Old 05-06-2005, 09:45 PM   #8716
Jack2's Avatar
arhh... I'd say NO to 4 degree's negitive camber. I'd start with 2 degree's negitive all round the go from there. I'd use a different block combination in the rear as well. 1 degree wont work real well in most situations. I would never go below 2 degrees or over 3
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 05-07-2005, 09:59 AM   #8717
dawgmeat's Avatar
Originally posted by David J.
F.Alonso-
The hinge pins are the same as the LW Reversible suspension. At the moment, the Pro-Module system is only distributed by Tamiya America, Inc.
Dawgmeat-
Foam tires will most likely be too wide to fit. I don’t know how effective it would be on carpet with foam tires to be honest. Typically, the set-ups for such are very stiff in comparison to rubber resulting in much smaller suspension travel so you may not see any benefit. Also, on carpet with foam, you’re usually trying to free up the car to carry more corner speed. Traction and stability is usually more difficult to obtain racing asphalt on rubber tires and this is what the Pro-Module System is intended for.
thank you
dawgmeat is offline   Reply With Quote
Old 05-07-2005, 10:05 AM   #8718
dawgmeat's Avatar
Hey Gabe,
Pick a window.......because your leaving!!! J/K
When are you getting a bike so I can show you how to ride? Tell Fernando I'm sorry I had to cut our conversation short this morning. I'll call you guys this weekend.
DJ
How long before the TRF website up and running?
Old 05-07-2005, 10:15 AM   #8719
dawgmeat's Avatar
Default came close
I'm so happy that I didn't sale my 415 this past week, why buy another clone when the 415 is top dawg outdoors, I'll just keep ordering parts from speedtech and rainbow 10 on line
Old 05-07-2005, 02:31 PM   #8720
I'm going to try the DJ suspension today at Ripon. I'll write back with how it worked Sunday. Dominic
discodom is offline   Reply With Quote
Old 05-07-2005, 02:41 PM   #8721
FW-05RR's Avatar
Default Re: came close
exactly my thoughts
FW-05RR is offline   Reply With Quote
Old 05-07-2005, 02:53 PM   #8722
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
Default Evo IV or 415
I am debating between a few touring cars and wanted to get someone to help me with the difference between the Evo IV and the 415. Also what does the MS editions of each have? Any help would be highly appreciated.
cpatel529 is offline   Reply With Quote
Old 05-07-2005, 08:09 PM   #8723
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
whats the best bodyshell for high speed track for the 415?
KREATOR1 is offline   Reply With Quote
Old 05-07-2005, 09:24 PM   #8724
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Ran the 415 today. Pretty much bone stock 415 with the stock suspension with a different rear toe block. Ran rubber tires on it and had a pretty much locked front diff (Yoke setup).
Car was really smooth once I got the right tires on it (TakeOff 32's) and then it steered great and plenty of rear traction. The thing was easy to drive and didn't do anything unexpected. Might try 50wt oil from the 40wt oil I have in it. The track has so much traction your sneakers stick like glue to the track.
Car ran pretty flawless and with the stock suspension setup is pretty much unbreakable for the most part. If it keeps working like this I won't have to spend 80 bucks to get the LW suspension.
ST Racing Concepts (STRC)
Old 05-07-2005, 09:28 PM   #8725
KREATOR1's Avatar
Did you ran on manual settup?
Old 05-07-2005, 09:32 PM   #8726
wyd
Tech Legend
wyd's Avatar
Well it is off some from the stock type setup. I got the car used and it had 4 runs on it and thats it. I changed the oil to 40wt with blue front srpings and yellow rear springs. I do have the alum rear hubs and a total of 2 degrees of rear toe per side. Also have 1mm spacers under the front toe block to add a little more kick for more overall caster. All stock wheel bases and bottom of shocks in the outter holes. Front shocks in one hole on the tower from the outside of the shock and 2nd to last whole in on the rear tower.
The rear blocks are front rear X block and rear C block with the 1 degree rear alum hubs with the ball stud out into the 3rd hole mounting posistion.
Old 05-07-2005, 09:39 PM   #8727
Send a message via AIM to Mantacav1
WYD- heard you like the car... I ran mine at HTGB couldn't make it to fredneck. 2nd behind R.Dodge by 2 laps course i could have drove cleaner. I just might off load the EVO IV. Only thing is for TCS running that darm one-way ahhhhhhhhh!
Mantacav1 is offline   Reply With Quote
Old 05-07-2005, 09:40 PM   #8728
KREATOR1's Avatar
i guess i dont need to buy the LW arms.
Old 05-07-2005, 09:48 PM   #8729
wyd
Tech Legend
wyd's Avatar
I had it on the EVO IV I had and if I ran foams on carpet then it might be nice to have but since I only run rubber tires on asphalt I can't see needing to have it. Also another thing is when I had my EVO IV a few months ago the LW stuff is never in stock when I needed it. I want to race not wait and try to hunt for parts all the time.
Old 05-07-2005, 09:50 PM   #8730
wyd
Tech Legend
wyd's Avatar
I think Tamiya is working on a diff for it. How many at GB today? Did you guys run rubber tires?
Yeah the 415 was awesome today. After some work I had it running pretty good for my driving. Finsihed 3rd tonight so I was very pleased.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
