Old 07-31-2005, 05:12 PM   #9556
Burlap's Avatar
Send a message via MSN to Burlap
Cool pics and interesting interview.
Burlap is offline   Reply With Quote
Old 07-31-2005, 05:18 PM   #9557
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Nexus
I have both a standard 415 and a 415 with the LW suspension parts.
Overall I think both are very capable. With my current setups the 415LW seems to corner much better. As for the durability I'm actually surprised at how well the LW bits have held up. Before I owned ithe LW parts I thought they would be fragile. Now having run 8T mods on carpet and asphault I see it's very durable.
If you want to try something different or are concerned about the smaller bearings with the LW suspension....use Pro4 knuckles with 4x10 bearing (i think that's the size). With that you just need about a 1mm shim on top of the knuckles to fit snug in the c-hub.
1050 bearing
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 07-31-2005, 06:12 PM   #9558
TryHard's Avatar
Originally Posted by JDM_DOHC_SiR
You are Correct ... . The Shock shafts sold by Tamiya.. ( but made by ALEX )
-Dave
Really? Didn't know that. Part #?
| THard.co.uk | Xray | MuchMore |
Old 07-31-2005, 06:58 PM   #9559
Here ya go
TRF Damper Titanium Coated Piston Rod (2 pcs.)
Item No.53850
Old 07-31-2005, 11:08 PM   #9560
hi guys
i am running the standard 415 in kit form and i cant get any front steering on a smooth tar surface whilst running mod.I dont want to got to the expense of replacing all the parts to make it a MS,does someone have a set up i could try or is it a non issue
grahame is offline   Reply With Quote
Old 08-01-2005, 12:38 AM   #9561
acutts's Avatar
Hi Guys ... ayone got a release date for MSX conversion yet?
acutts is offline   Reply With Quote
Old 08-01-2005, 01:59 AM   #9562
News that it should be out around september...So its another 1 month wait.
Ben.C is offline   Reply With Quote
Old 08-01-2005, 04:22 AM   #9563
Burlap's Avatar
Originally Posted by grahame
hi guys
What type of servo are you running, motor and wheel (foam or rubber)?
The way I got some more front steering on my car was to put the ball connector for the steering arms on the outside spot on the front uprights, dial a little more rear toe-in and about 1.5 deg of front toe out. Since getting the digital servo, the car pretty well turns nicely now. Leaving the ball connector on the inside hole seemed to make the car too twitchy.
Old 08-01-2005, 04:25 AM   #9564
running a 12 x2 and a ko servo and take off 27
its got bad under steer in and mid corner
Old 08-01-2005, 04:30 AM   #9565
Jack2's Avatar
What style of front drive are you running (i.e, one-way, Spool or Diff) ?
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 08-01-2005, 04:33 AM   #9566
what ever the car comes with??????
Old 08-01-2005, 04:40 AM   #9567
Jack2's Avatar
You might want to try adding some more spacers under the front upper inner link, I usually run at least a 4mm spacer, it will raise the front roll center quite a bit and I find it makes the car turn a lot better.
If you are running some anti-dive, get rid of that and dont run any anti dive.
you might want to add some anti-squat, and maybe try decreasing the rear droop.
if you are running harder springs on the front, go back to the Tamiya yellow kit springs, front and rear, they seem to work very well and are a great starting point on asphalt.
Schumacher Mi4CX
Mugen MTX & MRX
Old 08-01-2005, 04:52 AM   #9568
Originally Posted by Jack2
You might want to try adding some more spacers under the front upper inner link, I usually run at least a 4mm spacer, it lowers the front roll center quite a bit and I find it makes the car turn a lot better.
the front upper link??does that have 1d on it other wise i am lost
Old 08-01-2005, 05:21 AM   #9569
Jack2's Avatar
The front upper link is just the front camber link. Here is a Pic-
Schumacher Mi4CX
Mugen MTX & MRX
Old 08-01-2005, 05:25 AM   #9570
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Correct me if I am wrong, but isn't what you are saying raising the front roll center??
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
