Old 05-12-2005, 11:38 PM   #8836
R/C Tech Charter Subscriber
Ya that was my next on the to do list. Figured I would check here too. Hopefully I'll be back in town in time for the TCS this year. Once the car gets here, all I'll need is PS and batteries and I'm ready to race again (more like try to keep up).
NismoSkyline17 is offline   Reply With Quote
Old 05-12-2005, 11:39 PM   #8837
Originally posted by Jack2
what brand of oil & which type of pistons ??
Serpent silicone oil (Same as the xray line) the white 2 hole pistons
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 05-13-2005, 12:17 AM   #8838
Jack2's Avatar
MMM... very strange. Hope mine don't go all funky like that
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 05-13-2005, 06:25 AM   #8839
Dan415ms's Avatar
Default Foam on Carpet help for MS
Hi Guys,
I recently built my 415MS what a beautiful thing! I have also replaced the front one way with a diff after gathering all the yokomo/tamiya bits and have fitted a solid centre pulley instead of the one-way.
I have run it on carpet twice and I just cannot get it to be competitive and to handle right, if any of you run on carpet with foams please help?!
My setup:
Front Foam: 42 shore orion fresh kicks
Rear Foam: 37 shore orion fresh kicks
Front Springs: Tamiya White
Rear Spring: Tamiya Blue
Motor: 19 turn Integy Matrix Quad Mag
Speedo: Nosram Dominator Evo
Front Roll Bar: Kit Blue
Rear Roll Bar: None
Body: TRF Subaru Legacy B4
All else such as droop/shock position etc is as per the kit setup.
I have been doing well (won the club championship!) with my losi xxx-s on carpet with foams but cant get the 415 to handle as well as the losi.....I am determined to persevere with it as it runs so smoothly. The main problems are that it seems to skip and jitter when turning hard and understeers a bit on full power.
Any info very welcome!
Thanks,
Dan
Dan415ms is offline   Reply With Quote
Old 05-13-2005, 06:42 AM   #8840
Scho's Avatar
Send a message via MSN to Scho
Seems takiya have there own spool coming out, http://www.pro-s-futaba.co.jp/hsphoto/VFTS00031.jpg
Scho is offline   Reply With Quote
Old 05-13-2005, 06:49 AM   #8841
TryHard's Avatar
hey dan,
I was chatting to you yesterday via email.
Deffiently try out thoose things I suggested.
However I like I also said, I've never used foams, but there are deffiently people on here who have who can help you out.
Regards
Ed
| THard.co.uk | Xray | MuchMore |
Old 05-13-2005, 07:08 AM   #8842
Dan415ms's Avatar
Hi Ed!
Your emails were most helpfula nd I will be trying out the settings! Thanks!
Just thought i'd whack the question on here anyway to see if any of the worldwide 415ms racers have a perfect foam on carpet setup.
Thanks again.
Dan
Old 05-13-2005, 07:11 AM   #8843
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
Default Re: Foam on Carpet help for MS
Originally posted by Dan415ms
Hi Guys,
My setup:
Rear Roll Bar: None
Dan
its been a while since i ran the 415 on foams, but as a start i would think the springs are a little too soft, maybe scrubbing corner speed. if i remember right, i had used Associated springs, purple front, copper rear, with 60wt front, 40 rear.
not sure about those tires, really... never have tried them on carpet.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 05-13-2005, 11:19 AM   #8844
Arun's Avatar
Hi Guys,
My setup:
Rear Roll Bar: None
Thanks,
Dan
I would say that you definitely need to start by changing your tires. Jaco double pink\orange fronts and double pink rears are the best starting point. Your biggest problem is that these tires will not fit on the front end because the tamiya stock steering knuckle does not give enough clearance. In the States, we switched to the HPI steering knuckle from the pro4. To complete the conversion, though, you need 4 5x10mm bearings and the wheel axle from the old tamiya suspension.
If you are determined to stick with the tires you have, then you should at least switch to different springs, like the ones Turbonium mentioned. Then, there are several things you can do to increase your on-power steering. My favorite place to start on carpet with foams with the 415 is to raise the inner-upper link on the rear by placing shims underneath the ball nut. Start by adding 1mm, and see if it helps.
As for the "skip and jitter", you should go through the car and see if some thing binds or rubs when you are at full throw. It could just be your tires hitting your shocks or something.
http://nexusracing.com
Arun is offline   Reply With Quote
Old 05-13-2005, 11:30 AM   #8845
Does anyone have a copy of TRF415MS manaul in PDF? I lost mine and need it desperately...
Thank you.
Tamiya Virus is offline   Reply With Quote
Old 05-13-2005, 12:27 PM   #8846
Ill Factor's Avatar
Default Battery Strap
Can someone plerase help in leading me in the right direction to locate a battery strap for the 415.
Thanks in advance
Ill Factor is offline   Reply With Quote
Old 05-13-2005, 03:15 PM   #8847
Turbonium's Avatar
i had last used the 6-cell strap from the Xray, or the one from the RDX will work, with a slight modification....
Wes
Team Novak
Old 05-13-2005, 04:03 PM   #8848
Here's a 415 for sale.
http://www.rctech.net/forum/showthre...50#post1584450
Obsidian is offline   Reply With Quote
Old 05-13-2005, 07:49 PM   #8849
Ill Factor's Avatar
Any idea where I can locate? I checked Speedtech and found nothing. Also what mods need to be done to make it work?
Old 05-13-2005, 07:59 PM   #8850
JimmyMac's Avatar
Try Stormer, they might have some left.. maybe...
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
