Old 03-18-2005, 12:45 PM   #7891
rtypec's Avatar
Max, 190mm is width. There are Roar and Ifmar rules on how to measure roof and wing heights. And the methods to measure them can vary from race to race. If I remember correctly, last year's Reedy race followed Ifmar height rules. The body on the chassis, ready to race, must be a minimum of 115mm and the wing must be a maximum of 115mm. I don't know how they are going to do it this year...
rtypec is offline   Reply With Quote
Old 03-18-2005, 12:46 PM   #7892
SCML's Avatar
Default Re: Question on ROAR Rules?
Originally posted by maxepower
I'm trying to set-up my body and my (415)chassis weight of the car. I believe the weight is under and the body is too high.
I have the rules but can't figure what the height of the top of the body and the wing should be. I'd like to make a fixture to try and set the propere height but the height amount doesn't seem correct.
I say the height or dimension "C" is 190 mm. I dont think that right. Can somebody clear things up for me. Try to prepare for Reedy if I can get in!
190mm is the maximum height with 20mm blocks under the chassis. Presumably, this is to avoid ride height affecting overall height measurement. If you don't have 20 mm blocks.... get some?
415 is under weight when built, by it seems like about 40 grams with pretty light electronics. More if you use Ultra light stuff like the small servo, QC2, and a 2 channel reciever. Min weight is 1525 grams, with body. Try to weigh you car (corner wieght) wihtout shocks to get a static reading, then add weight where it makes sense.
Is Reedy using ROAR Rules?
Mike
SCML is offline   Reply With Quote
Old 03-18-2005, 01:06 PM   #7893
SCML's Avatar
Yea... looks like ROAR's rule book is attempting to use IFMAR rules for 1/10 TC, but the IFMAR rules read differently.
IFMAR, as Rod stated, is 115mm min, 175mm max height ready to race, and the wing can only be 115mm max. Minimum ride height is 5mm.
Weight is 1500 g for 4wd, not 1525 g. Gotta love rule books... Good news, 3 less squares of lead to stick on.
Mike
Old 03-18-2005, 01:29 PM   #7894
rtypec's Avatar
Keep in mind about the 5mm ride height.
"*Ground clearance -for use on carpet and other surfaces which could be damaged."
Good thing, because currently my car is at around 4mm hehe
Old 03-18-2005, 02:53 PM   #7895
Trader Rating: 37 (100%+)
For those that run foams...or...just have an answer.
Are you running longer/different ballend things on the end of the piston rod to get more extension?
It looks like running foams with the stock suspension should be no problem but with low cut foam tires it seem the shock does not extend out far enough.
**edit**
found some pro4 parts and this part(s) work real well. they fit nice and snug on the ballhead and give you a little more length.
on the right part #73510
#8 or #3 on that parts tree.
http://hpiracing.com/graphics/instr/.../Pro4_pg07.jpg
I also read before there was discussion on which foams fit the best on the 415 hexes.
Using Parma's they fit the hexes but seem to be wobbly until you tighten them down......Is anyone using TRC, TM, or another brand that might fit more snug?
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 03-18-2005, 05:05 PM   #7896
Ill Factor's Avatar
Default Setup
I think someone asked for a possible set up on asphalt. the set up I am using is mostly box stock instead of yellow sways I chose red.
40wt oil 2 hole piston
Shock length 62mm
Droop front 1.5
Droop Back 2.0
Camber front 1 deg
Camber Back 2
0 Toe front
2.5 Back
Ride height front 5mm/Back 5.5mm
Mazda 6 body
Not to different but seems to work very well on meduim grip aspahlt. We use CS27 tires for the entire class which is 19t.
Hope this helps some of you
Ill Factor is offline   Reply With Quote
Old 03-19-2005, 09:58 AM   #7897
Where can I buy a Titanium Racing spool for 415????
Hugo is offline   Reply With Quote
Old 03-19-2005, 01:28 PM   #7898
i was poss thinking about making a spool out of my oneway in my 415ms any suggestions on the best way to do this.
Bryan D is offline   Reply With Quote
Old 03-19-2005, 01:34 PM   #7899
glue the out drives of the one way together,works well,
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 03-19-2005, 03:13 PM   #7900
Customworksking's Avatar
Trader Rating: 73 (100%+)
i have a spool from Jurgen for sale
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 03-20-2005, 05:11 AM   #7901
dawgmeat's Avatar
Default 415 warriors
I've have seen the light, all this talk about the 415 or 415ms on carpet Bah, Bah, Bah. Fernado is slicin' some serious carpet with pretty much stock 415"""""""""""MS"""""""""", so for those people second guessing their 415's. You can and you will beat the enemy, I demand it. I will try best to post the results and set-up 2day
dawgmeat is offline   Reply With Quote
Old 03-20-2005, 12:30 PM   #7902
Default Re: 415 warriors
It's awesome to see a 415 in the show at a foam race.
I mainly race carpet and after recieving my 415 I don't see any reason why the car wouldn't be great....it has a stiff chassis, nice drive train, and a lot of adjustability.
IMO...the only reason you haven't seen more Tamiya's at big carpet races is because most of the 'team/sponsored' guys run out West or in areas where asphault racing is king.
dawgmeat - are you racing the event also?
Old 03-20-2005, 03:35 PM   #7903
red robinhood's Avatar
fernando was bumped down cause the evil forces ,,,,matt francis ..trinity ...its all good he proved a point .give him good s,,t to run and he will and has delivered ,he said the car was ballistic he got it to work big time ..the motor was crazy fast .well his proven what no one else has the car works on carpet with foams .well done fernando i will post his setup next week
red robinhood is offline   Reply With Quote
Old 03-20-2005, 03:55 PM   #7904
Was he bumped out because of the brushless motor?
That's too bad if so....if you get the setup that would be awesome as well.
Congrats to him for doing that well. If you can't get his setup maybe they will eventually post it on the TRF Racing page on tamiya's website.
* edit *
found out he got bumped because an error in the timing system counting Matt Francis' laps....either way...great job to see a Tamiya up front.
Old 03-20-2005, 08:11 PM   #7905
raffaelli's Avatar
Fernando was not bumped down. He never had the position to begin with.
He was a rocket though...
24ITA
raffaelli is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
