Old 03-15-2005, 12:42 AM   #7816
Question to the guys who use jurgen's spool:
Do you use the 42 or 46 shaft with jurgen's spool?
I had a race on sunday, I used brand new corally blades but at the end of the race they were worn out. After 10 runs.
The ones given with the spool were broken after 2 runs.
Hugo is offline   Reply With Quote
Old 03-15-2005, 12:46 AM   #7817
Default Rheinardt's spool
Does anyone know where I can buy the spool used by Rheinardt?
Old 03-15-2005, 01:15 AM   #7818
SCML's Avatar
Originally posted by jeffreylin
Yeah, I understand the numbness symptom. It seems that no matter what you do, you cannot get the car to work right. It's a well know problem among RC enthusiasts. it's also know as newchassisitis. The only known effective cure is to buy a new chassis. If that is not an option, purchasing some expensive hop ups for your current chassis or rebuilding it from the ground up will temporary suppress the symptom, but only a brand new car will provide long term relief.
Hahaha, nice Jeffrey!
Rafaelli, make sure you let us know what brand was the answer, you've got a nice setup for sale
Mike
SCML is offline   Reply With Quote
Old 03-15-2005, 02:50 AM   #7819
TRF415boy's Avatar
Default Re: Rheinardt's spool
Easy answer : just don't, unless you run stock. Too fragile.
TRF415boy is offline   Reply With Quote
Old 03-15-2005, 03:10 AM   #7820
Default Re: Re: Rheinardt's spool
I know but I want to try it.
Any info about the place I can buy it?
Old 03-15-2005, 03:22 AM   #7821
T-man
Guest
Posts: n/a
To fragile?? I understood that Marc R. was running the Jurgen spool at the worlds and that it went perfectly. using it myself and it is as 'hard' as it can get.
Marc
Old 03-15-2005, 03:24 AM   #7822
T-man
Guest
Posts: n/a
Default Re: Re: Re: Rheinardt's spool
Hugo, send me a mail and I will check Jurgens email for you.
Marc
Old 03-15-2005, 05:13 AM   #7823
raffaelli's Avatar
Originally posted by C_O_jones
Someone PLEASE BUY raffaelli's 415.
I realy enjoy reading these posts,BUT after working all day and then coming home to the wife I get more than my share of WHYYYNING.
PLEASE OH!! PLEASE
Fred
LOLOLOL
please please please buy it......
24ITA
raffaelli is offline   Reply With Quote
Old 03-15-2005, 06:02 AM   #7824
Marc
Marc ran a alloy spool with plastic outdrives.
Rick Draper is offline   Reply With Quote
Old 03-15-2005, 06:06 AM   #7825
TryHard's Avatar
Default Re: Re: Re: Re: Rheinardt's spool
I thought it was a prototype TiR spool, with delrin outdrives.... One of these broke in qualy, so they switched to using alloy outdrives instead.
| THard.co.uk | Xray | MuchMore |
Old 03-15-2005, 06:25 AM   #7826
T-man
Guest
Posts: n/a
Titanium Racing? Okay, then I am misinformed. To be honest I wanted the TiR version (due to the delrin outdrives) but after some vague contact I decided to go with the Jurgen Spool (which is a pleasure to drive with).
Old 03-15-2005, 10:25 AM   #7827
over gear's Avatar
Trader Rating: 15 (100%+)
Jeff, my 415MS is supposed to be the brand new car that provide the long term relief...
over gear is offline   Reply With Quote
Old 03-15-2005, 10:44 AM   #7828
SCML's Avatar
Over Gear, I think Jeff was aiming that more at Rafaelli than you.
How far from the box stock setup have you gone? I've found the stock setup pretty good, and if all else fails, go back to that and start over.
The track at So Cal right now is pretty tight, and on Saturday I was pushing a lot, having trouble with turn in. I changed to the locked center pulley (though I'm not sure how much affect this has), and went to 1.5 rear toe in, plus setup with -2.5 rear camber, and -3.0 front camber, and about 1/2 toe in. The only other thing that is not stock setup is 3 hole pistons and 35wt Losi oil (which I was running before). The car was much quicker, turned in a lot better, and had more steering overall.
I'm planning on coming out to Tamiya a few weekends starting on the 26th, maybe we can hook up and compare notes.
Mike
Old 03-15-2005, 11:09 AM   #7829
greetings
What is the difference b/t the 415 shock towers and the 415MS shock towers?
Obsidian is offline   Reply With Quote
Old 03-15-2005, 11:12 AM   #7830
greetings
I am planning to go to the Reedy race in may, and was wonder if anyone has a good base set up for 19t I can try on my 415 (not MS)... i.e. Spool, front diff, oneway?, oil, shock positions.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
