Old 04-09-2005, 11:25 AM   #8131
Default 415 Parts
Where are you guys buying parts from? I like to use Speedtech but they are usually out of the parts I need.
Charles is offline   Reply With Quote
Old 04-09-2005, 01:59 PM   #8132
TryHard's Avatar
I use two places, Speedtech as you mention, and also Rainbow Ten, over in japan (http://www.rainbowten.co.jp).
I do know there are others around (i have used stella models and precision Rc previously), and I'm sure others will let you know where too.
I personally find these two to have great prices, brilliant service, and speedy delivery (doubly useful in the UK, given there is a grand total of NOWT support for us 415 drivers )... usually depends on who has what i need when i comes to ordering
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 04-09-2005, 03:26 PM   #8133
dawgmeat's Avatar
Default Outdoor racing
Hey guys I need your help, unlike the west coast which runs nothing but outdoors, I live in carpet country USA" northeast" . Now my problem is that I have the Kai chassis which is super stiff, that all good for indoor racing but outdoor season starts next week at RCmaddness which will not be blistering hot, just one of nice days in Ct.. Now I have the LW conversion, can I make the Kia chassis work outdoor or do I need to go back to old chassis, which I don't want to
Carpet racing on Thrusday
Outdoor racing on Saturday
That a lot of wrechin'
Long term solution is to buy the 415ms, so can some one help me with a outdoor set-up for a stiff chassis, also the battery sits more inward and more fwd than the stock one
dawgmeat is offline   Reply With Quote
Old 04-09-2005, 04:42 PM   #8134
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Thumbs up New low height sus mount blocks..
Hey guys have a look at these....They are made by EOLGUL and they look to be the Hot item for you carpet guys .5mm lower in height than the standard 415 blocks and 2.5mm lower than the EVO3/4 blocks
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 04-09-2005, 04:42 PM   #8135
TryHard's Avatar
Dawg, i don't if the Kai chassis has them, but you could try removing the chassis posts, that should allow the chassis to flex a bit more.
I'm gonna be running my std 3mm chassis outdoor this season, with the lwt suspension. If I want more chassis flex, i'll just take the posts out. Something to try in practise.....
I know what you mean though, i did the carpet racing thursday, outdoor sunday last weekend. Of course didn't change the suspension over though.... except on sunday, when it only took 45mins to go from std suspension setup to Lwt, not bad I think
Dave, they look nice, any info on where to get them?
HiH
Ed
Old 04-09-2005, 05:17 PM   #8136
TRF Drive Hard's Avatar
Send a message via AIM to TRF Drive Hard Send a message via Yahoo to TRF Drive Hard
WOW who makes those???
TRF Drive Hard is offline   Reply With Quote
Old 04-09-2005, 05:38 PM   #8137
raving-monkey's Avatar
Send a message via MSN to raving-monkey
i know i don't own a 415 so i don't know why i'm in here but......Dave, if they are lower..wouldn't that just raise the rest of the car making the CoG higher?
edit: typo
raving-monkey is offline   Reply With Quote
Old 04-09-2005, 06:01 PM   #8138
dawgmeat's Avatar
HiH
Ed
thanks bud come to think of it, if the TC4 "graphite tub "can be good outdoors then so can my car
Old 04-09-2005, 06:01 PM   #8139
dawgmeat's Avatar
Old 04-09-2005, 06:16 PM   #8140
TryHard's Avatar
edit: typo
Hey matt,
Nope they don't.... they only lower the height of the suspension piviots.
Technincally, the car will still be in the same place, with regard to CoG, as this relates to ride height.
Ie for a given ride height, running thoose blocks would result in lower hinge pins.
Of course, to get the same ride height, the shock collars and droop screws would need to be adjusted....
HiH
Ed
Old 04-09-2005, 06:44 PM   #8141
ahh yeah i get you now.....i was thinking it would lower all the suspension (which in turn would raise everything else i think)
*slaps himself*
Old 04-09-2005, 06:53 PM   #8142
koabich's Avatar
Send a message via Yahoo to koabich
Default Re: 415 Parts
Walawala store on ebay has everything you will ever need!
koabich is offline   Reply With Quote
Old 04-10-2005, 12:26 AM   #8143
Arun's Avatar
Default Re: New low height sus mount blocks..
Originally posted by JDM_DOHC_SiR
[B]Hey guys have a look at these....They are made by EOLGUL and they look to be the Hot item for you carpet guys .5mm lower in height than the standard 415 blocks and 2.5mm lower than the EVO3/4 blocks
-Dave
Shouldn't it be 1.5mm lower than the evo blocks? I believe that the evo blocks are 1mm higher than the 415's.
http://nexusracing.com
Arun is offline   Reply With Quote
Old 04-10-2005, 12:39 AM   #8144
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
I thought the same.... but I've never heard of Dave being wrong about new items and details like that.
Anyway, on another note, I had my first run with the new car (415MS modded to SF-sped ) and I must say that I'm pretty happy with the car. There were some good names to compare myself to and I ended up only being around 1 sec per lap (~14-15sec laps) in terms of Best Lap compared to the front runners, who are 2 of the best drivers in the country. So..... I'm really quite happy with the performance and I know that I'll get there, just need time. Unfortunately, rain and 100kmg wind swept through before the finals started so I couldn't really compare my car VISUALLY to the other out there, but that's okay... I have a fair idea of where I'm losing ground. Mainly in just pace (gearing a 9x1 pretty conservatively) and also on my best run, I was suffering from a lot of turn-in understeer. The car was pretty stable aside from that intial understeer which was prodominantly high speed understeer. Its something that I'll have to tackle and work with the get the best out of the car, but considering I hadn't driven the car on the track before today, I was very happy with it.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 04-10-2005, 02:09 AM   #8145
paulc's Avatar
-Dave
Dave,
I'll be at Shin Yokohama from April 11 - 19, how about a tour or your tracks?
I'll be staying at the Shin Yokohama Prince Hotel
Paul
paulc is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
