Old 03-23-2005, 10:57 AM   #7951
koabich's Avatar
Send a message via Yahoo to koabich
I have yet to break a front A-Arm on the standard 415 (with no extra protection) and I hit the boards as hard and as often as anyone. I have hit hard enough to bend several hinge pin mounts but I have never broken an arm.
Originally posted by Nexus
tryhard - nice setup!
If that's the case I would probably stick with the Stratus 1, 2, or new 3.0 style bodies.
Has anyone tried to mount an additional rigid plastic type bumper under the foam bumper of their 415s?
With Pro4s we were putting BRP wide bumpers so that the rigid bumper extends to cover the front arms. The 415 foam and bumper mount seem ok but racing indoors it's nicer to have something wider.
koabich is offline   Reply With Quote
Old 03-23-2005, 10:59 AM   #7952
Ill Factor's Avatar
Default 415 Batt Strap
Kai747 where did you get that battery strap?
Ill Factor is offline   Reply With Quote
Old 03-23-2005, 11:04 AM   #7953
SCML's Avatar
Speaking of which... I broke my first part last night, or well, it was broken for me, without my prior consent....
Right front arm cracked, outer hinge pin very bent, about 10 deg caster on that side, didn't handle very well. Stayed together though, but now finding parts..... This was on the MS though.
Thanks for the info on your fan setup Ed. I'm a little worried about the fans I have burning up on 7-8v direct from the battery. One blew up while testing it on a discharged pack... I guess I'll just look for a higher quality fan, and the run a switch to the battery wires so I can control the fan.
Mike
SCML is offline   Reply With Quote
Old 03-23-2005, 12:22 PM   #7954
Trader Rating: 37 (100%+)
Will this part fit the stock 415?
http://www.speedtechrc.com/store/ebp...id=245&id=1710
If so...what's the difference between that and this...
http://www.speedtechrc.com/store/ebp...id=245&id=1714
Is the lower link the rear hubs that have toe built in and the first link the rear hub with 0deg rear toe?
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 03-23-2005, 12:35 PM   #7955
TryHard's Avatar
Mike
No prob, I'm not sure on the fans i haver, but they have a 5v rating on them... I doubt the extra 2v is gonna harm them (nothing happend yet, and i've been playing with them for most of the afternoon). I don't know if i mentioned it, but these are rated at 0.08a @ 5v, which i think is pretty low, given what our motors pull at....
Later
Ed
| THard.co.uk | Xray | MuchMore |
Old 03-23-2005, 12:36 PM   #7956
SCML's Avatar
I believe they are the same thing, except one is made of extra hard, no flex material. I know they will not work with the light weight suspension on the MS, but I'm not sure about the standard 415 arms. I think they would fit, the TA04 uses the same arms I think.
Mike
Old 03-23-2005, 12:38 PM   #7957
TryHard's Avatar
The first one is the optional 1deg rear hubs, I currently have them on my std suspension, so yes they will fit
The only difference between the two is the Toe-in rear uprights (your 2nd link, and std fitment on the std 415) are 2deg toe in hubs, which whilst running stock, I'm finding to be a little excessive...
Basically, the 1 deg ones give you more scope for tuning lower amounts of toe on the rear. The lowest you can really go on the stock hubs is 2deg, without sweeping the arms back.
HiH
Ed
Old 03-23-2005, 01:14 PM   #7958
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
Mike
this is correct... the one set is the hard pair, which came on the 414/415 Standard series, the other set is the regular soft plastic set, which is a Hop-Up option on the TA04 series cars... either will work, but as the typical Tamiya rear hub, you will probably have to file/sand them to fit.... they will both be 2 degree...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 03-23-2005, 01:32 PM   #7959
TryHard's Avatar
I'm pretty sure the hard set is 1deg, and the toe in set 2deg.
Ed
Old 03-23-2005, 02:44 PM   #7960
TRF415boy's Avatar
Ed
I back this up, as I've had the first set on my TRF 414, and there were only 1 hubs at this time (and they are made of graphite reinforced plastic). The second one is the one given with the TRF 415 (look at the back you your instruction manual) and this is 2.
TRF415boy is offline   Reply With Quote
Old 03-23-2005, 03:14 PM   #7961
Turbonium's Avatar
uh.. ok.
Wes
Team Novak
Old 03-23-2005, 06:41 PM   #7962
fire929's Avatar
Default Some thread ago
415 owners complained of diff rebuilds every 3to4 runs has anyone had this problem or figured out why it happens.?????????
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
fire929 is offline   Reply With Quote
Old 03-23-2005, 06:48 PM   #7963
jeffreylin's Avatar
R/C Tech Charter Subscriber
Default Re: Some thread ago
why was never a question. the diff is exposed as opposed to enclosed like the eveo4.
jeffreylin is offline   Reply With Quote
Old 03-23-2005, 09:04 PM   #7964
Trader Rating: 23 (100%+)
IMO, the gritty feeling is from thrust. I believe that the thrust units' balls are too small to work with the debris that get caught up in the diff half.
I usually run low-turn motors; if it was the rings - it would show there. Usually, a good cleaning of the thrust assembly will bring some life back to the diff.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 03-23-2005, 11:21 PM   #7965
Arun's Avatar
"Investing" in a decent set of diff balls goes a long way...both the tamiya tungsten carbide and the xenon ceramic perform and last. I can get maybe 10 good runs out of the stock tamiya (LW) diff balls.
http://nexusracing.com
Arun is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
