Old 06-24-2005, 01:56 AM   #9241
Any news for the release of the 415MSX??
MARKANO is offline   Reply With Quote
Old 06-24-2005, 03:11 AM   #9242
Szimon's Avatar
It should be available in about 2 month
read more info's here: http://www.realrc.net/modules.php?na...rticle&sid=162
Szimon is offline   Reply With Quote
Old 06-24-2005, 05:14 AM   #9243
But i want it now
grahame is offline   Reply With Quote
Old 06-24-2005, 05:52 AM   #9244
I'll convert both of my 415's to that bulkhead, the rest is all good. Anyone got part numbers?
Alonso: Don't waste your time gettin a tamiya spool if you only need it for TCS. I know for a fact that you will be at least 1/2 a sec a lap slower as TCS is at castle hill again.
BTW: hara's own words today... no spool for fairy meadows
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 06-24-2005, 10:16 AM   #9245
dynoman007's Avatar
Send a message via MSN to dynoman007 Send a message via Skype™ to dynoman007
Default ratio
what is the internal ratio on the 415....
dynoman007 is offline   Reply With Quote
Old 06-24-2005, 12:09 PM   #9246
ttso's Avatar
2.187
ttso is offline   Reply With Quote
Old 06-24-2005, 05:21 PM   #9247
Ballsie's Avatar
Thanks for the info Re: the car stands.
I'm really p*ssed of with the new 415 spool!
The derlin outdrives are worse than useless, I melted two in two laps tonight running on carpet with foams. Should I be running 46mm shafts with it even thought i'm using the original 415 suspension?
Anyone else had problems with it?
Ballsie is offline   Reply With Quote
Old 06-24-2005, 05:38 PM   #9248
snopro31's Avatar
Trader Rating: 36 (100%+)
I think foam tires on carpet would beat the crap out any spool. foams on carpet have alot of traction . I have never tried anything myself other then a doff or oneway on the carpet so i dont know my spool has only been used outside (its not a tamiya spool either)
snopro31 is offline   Reply With Quote
Old 06-25-2005, 05:50 PM   #9249
rraden's Avatar
Trader Rating: 235 (100%+)
Default shock question
Can anyone tell me if the Tamiya Flourine coated dampners, part #53571, will fit on the TRF415 or EVO4?
rraden is offline   Reply With Quote
Old 06-25-2005, 05:58 PM   #9250
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Should. All the aluminum shocks will.
tamiyarcracer is offline   Reply With Quote
Old 06-25-2005, 09:28 PM   #9251
JimmyMac's Avatar
I agree about the spool on carpet. Carpet is very tough on the drivetrain due to the high traction and usually tight turns on a carpet course. Was this in stock, 19t, or mod? Also, if you just tap a corner, you could easily destroy a plastic spool.
Not that I have run the new Tamiya 415 spool (I sold my 415 to my friend), but I ran my new Tamiya EvoIV spool outdoors today in Stock class. It held up very good with no signs of visible wear on one side. On the other side it shows alittle sign of wear from when I tapped a flapper(corner). But it's nothing to worry about. I also posted my fastest TQ time and new track record in stock class as well. So I think this spool has helped out in the performance of my car. Previous TQ record was with my Yokomo BD. Also, I don't get any chatter from this spool as I do when I use steel spools.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 06-26-2005, 03:01 AM   #9252
Delrin outdrives? Sounds like a spool a race with my 7/8 turns
The flourine coated shocks are standard with the original 415 and will fit all of the tamiya on-road touring cars
Powered by Falco
Old 06-26-2005, 04:27 AM   #9253
BrainTeased's Avatar
is not wanting chatter noises a personal preference or a performance issue?
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 06-26-2005, 05:05 AM   #9254
Mr-s413bt's Avatar
Heya Guys.
Ok i have had an issue with my Speedtech spool diff in my 415.
Basically after its 3rd run, i very lightly rubbed a board on the outside of our esses only to turn in for the next corner to spin out. I pulled off right away and found that i had snapped the outdrive in half!! Its snapped almost clean where the slots are.
Any ideas why it snapped so easliy, it wasn't a hard rub at all either as the car wasn't even pushed offline.
Thanks.
Glenn
ps it was carpet, 19t on rubbers.
Mr-s413bt is offline   Reply With Quote
Old 06-26-2005, 06:28 AM   #9255
rraden's Avatar
When running a spool anytime one tire is forced to rotate at a different rate than the other tire the weakest part in the front drive train will break. In the HPI Pro 4 it was the bevel gear. On this car the weakest part is probably the outdrive. It doesn't take much!
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
