Old 04-27-2005, 10:33 AM   #8431
dawgmeat's Avatar
Default Re: Re: north east
Originally posted by wyd
I will be running their the weekend of June11th for the Express Motorsports race. Never ran a 415 yet but I will do so in another week or two.
good man welcome to the tamiya family see ya there!
dawgmeat is offline   Reply With Quote
Old 04-27-2005, 10:35 AM   #8432
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Default Re: Re: Re: north east
I will be their bro!!!!!!!! I will hopefully have my 415 dialed by then. Going to run it at least once before Jackson at a indoor asphalt track to try to get a shakedown on the car and to get use to the 415. I have only driven shaft cars for the last few years when I was racing touring.
ST Racing Concepts (STRC)
Old 04-27-2005, 10:44 AM   #8433
dawgmeat's Avatar
Default Re: Re: Re: Re: north east
go with the stock springsor 13-15 lbs. and about 35-40 oil, this car is super responsive. Red sway bars in the front none in the rear, when you attach the red swat bars you will notice a great deal of side to side slop, the way to fix the is to angle the sway bar retainer clips, this let's them operate smoothly and stop the side to side movement
Old 04-27-2005, 11:45 AM   #8434
racer's Avatar
couldn't find info through the forum search.
what is the purpose of reversing the steering hubs?
for example: c1, c2
is it for more steering, how many degrees does it give the user?
Thanks in advance!
racer is offline   Reply With Quote
Old 04-27-2005, 12:01 PM   #8435
TryHard's Avatar
Racer;
Not entirely sure, but the difference between the two settings is axle height.
ie one way round the axle will be higher (c1 on the right, c2 on the left) , the other lower (right c2, left c1).
Don't know what it'll do to the handling, never tried.
Someone else on here might be able to help on that.
Regards
Ed
| THard.co.uk | Xray | MuchMore |
Old 04-27-2005, 12:37 PM   #8436
ttso's Avatar
Default Inbound Toe
As my understanding, inbound toe will in fact affect axis-base length, which will change the weight transfer, result different driving characteristic.
1st assume lower a-arm is horizontally at downstop.
When you have inbound toe-in, your wheel axis will move backward when the suspension travel upward (compression)
When you have inbound toe-out, your wheel axis will move forward when suspension travel upward (compression)
So, if you have a fixed variable on all other setting. For rear suspension, increasing inbound toe-in will reduce weight transfer to back during accelration. For front suspension, increasing inbound toe-out will reduce weight transfer to front during braking.
The affect is similar to kick-up/anti-squat which will change axis-base length during suspension movement.
Please lemme know if I made any mistake...
ttso is offline   Reply With Quote
Old 04-27-2005, 12:57 PM   #8437
V12
V12's Avatar
Originally posted by TryHard
Racer;
Regards
Ed
This affects rollcenter. As with the instructions its the higher rollcenter the other way it´s lower rollcenter. I had the reversed version in the beginning with my EVO3 when I didn´t know there are two ways using the steering hubs. The reversed version gives more steering but also makes the car twitchy. Never went back to this however.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 04-27-2005, 12:57 PM   #8438
SCML's Avatar
That sounds logical to me. If this is infact the case, why does everyone like front inboard toe out? I have the MS, and biggest issues I have to over come is lack of steering on tighter tracks. If I run inboard toe out on the front, I'm decreasing the weight transfer to the front on corner entry, which would make the car push (which it already does). In fact, I'm coming to the conclusion that A/A blocks in the front are better than A/D or A/C for tight tracks, though this is only my experience. Since I have gone to inboard toe out on the front, I've found it harder to get the car to turn in and out of the corner, but I've kept it this way because it's what everyone says is better. I'm going to try going back to 0 or .5 deg toe out and see how it feels.
On the rear, having inboard toe in seems it would help keep weight on the front end for more on power steering. My own experience (though minimal back to back) is when I changed from the 0 deg rear hubs and 1.5 deg inboard toe in to 1.5 deg hubs and 0 inboard toe, the car had a lot more steering, everywhere. This is totally unscientific, as it was a different day, with different tires, etc., but I was very surprised at the difference.
Mike
SCML is offline   Reply With Quote
Old 04-27-2005, 01:23 PM   #8439
Trader Rating: 37 (100%+)
link is dead
might have been loading the pages up at the time..
this should work.
http://home.comcast.net/~anthony.isl...p_swaybar.html
Tryhard...you setscrew setup is nice.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 04-27-2005, 02:03 PM   #8440
TryHard's Avatar
Nexus, It's really easy to do, take a 3/32 drill bit, and four 3mm grub screws . took me about 10mins to do the car.
Old 04-27-2005, 02:09 PM   #8441
rtypec's Avatar
You can also use these along with the "twist". Blue Aluminum Collars Thanks to Jimmay-J for the find.
rtypec is offline   Reply With Quote
Old 04-27-2005, 02:22 PM   #8442
If anyone has any nice setups for specifics track and wants to post them please email them to me and I'll list it on my site.
nice site to find blue hardware...
i used red for the red swaybar. :P
Old 04-27-2005, 02:53 PM   #8443
koabich's Avatar
Send a message via Yahoo to koabich
Boy, that tape on the sway bar really looks like it will interfere badly with the swaybars up and down movement!
koabich is offline   Reply With Quote
Old 04-27-2005, 02:55 PM   #8444
With the shocks off and droop taken out the arms move freely as does the swaybar
Old 04-27-2005, 03:43 PM   #8445
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
Anybody run this motor before on 415 ?
its a 8X1 V2 team Orion motor.
whats the range of gear ratio for this motor?
KREATOR1 is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
