Old 06-05-2005, 04:27 PM   #9091
TRF415boy's Avatar
Originally Posted by A-Ko
On the Suspension blocks.
What has been the height of the EvoIV and 415 blocks. The EvoIII and 414 are 2mm and I think 1mm respectivly.
And do you know the part Numbers of the 0deg, 1deg and 2deg hub and what car they came with?
The lowest ones are those of the 414, the ones from the 415 are 1mm higher and those of the Evo 3/4 are 2mm higher than 414.
TRF415boy is offline   Reply With Quote
Old 06-05-2005, 05:30 PM   #9092
Send a message via AIM to odawg315
hey guys,
i got a question maybe someone can answer, i just ordered a dj suspension for my car, only problem is my car is a trf414... anyone know if i can make this work, i know i had to get the evo shafts ,axles and bearings, the only issue i can forsee is the damper stay, but this should be easily worked out with spacers. anyone with a clue if this can be done or will i be putting the dj system on ebay or buying a 415ms, i wont get rid of my 414, i had a 415 and liked it the 414 better.
odawg315 is offline   Reply With Quote
Old 06-05-2005, 05:32 PM   #9093
I cant see why it wouldnt work, i would say you just need to play with driveshaft lengths, and spacing of the shock tower, make sure you take a pic when its finished.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 06-05-2005, 06:00 PM   #9094
of course, i think itll work, i mean the car uses the same arms and shafts as the 415 so it really shouldnt take to much engineering to get it working. its coming wed. so hopefully ill have pics by the week
Old 06-05-2005, 11:54 PM   #9095
Send a message via AIM to A-Ko
Thanks for the info...
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 06-06-2005, 01:44 AM   #9096
Burlap's Avatar
Send a message via MSN to Burlap
Originally Posted by odawg315
hey guys,
Copied from the DJ suspension thread (since the 414 and standard 415 run the same suspension):
Originally Posted by Kevin CBR
To put on a regular 415, you will need the 2.6 x 25mm shaft that holds the hub carrier to the A-arm P/N 51099, the 46mm swing shaft P/N 53724 aluminum or P/N 51092 steel, EVO IV wheel axle P/N 51094, Universal drive shaft joints P/N 53500, 5x9 bearings (x4), and then use extra spacers on the hinge pin to take out slop. The 415 uses a 48.5mm hinge pin, the lightweight MS version hinge pin is only 46mm and the DJ arm is designed for the 46mm hinge pin on the EVO IV and 415MS.
There you go
Burlap is offline   Reply With Quote
Old 06-06-2005, 04:32 AM   #9097
Mr-s413bt's Avatar
Default Solving Tweek problems
Hi everyone
I just bought a TRF 415 and i cant solve these damn tweek problems.. anyone got some suggestions?? Its driving me MAD!!!!!
Cheers Glenn
Mr-s413bt is offline   Reply With Quote
Old 06-06-2005, 04:35 AM   #9098
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally Posted by Mr-s413bt
Hi everyone
Cheers Glenn
what tweak problem? if anything that chassis is too stiff.
jeffreylin is offline   Reply With Quote
Old 06-06-2005, 04:38 AM   #9099
Mr-s413bt's Avatar
Everytime i put the car back together its basically that it twists on one side.
Old 06-06-2005, 04:38 AM   #9100
Jack2's Avatar
Hi, yeh when I put My 415MS together I found it tweaked if the top deck wasn't tightened correctly. try loosening all the top deck screws and all the chassis screws and triple check and be very precise about how you tighten them and sit the chassis on a dead flat surface with shocks and roll bars disconnected, they have to be tightened in a perfect X pattern. Same with the chassis screws.
~Jack
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 06-06-2005, 04:42 AM   #9101
Mr-s413bt's Avatar
Ive undone all the screws and its just sitting on a flat surface and it still doesnt sit flat.
Old 06-06-2005, 04:47 AM   #9102
Jack2's Avatar
hmmm, unscrew every thing from the chassis, and sit the chassis by it self flat on a perfectly flat surface. If it is twisted, your up for a new chassis, if it sit's flat, you buggered something up when you built it.
also check the top deck isn't twisted.
Schumacher Mi4CX
Mugen MTX & MRX
Old 06-06-2005, 04:52 AM   #9103
Mr-s413bt's Avatar
Also... when i drive it ... on power it pulls to one side .. then off power it pulls to the other??????????
Cheers everyone
Old 06-06-2005, 04:55 AM   #9104
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
I've only ever had the chassis tweaked on my once, and I just unscrewed all of the screws to relax all of the chassis, and left it overnight for it to go back to shape. Try that, then screw it together in X patterns like Jack2 suggested, and then I think you should be right. It fixed my tweak problem completely!
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 06-06-2005, 04:59 AM   #9105
Mr-s413bt's Avatar
Ok well ive stripped it back down.. I'll leave it over night and see how we get on. Cheers for your help everyone
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
