Old 08-09-2005, 12:55 PM   #9661
As said before the MS and the TRF415 chassis are different bolt spacing for the toe blocks. The range of adjustment for the TRF is more than the MS. The MSX that was run at Reedy had the old TRF 415 spacing for the lower plate toe blocks. Other than that the rest of the central chassis was the same.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 08-09-2005, 09:05 PM   #9662
Default MSX Conversion
Well I have not completely kept up on the 415MS kit contents and changes, but the bulkheads were the same maybe with the exception of the heatsink rear type as that part was available to the Standard 415. Same bolt pattern to the bottom chassis.
Also the LWS kit allowed you to put it on the Standard 415 with no other blocks needed and it would work. The same components are in the 415MS car kit. Maybe the LWS kit A-arms would need extra shims to fit it on the Standard 415 between the blocks. Maybe the 415MS blocks are really closer together. But it should not keep Standard 415 kit owners with the standard suspension from being able to install the MSX conversion as it is just the bulkheads, shock towers, and upper deck + screws and shims. I just don't see it being out of alignment with screw holes or with the suspension or drivetrain like swingshaft alignment.
Also I noticed the 415MS kit and the Reversible LWS conversion kit is now discontinued items as per the Tamiya USA website.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 08-09-2005, 09:12 PM   #9663
Difuser,
Just reading your post again, Do you mean the bolt spacing of the 415MS of the blocks are closer to each other as in closer to the centerline of the chassis spliting the left and right sides (if line drawn front to back) when mounted?
So that would be EVO IV blocks? And also these new XA, XB, XC, XD blocks part of the 415MS Champion parts set? And that would eliminate those from ever going onto a Standard 415 kit?
Old 08-09-2005, 09:27 PM   #9664
C_O_jones's Avatar
190mph,
The spacing of the suspension blocks being closer together would be a shorter hinge pin on the MS as compared to a std 415.The front and rear of the chassis screw hole locations are the same, just the adjoining holes are closer.
Bacon is Meat Candy
C_O_jones is offline   Reply With Quote
Old 08-09-2005, 09:31 PM   #9665
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally Posted by V12
Yes you´re right. Until now it seemed the MSX chassis is different to the MS chassis and is included in the conversion kit.
Just was at the Tamyia USA site and now you can read there the chassis isn´t included. This was different in the beginning.
So the conversion kit get´s even more expensive.
Maybe Tamiya should realize you can get a similar complete car for not much more money than this conversion kit.
Figures ....
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽµ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 08-09-2005, 10:05 PM   #9666
Burlap's Avatar
Send a message via MSN to Burlap
I apologise if this has been posted before. From Rainbow Ten's website:
53866 TRF415MS PRO MODULE SUSPENSION SET
*Compatible Chassis: TB EVO 4, TRF415MS,
(also TRF415 equipped with reversible suspension)
*ALUMINUM PRO MODULE SUSPENSION
*SCREW & COLLAR FOR DAMPER STAY
*SOFT SPRINGS
*LINKAGE REAR UPRIGTH
*STAINLESS SHAFT
8000YEN Late September
Burlap is offline   Reply With Quote
Old 08-09-2005, 11:09 PM   #9667
Pezz's Avatar
Send a message via Yahoo to Pezz
Anyone know of a part number for the joint cup, that is included in the 415 front direct coupling? I need to order some.
-B
Pezz is offline   Reply With Quote
Old 08-09-2005, 11:38 PM   #9668
*SOFT SPRINGS
*STAINLESS SHAFT
Japanese Street price should be about 6200~6500Yen ... or about 58$
-Dave
Old 08-09-2005, 11:39 PM   #9669
-B
You"ll have to buy a new spool set just to get the joint cups
-Dave
Old 08-09-2005, 11:44 PM   #9670
Pezz's Avatar
-Dave
That's what I was afraid of... Do you think they might sell them seperate in the near future?
-B
Old 08-09-2005, 11:49 PM   #9671
-B
Not too sure.. ..
Old 08-10-2005, 02:26 AM   #9672
-B
I suppose they will....
Ben.C is offline   Reply With Quote
Old 08-10-2005, 06:46 PM   #9673
Default Battery strap
I have a few of these for sale. $15.00 shipped. USA only.
Set up for XRAY post but can changed for standard type post.
http://cgi.ebay.com/ws/eBayISAPI.dll...MESE%3AIT&rd=1
My email is [email protected]
gonad is offline   Reply With Quote
Old 08-10-2005, 07:03 PM   #9674
Burlap's Avatar
Bummer, US Only. That looks pretty cool and I use the XRay battery brace in my 415.
Old 08-11-2005, 03:53 AM   #9675
Hello
Finally i got my TRF415MS. Do you have any advice for me about assembling this car? Are there any "must have" parts or tuning parts that should i buy at the begining? Maybe some more suspension blocks?
Is it good idea to use one way in front and center one way pulley? Or should i buy direct pulley?
Can you give me links for some good setups? Do you have setup Marc Rheinard from EC 2005 from last week? I know that he was using MSX.
Please give me links for good on-line shops with spare parts and aftermarket parts for Tamiya.
Thank you in advance.
Tral is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
