Old 04-11-2005, 11:59 AM   #8191
rcmaniax's Avatar
Default RC Maniax Spool
hi there
the first response about our spool was not so bad - so we think we'll produce a batch soon. the parts with a new light-weight design will be available in about 3 weeks. of course these parts will be blue anodized.
we're going to test a first prototype this weekend. this design needs the corally blades which fit perfectly! (weight 9.17 grams)
rcmaniax is offline   Reply With Quote
Old 04-11-2005, 12:32 PM   #8192
TryHard's Avatar
hey rcmaniax,
Just wonder, have you thought about putting the outdrive slots at 90deg to each other?
My heavyweight speedtech spool has them this way round. personally feel it puts the drive down smoother.
Regards
Ed
| THard.co.uk | Xray | MuchMore |
Old 04-11-2005, 01:12 PM   #8193
Hey Tryhard,
Do you have a good setup for the spool and old susp. with rubber tires and 19t?
cheerz
Obsidian is offline   Reply With Quote
Old 04-11-2005, 01:21 PM   #8194
how can i contact jurgan about the spool for the 415
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 04-11-2005, 01:45 PM   #8195
TryHard's Avatar
Originally posted by Obsidian
Hey Tryhard,
cheerz
The stew noble one on my site is good for that.
HiH
Ed
Old 04-11-2005, 02:00 PM   #8196
Trader Rating: 37 (100%+)
For those of you looking for more indepth info on building the front diff for the 415...
You can look at my website. The only link working now is the "Front Diff" link. I am finishing the pages now.
http://home.comcast.net/~anthony.isla/TRF_415/
If you have any images of your 415 that I could use in the gallery please feel free to email them to me.
[email protected]
thanks.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 04-11-2005, 03:01 PM   #8197
dawgmeat's Avatar
[email protected]
thanks.
you got mail
dawgmeat is offline   Reply With Quote
Old 04-11-2005, 03:03 PM   #8198
V12
V12's Avatar
just send you his address
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 04-11-2005, 04:39 PM   #8199
Originally posted by dawgmeat
you got mail
dawg.
got the pics...thanks.
I placed the link in my profile if anyone wants to see the site.
Any nice digital pics you have of your 415 you want placed in the gallery feel free to email me.
Old 04-11-2005, 05:30 PM   #8200
Burlap's Avatar
Send a message via MSN to Burlap
Originally posted by F. Alonso Dec....... you don't have the Evo IV rear uprights on the car otherwise they would definately state a number on them. I'd say that they were some aluminium rear uprights based on the older TA04 arms like what came on the original 415s and would most likely be 2 degrees still.
No, they are shaped like a Evo IV upright, since the 415 normal upright looks like a TA04. See the differences between the two on the Tryhard's page with the different setup sheet for the LW arms and the normal ones. The rear uprights on mine look like the LW ones.
I'll find out from Tom's setup board on Wednesday what toe it has on it anyway.
Burlap is offline   Reply With Quote
Old 04-11-2005, 10:20 PM   #8201
TRAJ's Avatar
TRAJ - Sure no problems mate. I'd just get 2mm worth of spacers on either side and then cut the wheel down a mm or so on either side, unless you ahve the 6mm hubs.
Tryhard - I'm running the kit tension at the moment which by memory is like pointing downwards. I think that you are right and I'll try to move it +1 or +2 around and see how it goes. Just wanted to make sure of that before I do it, cause theres a few screws to take out to do that change.
Thanks again ill give it a go
TRAJ is offline   Reply With Quote
Old 04-11-2005, 10:20 PM   #8202
TRAJ's Avatar
Most of these cars are designed with rubber tires in mind....which is what a majority of the world races. Pretty much only in the U.S. is the carpet racing scene big.
As people have stated....a quick fix might just be the 6mm hexes. They should solved your clearance problems without having to buy Pro4 knuckles and bearings.
If you have both the LW suspension and standard...try running the standard. 28mm foams fit fine with it.
Thanks Nexus ill try get my hands on the 6mm hex
Old 04-12-2005, 08:33 AM   #8203
Arun's Avatar
The problem with spacing it out so much is that it removes a lot of steering from the car. The LW suspension already has less throw than the standard suspension. This is why we went with the pro4 knuckles on carpet with foams.
http://nexusracing.com
Arun is offline   Reply With Quote
Old 04-12-2005, 08:36 AM   #8204
TRAJ's Avatar
Thanks for the info
Did you just change the front to the pro4 knuckles?
Thanks for the info again guys
Old 04-12-2005, 08:44 AM   #8205
Arun's Avatar
Thanks for the info
Yes, just the front knuckle. You need to use 4 5x10mm bearings and the axle from the old suspension. Then, to assemble, you must put a thin motor shim on the top and bottom of the knuckle.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
