Old 04-10-2005, 10:17 PM   #8161
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally posted by F. Alonso
Would anyone have a solution to high speed understeer?? The rest of the car seems to be handling pretty well and consistant. I'm using ALMOST the box settings from the MS but with XB, B on rear and A D on front. 1.5 degree camber, 4 deg castor. Also.... I'm running in Modified.
Cut down the size of your rear wing might help.
jeffreylin is offline   Reply With Quote
Old 04-11-2005, 01:40 AM   #8162
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
if you are running A / D blocks in the front (hinge pins toed in), this could cause a push. try going A / A and go from there.
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 04-11-2005, 04:04 AM   #8163
ttso's Avatar
I'm going to try spool next week. Any special behavior should I worry about on setting?
My current setting is with front 1-way, super steering on corner entry (deceleration steering) and a bit push on corner exit (acceleration steering).
ttso is offline   Reply With Quote
Old 04-11-2005, 04:13 AM   #8164
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Originally posted by KREATOR1
i wanna know too
Yes, the lightened hollow ones I bought for the Evo IV work fine and they were TA04 ones. Plus... they work on my new 415 too.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 04-11-2005, 04:15 AM   #8165
F. Alonso's Avatar
I'll try some of those suggestions. I like how the car is in the slower corners, really stable and is generally stable throughout... just it lacks initial corner entry speed. I will try a few things out with the toe settings. thanks for the suggestions guys.
Simon Feigl
Old 04-11-2005, 04:18 AM   #8166
TRAJ's Avatar
Originally posted by TRAJ
Hi guys
I dunno if this has been asked before but im having trouble with 26mm foams on the front they rub i was wondering what a solution to this is apart from getting larger wheel hexs? is there anyother way?
Its the Ms version
Any help is appreciated
Anyone??
TRAJ is offline   Reply With Quote
Old 04-11-2005, 04:21 AM   #8167
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
thanks
KREATOR1 is offline   Reply With Quote
Old 04-11-2005, 04:21 AM   #8168
F. Alonso's Avatar
There was a LOT of talk about it on the Evo IV forum a month or so ago. I used the Evo IV at the Summernats with the same type of suspension and I didn't really have any problems with it. I used 6mm hexes with it though but you could still just use 2mm worth of spacers on the front hexes to get the same effect. I also had to cut down the front wheels + rim by about a mm or so, that's the only thing that I really had to do.
Check out the Evo IV thread, your answer is there FOR SURE.... just it could take some time.
Simon Feigl
Old 04-11-2005, 04:34 AM   #8169
TryHard's Avatar
What are you currently running for the one way?
The only thing i realy adjust when switching from 1-way to spool was the front springs. Dropped from tamiya whites (1-way) to Tamiya blues (spool). Apart from that, everything else i kept the same.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 04-11-2005, 06:14 AM   #8170
Burlap's Avatar
Send a message via MSN to Burlap
I've given my 415 a big overhaul over the weekend. I've set it up with a layout another bloke has run at my track, with shocks angled the way he had them (a link to how he had his car setup here: http://members.iinet.net.au/~a.parre...ps/Boronia.gif ), put white springs on the front, blue at the back, and yellow stabiliser bars front and back.
Haven't checked toe or camber yet, as I'll check on a setup board this Wednesday. But I'll set the camber the same as what Tony did.
With rear toe I am keeping the blocks/bulkheads the same as what is in the Tamiya manual, 1Ds at the rear and 1C at the front for 0.5 toe in. However I do not know how much toe my rear uprights have since they are aluminium ones fashioned on the lightweight/Evo IV ones, and there is no number stamped on them for how much toe they give.
I am running 27 turn stock and trying to dial out some of the understeer it has. See how it goes Wednesday night.
EDIT: Tryhard your site rocks. Learnt so much about chassis setup from it, as well as tips from other friends.
Burlap is offline   Reply With Quote
Old 04-11-2005, 06:34 AM   #8171
ttso's Avatar
HiH
Ed
My setting right now is kind extreme...
Tamiya yellow spring F/R; AE35 F, AE50 R
Tamiya yellow roll bar F/R
Stock suspension
Shock on 2tower,1arm F; 4tower, 2arm R
3mm spacer F; 0mm spacer R; Droop 0F/3R
Toein -1F/3R; camber 0F/1.5R; Kickup 0F/1R
61mm JACO foam F/R; 1mm spacer on all 4 wheels
3mm chassis, double deck
I know this setting is kind strange but that works for me. I guess I probably doesn't need to change setting for spool if the only thing TryHard did is softer front, where mine is too soft already (extremely good steering on deceleration, probably too good indeed)
Btw, by using spool, should I go for center one-way? or keep using direct pulley?
Old 04-11-2005, 06:50 AM   #8172
ttso's Avatar
Btw, I did this little mod on my 415: additional belt stabilizer on chassis.
The goal is to free some space under the belt so I can put some weight right on CG to meet the rule. Also, kepp the rolling mass as light as possible for faster direction change, in theory.
But right now Novak SS5800 is kind overweight so I don't need to put any weight for rule. In fact it's 15g overweight still (with 70% of screws already Ti, lol )
Old 04-11-2005, 08:42 AM   #8173
haura415's Avatar
HI guys
I got a speedtech spool in my car,but when i turn left +right it have a massive cvd chatter, is it how can i fix it ,i have tried rdx cvd with pro4 axle it still doing it,please help?
haura415 is offline   Reply With Quote
Old 04-11-2005, 08:51 AM   #8174
check you don't have too much steering turned on. I had no probs with mine even on full lock.
ukmaxx is offline   Reply With Quote
Old 04-11-2005, 09:05 AM   #8175
haura415's Avatar
how much is too much only with 75% it still doing it are u using tamiya uni
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
