Old 03-15-2005, 11:25 AM   #7831
SCML's Avatar
Pics of both towers can be found on page 214 - http://www.rctech.net/forum/showthre...pagenumber=214
I think rtypec (Rod Canare) posted his base setup for the Tamiya track somewhere in this thread. I would start there, Rod should know that track pretty well.
Mike
SCML is offline   Reply With Quote
Old 03-15-2005, 11:26 AM   #7832
maxepower's Avatar
Default 415 set-up
Originally posted by Obsidian
greetings
I am planning to go to the Reedy race in may, and was wonder if anyone has a good base set up for 19t I can try on my 415 (not MS)... i.e. Spool, front diff, oneway?, oil, shock positions.
There are several set-up in this thread, you'll just have to go back quite a few to find them! This also depends on your driving style!
The difference in the towers is there is one more hole from shock alignment compared to the original tower. Some racers just drilled another hole in their original.
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 03-15-2005, 11:28 AM   #7833
TryHard's Avatar
greetings
What is the difference b/t the 415 shock towers and the 415MS shock towers?
I did a comparison on this a while back.
For the front tower, the holes are about 1mm wider, and also about 0.5mm lower.
Also, you lose the 5th body post holes, and the extra camber link holes.
On the rear tower, there are two differences
1) the extra 5th hole on the outside
2) all the holes are around 1mm lower
Also the rear body posts are lower, and you lose the extra camber link holes.
HiH
Ed
EDIT - Beaten to it.... check SCML's post.
| THard.co.uk | Xray | MuchMore |
Old 03-15-2005, 11:32 AM   #7834
rtypec's Avatar
To save search time, here's the standard 415 setup that I used last year. There are a number of good setups posted in this thread and I believe Mr 19T Champ Charlie would have one as well.
rtypec is offline   Reply With Quote
Old 03-15-2005, 11:35 AM   #7835
TryHard's Avatar
Default Re: 415 set-up
I've done this too now.
Took my MS tower, bolted it to the std one in the position 4 holes, then whipped out my dremmel and a 3mm drill bit, and hey presto!
I've found that with the std suspension, it's difficult to get low enough rear ride height with an MS tower, especially if using the alloy shock collars.
Originally I went back to the std plastic collars, but i really really don't like them.
So i drilled the 5th hole in my std tower, put the alloy collars back on, and mounted the std tower (I had to lengthen the shock again too, to get the right droop level).
HiH
Ed
Old 03-15-2005, 11:39 AM   #7836
Ill Factor's Avatar
greetings
You are only allowed to run regular diffs @ the Reedy race so no need to experiment playa.
Ill Factor is offline   Reply With Quote
Old 03-15-2005, 01:55 PM   #7837
koabich's Avatar
Send a message via Yahoo to koabich
I thought you could run either a front diff or a front spool? You are not allowed to run a one-way.
koabich is offline   Reply With Quote
Old 03-15-2005, 02:07 PM   #7838
Ill Factor's Avatar
I stand corrected. It says that must be four wheel drive and 4 wheel braking.
Old 03-15-2005, 03:11 PM   #7839
Thanks to everyone for their input.
Obsidian is offline   Reply With Quote
Old 03-15-2005, 04:30 PM   #7840
Trader Rating: 37 (100%+)
Just got one of these 415s with the stock and LW suspension.
Can't wait to test it on carpet/rubber tires!
The stock chassis seems very stiff compared to my Pro4 chassis....which is nice since I run a newer ozite carpet.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 03-15-2005, 06:44 PM   #7841
Default center pulley
just wondering how the locked/center pulley affects the car?
bama is offline   Reply With Quote
Old 03-15-2005, 07:31 PM   #7842
dawgmeat's Avatar
Default 415 on carpet
just came back from open practice at the National, car was good in the end I will be there again for open practice
dawgmeat is offline   Reply With Quote
Old 03-16-2005, 11:54 AM   #7843
Default Spool
Does anyone know if M.Rheinardt is using the Titanium Racing spool or an other one?
Any help will be appreciate.
Bye
Hugo is offline   Reply With Quote
Old 03-16-2005, 12:07 PM   #7844
using the stock suspension...
which swing shafts do you use... 42 or 46mm?
just trying to figure out the combo of swing shaft and wheel axle to run the stock suspension.
Old 03-16-2005, 12:09 PM   #7845
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Default Re: Spool
Bye
yes that was my understanding (TiRacing)
madjack is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
