Old 03-16-2005, 12:12 PM   #7846
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Originally posted by Nexus
using the stock suspension...
which swing shafts do you use... 42 or 46mm?
just trying to figure out the combo of swing shaft and wheel axle to run the stock suspension.
Not sure that this is the answer you want but i run 42mm swingshafts with the stock suspension.
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Savx - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 03-16-2005, 12:13 PM   #7847
TRF415boy's Avatar
Default Re: Re: Spool
Originally posted by madjack
yes that was my understanding (TiRacing)
That was only at the worlds, I think I read earlier here that he's now using one of Jurgen's spools.
TRF415boy is offline   Reply With Quote
Old 03-16-2005, 12:29 PM   #7848
I've got a picture from TITC and it looks like he uses the TIR one, or a similar one with the delrin cups.
I'm wondering if an other brand produce a spool for 415 with delrin cups.
Hugo is offline   Reply With Quote
Old 03-16-2005, 12:45 PM   #7849
Trader Rating: 37 (100%+)
is that 42mm all around?
i noticed there are shorter and longer wheel axles also.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is online now   Reply With Quote
Old 03-16-2005, 01:03 PM   #7850
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
Nexus, the regular suspension uses 42mm all around with the axles that have kind of a square machine cut.... the liteweight uses the 46mm all around with the rounder machining... kinda hard to explain, but if you have the axles next to each other, its easier to see...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 03-16-2005, 01:27 PM   #7851
42mm...thanks...i'll bring the car to the track today to figure it all out.
Old 03-16-2005, 03:42 PM   #7852
KDagh1's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to KDagh1 Send a message via MSN to KDagh1
Can you use Kimbrough 64 pitch spur gears on the 415 without modification? Do the holes line up etc.?
KDagh1 is offline   Reply With Quote
Old 03-16-2005, 04:42 PM   #7853
stonedgti's Avatar
Trader Rating: 15 (100%+)
yes
you won't have problems with the Kimbroughs
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 03-16-2005, 04:45 PM   #7854
I read a couple of pages back that you can fit a pro4 spool in a 415ms , Is this a straight forward fit ?? Can anyone supply a picture.
Thanks in advance
Bryan D is offline   Reply With Quote
Old 03-16-2005, 04:51 PM   #7855
Thanks in advance
Old 03-16-2005, 04:58 PM   #7856
SCML's Avatar
Never heard this. There are a couple of options for spools, Speedtech makes one, though he may not have stock at the moment. There is also a machinist in Germany named Jurgen that makes some nice alum spools. Just search for Jurgen and you should find it in this thread.
Mike
SCML is offline   Reply With Quote
Old 03-16-2005, 07:38 PM   #7857
Ill Factor's Avatar
Default 415MS
Is the Mid deck on the MS 3mm or 2.5?
Ill Factor is offline   Reply With Quote
Old 03-16-2005, 11:04 PM   #7858
tried it out......doesn't fit.
have to use 42mm in back and 46mm up front on the stock suspension 415.
if i use 42mm ones up front they barely go into the oneway outdrive........is that strange or do i have something setup wrong?
Old 03-16-2005, 11:47 PM   #7859
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Re: 415MS
edit. nevermind.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 03-17-2005, 06:56 AM   #7860
koabich's Avatar
Send a message via Yahoo to koabich
Sounds like you do not have something assembled correctly. 42mm, when using all stock 415 components fit perfectly. Actually in this case 46mm would be way too long.
koabich is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
