Old 03-14-2005, 01:06 AM   #7786
over gear's Avatar
Trader Rating: 15 (100%+)
Default Need more turn-in
I have been testing the 415MS at the Tamiya track for a couple of times... the car seems to have a MAJOR push into corners... the mid corner steering is good with the C/A front bridge combo....
How to get more initial turn-in? I'm running 19T motor with sorex 36R tires. the car is on the stock setup except the C/A front combo, red front and rear swaybar and I put the front shock to the outter hole on the shock tower to get more steering...
over gear is offline   Reply With Quote
Old 03-14-2005, 01:08 AM   #7787
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Need more turn-in
Have you tried the 2 deg c-hubs yet..???
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 03-14-2005, 01:41 AM   #7788
stonedgti's Avatar
You might want to try 1x and 1a blocks on the rear of the car.
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 03-14-2005, 04:24 AM   #7789
dawgmeat's Avatar
Originally posted by raffaelli
Guess I must be. I had to take the shims from my Mugen clutches to get ti right.
Hey Stan...how much money you have into it to get it to work?
Good luck guys, I am done with this car.
wow, not as much as you think, but then again no matter car you buy your going to put money into
dawgmeat is offline   Reply With Quote
Old 03-14-2005, 04:29 AM   #7790
Trader Rating: 74 (100%+)
Post
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 03-14-2005, 06:29 AM   #7791
dawgmeat's Avatar
Default Re: No Shims
Originally posted by SCML
Come on Rafaelli, this car works very well. I sense an underlying tone of recent losses to a different brand which could be causing your frustration with the car.
I've raced this car 4 times now, and practiced a few days, and it's got a record of 3 wins and a second in Sportsman at So Cal raceway. That class contains some pretty good talent. Mine is a MS with box stock setup!
I just took the box stock setup off, and installed the 0 deg rear hubs, and did a few other things, and I had 0 washers keeping the stock rear hubs from moving in and out, no problems at all.
The only weak spot on this that I have found is the hub bearings. When I pulled everything apart today, one of them was crunchy, still not that bad.
Go buy brand X car that is beating you, I'm sure you will feel better.
Mike
Hey Raul Garcia, does this apply to you? Tamiya was good enough for you to beat the local guys, but as soon as somebody took you behind the shed now the Tamiya not good enough, you better stay away from RC madness you might go through every touring they make
good luck this weekend
Old 03-14-2005, 08:40 AM   #7792
rtypec's Avatar
Lately, Sorex 36Rs (with the Hara medium insert ) are a little out of range as far as tire compounds go. Takes a couple of laps to come up to temp and will push while doing so.
Try increasing downtravel in the rear. This will allow more weight to transfer forward when you initiate a turn. Also try moving the rear shocks to the outter holes on the shock tower.
rtypec is offline   Reply With Quote
Old 03-14-2005, 09:00 AM   #7793
KDagh1's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to KDagh1 Send a message via MSN to KDagh1
Where do you buy an aluminum Juergen front diff from?
KDagh1 is offline   Reply With Quote
Old 03-14-2005, 09:56 AM   #7794
koabich's Avatar
Send a message via Yahoo to koabich
Jurgen can be reached at this email: [email protected].
Make sure to buy some Corally Blades!!
koabich is offline   Reply With Quote
Old 03-14-2005, 10:28 AM   #7795
TRF415boy's Avatar
If you did that on the front shock tower, then you are wrong, it will give you less turn in, you should try the shocks on the second inner hole on the shock tower, try also using less spacers under the front turnbuckle (more angled turnbuckle), and more rear droop (aswell as the most upright position for the rear shocks). You could also try 1.5 rear toe as you're running 19T.
TRF415boy is offline   Reply With Quote
Old 03-14-2005, 11:12 AM   #7796
KDagh1's Avatar
Koabich,
Thanks for the tip. I just sent Juergen a note. BTW, with the Juergen front diff, do you have to buy any other parts to make it work (i.e. thrust bearing, balls, rings)?
How much do these run?
Old 03-14-2005, 11:18 AM   #7797
over gear's Avatar
Default Re: Re: Need more turn-in
thanks everyone for the reply!
I have tried using the inner hole on the front shock tower so that the rear is more "stand up" than the front. but to my surprise, it's even more PUSH! i stand up the front and i get more steering this suspension thing is black magic to me...
Old 03-14-2005, 11:28 AM   #7798
jeffreylin's Avatar
Default Re: Re: Re: Need more turn-in
I think you guys are talking about different kind of push. Standing the shocks in front up will give you quicker turn-in but less steering mid corner and exit, whereas laying the front shocks down will do the opposite and hold the turn better around the corner.
jeffreylin is offline   Reply With Quote
Old 03-14-2005, 11:38 AM   #7799
TRF415boy's Avatar
Default Re: Re: Re: Re: Need more turn-in
Nope he did say that the mid corner steering was good and that it was entering the corner that was the problem.
Old 03-14-2005, 11:42 AM   #7800
jeffreylin's Avatar
Default Re: Re: Re: Re: Re: Need more turn-in
Then it's true. As I said, standing the shocks up will give you more steering entering the corner than laying the shocks down.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
