Old 04-20-2005, 09:00 PM   #8326
TryHard's Avatar
double post... bugger
| THard.co.uk | Xray | MuchMore |
Old 04-20-2005, 09:50 PM   #8327
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Originally posted by grahame
is that the option part for the xray T1FK05????
I believe that it was the battery bar for the FK04, if you wanted to run Side x Side packs instead of the std saddle packs. Have a look on XRay's website, you should be able to find them. We got ours from CMC in Australia as well.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 04-20-2005, 09:59 PM   #8328
have you seen the new battery strap for the t1fk05 looks like it would fit perfect
grahame is offline   Reply With Quote
Old 04-20-2005, 10:06 PM   #8329
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Re: RE: DROOP!
Originally posted by maxepower
Dave,
So how do you know what your actual droop is? I've adjusted my droop using this method in order to be consistant from side to side but don't you still have to measure from some other point to get a number you can compare it to or use as a start point? For example I run 4.5mm droop in the back and 4 mm in the front so if I wanted to decrease the droop 1mm will this be consistant with the numbers I am getting from the top of the wheel axle? I hope this makes sense!
Max V.
max... ill show you how to do it this way, remind me next time i see you.. a former national champion showed me (thanks mr. mike rydwell!) how to measure droop this way (how mr. david j. mentioned above) and its the most accurate (down to the .01mm if you like) way of doing it as long as your calipers arent all funky.
then you can set your tweak too.. (another former national champion showed me - thanks rod canare!)
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 04-20-2005, 10:07 PM   #8330
F. Alonso's Avatar
I can't really remember it. I have got no reason to get another battery strap though, this XRay one fits REALLY well.
Simon Feigl
Old 04-20-2005, 10:08 PM   #8331
Hebiki's Avatar
Default Sway Bars
Originally posted by David J.
Droop is one of those settings that somehow ends up being difficult to transfer from person to person because everyone seems to measure it differently. There is one method I have found to be the most consistent. This method uses the top of the wheel axle as the reference point. To set droop with this method, remove all four wheels and rest the chassis flat on your tweak board. Using a vernier caliper with a depth gauge, measure from the top of your wheels axle to the tweak board. This tends to eliminate error that would otherwise occur when changing anti-squat or anti-dive or even raising or lowering your suspension blocks. Regardless of what you adjust on your suspension, your droop reading will remain consistent this way. Its not 100% perfect because it can be affected if you make wild camber changes but for the most part its the least problematic.
David.. my question for you is.. do you detach your sway bars when you measure droop? someone mentioned that you should since a bent/tweaked sway bar might/will affect your droop settings? thanks!
good luck at reedy.
Hebiki Design Works
Old 04-20-2005, 10:15 PM   #8332
do you have a photo of the set up?????????
Old 04-20-2005, 10:22 PM   #8333
F. Alonso's Avatar
Not yet... I'm going to be taking photos of the car though soon. I'm sure that someone else may have photos of their car with either the Schumacher bar (also fits but has purple posts) or the XRay bar. Besercoe was the one who told me about the XRay bar so maybe ask him?? There was another guy on this forum who said that XRay bar was awesome too.
Simon Feigl
Old 04-20-2005, 10:33 PM   #8334
forty6's Avatar
forty6 is offline   Reply With Quote
Old 04-20-2005, 10:48 PM   #8335
F. Alonso's Avatar
Yeh.... that's about right.
Simon Feigl
Old 04-20-2005, 10:50 PM   #8336
Good work Forty6,
i found that you need tov take the knurled end apart, and slightly elongate the hole so that the bar does not have to have pressure on it, and therefore tweak the chassis. It is very neat, easy to use and has never lost a battery. The number one upgrade for a 415 IMO
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 04-20-2005, 11:01 PM   #8337
Originally posted by forty6
thats the xray one is it???
Old 04-20-2005, 11:03 PM   #8338
F. Alonso's Avatar
Yes it is and Besercoe is right, single best upgrade for 415!!!
Simon Feigl
Old 04-20-2005, 11:08 PM   #8339
just got one from CMC
thanks for all the info and sorry for the 500 questions
Old 04-20-2005, 11:44 PM   #8340
Burlap's Avatar
Send a message via MSN to Burlap
I got one, fits the car well, too bad about it not being blue anodised aluminium.
About not losing a battery since, well, some people seem to still be able to hit my car in the right spot to spit it out...
Burlap is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
