9853
Originally Posted by FTD RACING
Hi
Does anyone run Pro 4 rear hubs and stearing knuckles? I have heard that Marc R use's them. What advantage would this give?
The pro4 rearhubs and steeringknuckles can be considered to be spoolparts when running rubbertires on asphalt. At the euros a month ago almost all the teamguys used them. The steeringknuckles allows you adjust the rollcenter and the rearhubs have different rollcenter too which give increased steering. As a bonus the hubs uses bigger and more durable 10x5 bearings. Below is a link with pictures of Steen Graversens where you can see the HPI parts.
http://www.e-image.dk/
Mr_Orange is offline   Reply With Quote
Old 08-29-2005, 02:44 AM   #9854
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
Has anyone ever put the rod guide in the bottom of the TRF shocks in the wrong way? What happened?
dontfeelcold is offline   Reply With Quote
Old 08-29-2005, 11:12 AM   #9855
Trader Rating: 37 (100%+)
Now these are awesome!
http://www.rczone.net/modules.php?na...rticle&sid=644
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
