Old 04-08-2005, 01:18 AM   #8101
Eirik's Avatar
Default RCMANIAX Spool
That spool looks outstanding and the weight really low!!
At the Carpet World Cup in Geneva I tried two different spools, one really light weight and one heavy, the light weight one gave me more steering and faster laptimes!!
The HPI Spool is also aluminum and with the right grease it will last a long time!! Just make sure to clean and relube frequently and it will be no problem....
Eirik is offline   Reply With Quote
Old 04-08-2005, 01:36 AM   #8102
JP
Why not ask them to make the axle slots just a little wider so we could use Corally blades. They fit right on and would work great.
JP is offline   Reply With Quote
Old 04-08-2005, 02:21 AM   #8103
rcmaniax's Avatar
good idea! no problem to implement that...!
do they fit on the trf axles? how thick are they?
thx
frank
rcmaniax is offline   Reply With Quote
Old 04-08-2005, 02:31 AM   #8104
KoE
KoE's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to KoE
quick help: what's the size of the diff balls? thanks
Yo!
KoE is offline   Reply With Quote
Old 04-08-2005, 02:42 AM   #8105
V12
V12's Avatar
@ rcmaniax
Yes from all existing blades the Corally ones fit the best on Tamiya driveshafts. Thickness is 3mm.
Are you coming to the Konstanz race this weekend? I can show you the Corally blades. They will go into my 415 for the Jürgen aluminium rear diff.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 04-08-2005, 02:44 AM   #8106
V12
V12's Avatar
3mm
Old 04-08-2005, 02:49 AM   #8107
KoE
KoE's Avatar
i've tried those corally blades on the outdrives and found 'em slightly over-sized to fit in snuggly. do i have to trim some material off?
thanks for the ball diff's size tho!
Yo!
Old 04-08-2005, 07:29 AM   #8108
Would anyone happen to know where I can get Rheinhards setup sheet from this past worlds down in kissimee? Thanks
RTolle is offline   Reply With Quote
Old 04-08-2005, 11:12 AM   #8109
TryHard's Avatar
I'm afraid to say that you won't find it....
Marc hardly ever notes down his setup, and given the number of non-tamiya parts he was running, i doubt tamiya would let him either.
I did try and do a best guess from pictures of the car, but given that it's impossible to see some parts of the car (f/r suspension block for example), and to figure out what angles are being run (toe, castor, camber, even droop), it missing a few vital details.
Also, unable to tell what was being run inside the shocks with regard to oil/pistons.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 04-08-2005, 11:21 AM   #8110
koabich's Avatar
Send a message via Yahoo to koabich
Isn't it also true that he didn't even set up his own car...he had mechanic from Tamiya do it? I think I read that he would run the car and tell the mechanic that he needs more steering or if it was loose and the mechanic would correct for it and not necessarily tell Marc what was done.
Just out of curosity, what patrs on the car were not from Tamiya?
HiH
Ed
koabich is offline   Reply With Quote
Old 04-08-2005, 11:28 AM   #8111
TryHard's Avatar
Thats apparently very true...
From what I heard, parts that weren't tamiya...
HPI: 0deg rear hubs, Silver springs
Alex racing: Gold Shock shafts, roll bars, and some internal shock components (bladders I think)
Also the TiR Spool
Admitadlly not as bad as some competitiors may have been, but still enough parts to possibly question the performance of tamiyas own stuff (in the eyes of some consumers maybe)
Actually I've just been studying the pics of the car closely again (got some good high res piccys), and theres a few interesting things on there.
Ie, only 1mm of shim under the front camber link, and 2 under the rear (compared to 4 and 1 on the stock lwt suspension), also the rear link is on the innermost hole on the rear hubs (the HPI ones are very similar to the tamiya ones)
Also shock positions are quite laid down (hole 1 on the front and 3 on the rear), and it looks like quite a lot of droop was run, as there is a fair amount of screw protruding from the top of the wishbones....
On another point, I have a suspescion that the car had 35wt oil in the front shocks, with 40wt in the rear as there is faded writing with these numbers on the relative shocks.
Still, I guess this is something we may never know for sure, shame.
Old 04-08-2005, 11:52 AM   #8112
koabich's Avatar
Also the TiR Spool
Cool...thanks!!
Old 04-08-2005, 12:21 PM   #8113
Arun's Avatar
Default Re: RCMANIAX Spool
Well, I have made 3 spools so far:
The first one is basically a locked one-way similar to the tamiyaUSA spools that were made last year. I used the short style outdrives from the LW kit. It weighs .9oz/23grams.
The other two are locked yokomo diffs using double-sided sandpaper instead of diff rings, with no balls or thrust bearing. The steel weighs 1.1oz/29grams, while the plastic one is a very light .4oz/12grams! I will probably not use the steel one, because it is heavier than the locked one way, and does not have a tight tolerance on the driveshaft pin.
I actually think that a plastic yokomo diff may work well, even in mod, because it is pretty stiff in construction. It is also narrow (like the LW sus one-way), so it gives less of a driveshaft angle at full lock, which should reduce cvd chatter.
Fernando has one of the spools like Marc used at the worlds, and the white outdrives are actually very flexible---comparable to nylon. They are not the high quality of delrin that we are used to seeing in the tamiya diffs. I am going to test the plastic yokomo spool tomorrow, with modifieds.
thx
frank
Maybe you should contact TamiyaUSA and see if they will promote your spool on their TRF Race Center page.
http://nexusracing.com
Arun is offline   Reply With Quote
Old 04-08-2005, 01:00 PM   #8114
rcmaniax's Avatar
Default Re: Re: RCMANIAX Spool
We're not a big company - just 4 swiss guys producing our own parts for racers all over the world... we're only able to produce a small batch of our parts, thats why they are available only for a short time...
We're all engineers - so designing rc parts is a pleasure, if there are some good ideas please let us know. We already made some chassis design for a big rc company...
But I think tamiyaUSA is some numbers to big for us....
By the way, we just released a carbonkit for the TRF415 for a very good price
Hi from Switzerland,
RC MANIAX
Old 04-08-2005, 01:46 PM   #8115
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
What parts are those besides transponderholder?
They look awsome though
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Savöx - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
