Tamiya TRF415
#9151
yes
Originally Posted by Bad Boys Racing
hey, how should i file the batt holders down on my car or is it optional, i just have a funny feeling i would wreck the chassis if i tried?
y
You should file down it a bit ...just so that the cells sit nicell on the chassis.
it also lets the cells sit lower the chassis..
just take your time an slowly file it down.... then just seal it up once ur down.
also just as u are filing keep putting the cell back on ancheck that u haven't filed too much that the cell is sitting below the chassis.
#9152
Chassis Filing
Yep, you have to file the battery slots, otherwise the sharp edges will cut through the shrinkwrap on your cells, and eventually short them out. Carbon Fiber is mildly conductive. If you don't mind seeing your car in a ball of smoke, no need to file.
A couple of tips -
Use a single cell, if you have one, to make sure it sits in each slot nicely, preferably flush with the bottom of the chassis.
Use one of your good packs to make sure the whole thing sits evenly in the slots.
Just take the sharp edge off the 2 end slots, each end of the battery. Only the edges between the cells need to be filed further to get the pack to sit low and even. I wish I knew this when I did my first chassis.
Take your time, and take small amounts, then check the fit. It is a time consuming task, no one likes it, but you'll be much happier with your car if the batteries fit well and sit low.
Mike
A couple of tips -
Mike
#9153
ok, do i have to retain the original shap of the holes or can i just file them in a square shape like my TC3 slots are
#9154
Help::: Carpet Set up needed!
Heya Guys.
I got a 415 (non-MS version)
Looking for a set up for rubbers on carpet.
Currently i have:
diff in the front
direct centre pulley
40wt ae oil and 2 hole pistons all round
yellow springs and sway bars
2mm under the fron ball stud
3mm under the rear ball stud
Factory everything else
Any help would be greatly appreciated
Glenn
Currently i have:
diff in the front
Glenn
#9155
the edges on my slots are rounded but they cells don't fit that well, what should i do now?
#9156
#9157
This thread should be titled: The Rich and Wealthy I sure would love one but do not want to have to remortgage the house! Why is that the top cars that Tamiya makes has to cost so much? ie... TRF 415MS and Evo iv. One day when I win the lottery I own one
Grip it and Rip it!
Grip it and Rip it!
#9158
Grip it and Rip it!
Grip it and Rip it!
#9159
Grip it and Rip it!
Grip it and Rip it!
#9160
Originally Posted by Besercoe
Each to their own champ, next thing you are going to admit to driving a corally, now thats an expensive car.
Actually I still race a Losi Street Weapon
#9161
A few quick questions regarding some 415 parts.
1. What are the differences between these two parts...
Tamiya Aluminum Rear Uprights for Touring Cars ??deg.
Part #: TAM53687
Tamiya rear hub carrier aluminum 1 deg.
Part #: TAM53784
Are they the same pieces just different in the 'degree'
2. What is the degree of toe for this part. I think I asked waaay back when but I wanted to verify.
Tamiya Hard Rear Upright for TA04/414MII
Part #: TAM53428
3. Will the part listed for the MS suspension work on the stock front c-hubs.
EVO IV Flanged Tube
Part #: TAM51100
I also have some parts for the LW suspension that I am going to post for sale if anyone is interested. They are like new...built up and mounted but never used. I prefer the stock suspension for it's durability.
1 set front and rear arms
1 set 4deg c-hubs
1 set of front knuckles
1 set of rear hubs
pm or email if interested.
Thanks in advance to anyone who can answer those questions. Anyone from the Tamiya camp know what the status of the TRF page is? Doesn't seem to be much information being feed through that page.
Part #: TAM53687
Part #: TAM53784
Part #: TAM53428
EVO IV Flanged Tube
Part #: TAM51100
1 set 4deg c-hubs
1 set of rear hubs
#9162
Part #: TAM53687
Part #: TAM53784
Part #: TAM53428
EVO IV Flanged Tube
Part #: TAM51100
1 set 4deg c-hubs
1 set of rear hubs
Part #: TAM53687
Part #: TAM53784
Part #: TAM53428
EVO IV Flanged Tube
Part #: TAM51100
1 set 4deg c-hubs
1 set of rear hubs
1 : one is for the STD suspension the other is for the Lw suspension.
2 : already answered that, it's 1°
3 no they're different lengths you can use those from the std suspension on the LW if really need to use one, but not the contrary, as it would bind the steering.
#9163
#9165
Guys,
What are the Corally Blades part numbers for the RCManiax Spool?? Is it: Part #: COR791898
One of mine just broke on the 5th run with the spool and I need to replace it. I don't think that should have happened, so I must have done something wrong.
But........ the car is awesome with it. Very happy with this spool
