Tamiya TRF415
#8986
Like I stated before, I'm in agreement with TRF415 boy here....
The only way they would lower the CoG with that amount of alloy on the bulkheads to make the whole drivetrain lower, say knocking a couple of mm out of the height of the bulkheads. Of course won't be able to tell that without looking at a few more detailed pics of the car.... or having got a few more details.
I can honestly see no reason otherwise the car would have a lower CoG otherwise... there's just too much alloy up high. especially given the look of the overly complicated rear bulkhead mounting in the middle.
Admitadly, some pieces on there look useful (camber pick ups for example), but nothing so special that couldn't be solved with a few custom carbon pieces...
And with regards to the mullti-piece bulkheads... yet more weight high up! How can anyone possibly say that a bulkhead in two pieces, with mounting hardwear is any lighter than the single piece currently used?
The only bit that really caught my eye was the lowered steering knuckles (by about 6mm), although I already run my rack in a similar position, just the kunckles are lower (carbon plate is on top, not below the kunckles).
Of course thats not to say I wouldn't consider one when it came out...just a little underwhelmed at the moment
And @ Entropy.... says something about the Cyclone though... when the pulley is a direct fit.... after all which came first?
Regards
Ed
Regards
Ed
#8987
I have just bought a TRF415MS kit. I want to run it with a spool so is there any other parts I will need to get? Also is there anything I should get that is a good addition to what looks like an awesome beast.... :-)
#8989
F.Alonso,
Been running one for the past few weeks.... very nice Find it gives loads more steering, plus better throttle response.
And Acutts, in agreement with F.Alonso here, direct centre pulley would be the only part you really need. Although you could get another front pulley, to make swapping over quicker and easier.
Regards
Ed
Regards
Ed
#8990
Originally Posted by TryHard
F.Alonso,
Regards
Ed
Regards
Ed
Ed ... where can I get direct pulley in UK ... do you know anywhere???
Also another front pulley I don't understand????
#8992
Originally Posted by Jack2
Front pulley : (front gear that the belt run's on, the gear that is bolted onto the front one-way) this means you can change from the one-way to spool or vice versa without changing over the gear.
#8995
Haven't run it yet, just it arrived today and I was impressed with its build quality, and it's weight. I want to use some of that Spin Grease Eirik was recommending so I'll still probably use the oneway at Boronia on Wednesday night, then I should have the grease for the weekend so I can use the spool at TFTR. Gotta play around with what sort of EPA I can use without getting chatter, which is the first issue to sort out.
#8996
Simon,
The Anti Wear Grease that comes with the car works really good as well, it will actually prevent chatter even more! Friction will be slightly higher because it's very "sticky"
#8998
Not a whole lot, just apply some grease around the Blade/Dogbone and you will be fine!
Clean and regrease after 6-8runs....
