Old 08-22-2005, 02:49 PM   #9811
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
The original 415 is really a tank, only thing i've broken (cracked) is a caster block, drove with the cracked caster block a half day..
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Savx - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 08-22-2005, 04:07 PM   #9812
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
This car will be used for carpet but mainly asphalt as the weather here is warm most of the year
I see alot of people with the MS shock towers? why?
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 08-22-2005, 04:18 PM   #9813
TryHard's Avatar
Originally Posted by Tral
What is the difference between A and D blocks in milimeters?
Are XA XB XC and XD block wider than standard or narrower?
I've tried to measure the difference before, but gave up when I figured all i really needed to know was what the angle difference between the blocks were. I might try and measure them again at some point.
The X-series blocks are narrower than the std series, they basically continue off where the X block finishes, allowing correct toe to be run with 0deg rear hubs.
The full range goes (from widest to narrowest);
D, C, B, A, X, XA, XB, XC, XD
The MS towers are slightly different to the std towers. Firstly they are about 1mm lower, and there is the extra hole on the rear tower.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 08-23-2005, 12:31 AM   #9814
The MSX conversion is finally up for pre order on speedtech at $270...
Stiff price...
Ben.C is offline   Reply With Quote
Old 08-23-2005, 02:08 AM   #9815
Can someone just confirm for me something about the standard toe blocks.
I have built the car as per instructions but have replaced the wishbones with the lightweight ones instead - have I in turn changed my rear toe in by doing this?
Andrew
Andrew Twigger is offline   Reply With Quote
Old 08-23-2005, 02:38 AM   #9816
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Stiff price...
i wonder how much would the entire kit be price
buboy28 is offline   Reply With Quote
Old 08-23-2005, 09:08 AM   #9817
SpeedTech's Avatar
Hi Guys,
Finally received a price on the upcoming TRF415MSX conversion kit (set for october release). We set the price on the conservative side at the moment (on the higher side) just in case the manufacture change their price when the production arrive, but if all remains the same, the actual price might be a bit lower We are also working on trying to get this kit in around Japanese release date so there will be minimal delay for the US market.
Tamiya Limited Edition TRF415MSX conversion kit is available for pre-order!
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 08-23-2005, 09:22 AM   #9818
TryHard's Avatar
Andrew
Simply put..Yes.
The LWT suspension uses 1deg rear hubs, whereas the Std suspension uses 2deg. So you'll have one degree less toe-in on the rear (ie from 2.5deg with C/D, down to 1.5deg)
HiH
Ed
Old 08-23-2005, 09:51 AM   #9819
Originally Posted by TryHard
Simply put..Yes.
HiH
Ed
1.5 is a bit on the low side from my experience. What combination of blocks do I need to use in order to get my toe back to what it should be - or do you still use this amount of toe?
Andrew
Old 08-23-2005, 10:05 AM   #9820
TryHard's Avatar
Given I only run stock, I tend to stay around 2deg, ocasionally dropping back to 1.5 if the track is particularly fast.
To get 2deg, try B/D; for 2.5, try A/D.
Basically you'll find that each block produces a 0.5deg change. So it's fairly easy to figure out once you get your head round it
On my site, you can actually find an excel spreadsheet which details the block changes. Direct Link: http://www.thard.co.uk/rc/TRF415/setups/ToeBlocks.xls
HiH
Ed
Old 08-23-2005, 06:34 PM   #9821
Burlap's Avatar
Send a message via MSN to Burlap
I run stock on a fairly tight twisty track, and have around 2.5deg of toe-in on my car.
Burlap is offline   Reply With Quote
Old 08-23-2005, 06:55 PM   #9822
Rnning mod, foam or rubber, i generally stick to 2 degrees rear toe.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 08-23-2005, 07:09 PM   #9823
Send a message via AIM to odawg315
i normaly run 2.5 as well, however my last race i needed more speed so i droped to 1deg, made a noticable difference in straightline speed, however car was very loose in, but faast.
odawg315 is offline   Reply With Quote
Old 08-24-2005, 02:21 AM   #9824
Thanks Ed,
Looking to try this theory out once I get it built. May take it down to Beddy on Friday for a Maiden voyage.
Andrew
Old 08-25-2005, 11:30 AM   #9825
BritRacer's Avatar
Can anyone tell me the dimensions of the flanged bearings on teh steering ackerman on the 415.
I have ordered some from precisionrc but would like to find some locally sooner if possible.
BritRacer is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
