Old 04-15-2005, 09:03 AM   #8251
Originally posted by neosan
hi guys,
Is there a way to lock the oneway center pulley, or should I by a locked center pulley ? If I should buy, where can I find it ???
Look at www.speedtechrc.com they should have some in stock.
SCOTT HOWARD is offline   Reply With Quote
Old 04-15-2005, 09:38 AM   #8252
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
rainbow Ten should have some locked pulleys in stock.
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Savöx - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 04-15-2005, 11:06 AM   #8253
Trader Rating: 37 (100%+)
hi guys,
Probably too much work...
I believe you can drill a small hole in the pulleys and place a pin in place to "lock" the two in place.
A guy locally bought something like that and said it was a limited production run of locked center pulleys.
m8commando
if you ever need info on building a front diff checkout my link.
http://home.comcast.net/~anthony.isla/TRF_415/
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 04-15-2005, 11:29 AM   #8254
Anyone know of any TRF-415's kits around? I am looking for two more. New only.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 04-15-2005, 11:48 AM   #8255
Hebiki's Avatar
Trader Rating: 26 (100%+)
steve at speedtechrc has both in stock (reg. and MS)
http://www.speedtechrc.com/store/ebp...?catmainid=120
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 04-15-2005, 12:09 PM   #8256
maxepower's Avatar
Default MIP CVD's
Does anybody know what part #'s I need to change my front universals to MIP. I thought I read somewhere a ways back that this was do-able! I know Speedtech has MIP's in stock but he didn't know with what combo of part #'s to use! Any help would be appreciated!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 04-15-2005, 01:22 PM   #8257
TryHard's Avatar
hey guys,
Just going over my car today, getting setup for the weekend. Was changing the shock oil over, and noticed a slight dead spot on my shocks.
Took them apart and had a little look at the pistons. Anyway, they were fine, but there was a fair amount of movement between the piston and the 2 e-clips....
Solved it now by placing 1 0.1mm shim underneath the piston. Theres absolutely no dead spot now, shaft moves straight away
Just thought I'd let you know....
Later
Ed
| THard.co.uk | Xray | MuchMore |
Old 04-15-2005, 01:26 PM   #8258
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Insead of using shims We were told many years ago to bend the e clip slightly through the center to tighten them up. Basicly bending the two ends up. And installing them on both sides of the pistons.
tamiyarcracer is offline   Reply With Quote
Old 04-15-2005, 01:54 PM   #8259
V12
V12's Avatar
This weekend the Indoor Nationals in Germany are held in Dortmund at a big model exhibition, rubber racing on carpet. Will start tomorrow. Today there was something of a warmup race on the same track and from what I heard most of the drivers were there already.
Just read a message Marc Rheinard TQed and won the Modified class easily being the only on 26 laps.
Results:
1. Marc Rheinard - TRF415
2. Marc Fischer - Corally RDX
3. Benni Gröschel - HPI Pro4
4. Jilles Groskamp - Xray FK05
5. Patrick Gassauer - Yokomo BD or SDW
I´m not there but I hope there are some informations throughout the day. A live report was planned but had to be cancelled for any reason.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 04-15-2005, 02:21 PM   #8260
TryHard's Avatar
Tamiyaracer:
Thanks for the tip, I'll give a try next time i take my shocks apart... For now though, I'm happy with how the shims are working. Piston would still spin on the shaft, but the was no up/down play.
Old 04-15-2005, 03:28 PM   #8261
Arun's Avatar
Originally posted by TryHard
hey guys,
Later
Ed
Yes, it is a good idea to install the shim from the beginning, because even in the beginning there is play in this part. I make it so that the piston no longer can rotate on the shaft.
http://nexusracing.com
Arun is offline   Reply With Quote
Old 04-16-2005, 10:12 AM   #8262
Here is information for the after market belts.
Echo D5101F MDx Lowfriction belt for TRF415 front 640yen
Echo D5101R MDx Lowfriction belt for TRF415 rear 480yen
Rush RU-0021 High response front belt for TRF415 803yen
Rush RU-0022 High response rear belt for TRF415 548yen
Anyone tried any of these belts on their 415's what did you think?
Powered by Falco
Old 04-16-2005, 07:43 PM   #8263
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
after 5 months i just snap my stock rear belt yesterday.
seems the stock belt is also good and last .
KREATOR1 is offline   Reply With Quote
Old 04-16-2005, 11:36 PM   #8264
maxepower's Avatar
Default Re: MIP CVD's
Need some help here guys! No response to this thread!
I have some wheel hop with a spool. It causes the car to push when this happens. I've use anti-wear grease and kept a close eye on the wear of the joints but I think MIP's will help out a lot!
I know somebody has tried this, I just don't remember who? Thanks!!!
Old 04-17-2005, 04:28 AM   #8265
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
I had my first race meet with my new 415 (a week and a bit old) and I was very happy with its pace. Given that two of the best rubber racers in Australia were at the meet, my best laps were consistently around 0.4sec off theirs which I was fairly happy with. Their grip levels were just awesome though... to the point where you could simply HEAR the grip and the tyres squealing even at slow speeds. I don't know what they are doing to their tyres... but its just amazing!!
But yeh.... in a comparison between the 415 and the Evo IV in Modified, I'm quite content to say that the 415 is the superior car for that job.... and I feel that they would be fairly similiar in performance at stock and 19t also. Overall.... VERY happy with the 415. Only thing is.... my low friction belts haven't broken yet but I have a BIT of the belt thats kind of tearing away, like fine strands of it. Has anyone else had this?? I did the last final on that belt too and it worked out alright.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
