Old 08-25-2005, 11:43 AM   #9826
C_O_jones's Avatar
BritRacer
Bearings are 630, Tam # 9805646.
6x3mm
Fred
Bacon is Meat Candy
C_O_jones is offline   Reply With Quote
Old 08-25-2005, 06:31 PM   #9827
TryHard's Avatar
Originally Posted by Andrew Twigger
Thanks Ed,
Looking to try this theory out once I get it built. May take it down to Beddy on Friday for a Maiden voyage.
Andrew
Hey Andrew,
If it's any help, there are a few setups on my site for Beddy, one at least from the TORC round, along with Ben C's setup he used to win the BRCA Nat with in '04.
One thing thats good to try (if you've got the blocks) is too narrower the front end down, by running A/A. You'll need the optional A-Bridge block to run it though. I found this really helped keep the nose in tight on the sweeper off the straight.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 08-25-2005, 07:44 PM   #9828
BritRacer's Avatar
exactly where does the hop-up heatsink beam go?
BritRacer is offline   Reply With Quote
Old 08-25-2005, 08:05 PM   #9829
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Is anyone running the solid front diff with the one way center shaft on asphalt? What are your findings with this setup?
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 08-26-2005, 02:53 AM   #9830
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
i think that woud be on the rear bulkheads there is a screw slot between those two rear bulkheads
buboy28 is offline   Reply With Quote
Old 08-26-2005, 03:37 AM   #9831
V12
V12's Avatar
Exactly this is the right position. When mounting just make sure you position the flat spot on the heatsink beam toward the diff pulley other than that it doesn´t work.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 08-26-2005, 03:39 AM   #9832
Originally Posted by TryHard
Hey Andrew,
HiH
Ed
Thanks again,
I have already been on your website actually. I looked at both setups and decided to copy Ben's first of all to see where that lands me. I've got the shock setup as his now and it feels really hard, particularly in comparison to my TC4. My car is somewhere between Ben's and yours it would seem as you have different suspension blocks and shock towers I think.
I have noticed quite a few complications while building the car which I wondered what other people did to solve;
By running the LWT suspension with 46mm driveshafts it would appear that these are just so slightly too long - as with the one way installed the shafts touch the rubber O-rings that the manual suggests you install. To combat this I took the O-rings out, but would rather have then in to pro-long the life of the shafts and outdrives
With the LWT arms being slightly narrower from front to back the shimming suggested in the manual is obviously out - how have you shimmed yours? I just tried to make the arm slightly forward or back in its stance depending upon the original suggestion if that makes sense - but obviously with more spacers.
I have bought a spool as this is what I almost exclusively used to run in my TC4 - I can't run this with a one way lay shaft pulley can I? This would surely just act as a coupled one way wouldn't it?
Andrew Twigger is offline   Reply With Quote
Old 08-26-2005, 04:31 AM   #9833
TRF415boy's Avatar
Ben likes hard suspensions setups, but he has the ability to take the advantage of it without being disturbed by the disadvantages.
your problem with the shafts, is it with the original's 415 one way outdrives (that are offset to make up for the narrower one way housing compared to the TRF 414's) or the normal ones as on the TRF 414 ?
TRF415boy is offline   Reply With Quote
Old 08-26-2005, 07:22 AM   #9834
Trader Rating: 37 (100%+)
Do you mean regular diff....sorry don't understand what you mean by "solid diff".
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 08-26-2005, 09:05 AM   #9835
V12
V12's Avatar
I think he speaks of a spool.
Old 08-26-2005, 02:59 PM   #9836
Hi
Does anyone run Pro 4 rear hubs and stearing knuckles? I have heard that Marc R use's them. What advantage would this give?
FTD RACING is offline   Reply With Quote
Old 08-26-2005, 03:04 PM   #9837
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Default TRF415 MS
found this on Ebay for anyone looking for one
http://cgi.ebay.com/Tamiya-415-MS-1-...QQcmdZViewItem
tamiyarcracer is offline   Reply With Quote
Old 08-26-2005, 03:17 PM   #9838
Originally Posted by FTD RACING
Hi
Using the rear hubs was something I was told they did before to be able to use 0deg rear hubs. Now with the new 0deg aluminum rear hubs from Tamiya I'm sure you won't see any Pro4 pieces on team cars. I'm not 100% sure if Tamiya makes 0deg plastic hubs so it's a good alternative if you want to use them.
I've never known anyway to use the Pro4 knuckles on rubber tires...the only real reason to switch to Pro4 knuckles would be if you run 28mm foams for carpet racing. Those give you the clearance to run them.
Old 08-26-2005, 03:25 PM   #9839
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
what was the HPI front knuckle part number again...carpet season is coming
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 08-26-2005, 08:35 PM   #9840
HPI Pro4 Carbon Graphite Steering Block and Rear hub carrier (1 each)
Part #: HP73507
http://www.speedtechrc.com/store/ebp...id=188&id=1421
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
