Old 03-07-2005, 07:57 PM   #7711
TryHard's Avatar
Originally posted by Burlap
I'll be getting a standard 415 second hand this week. What are the main differences between the two cars (I race ashphalt) and can I hop the standard 415 up to MS spec?
Main differences are the 2.5mm chassis of the MS v 3.0mm of the std car, and the suspension. The MS uses the Evo4/lightweight suspension, the std car the 414/Evo3 suspension.
I personally have a Std car that is almost MS spec, bar the 2.5mm chassis. All the parts for upgrading the std car to MS spec are avaliable seperatly (including the LWT suspension set, part#TAM49346
... much cheaper than all the individual components put together).
For your needs, get the LWT suspension, most of the TRF drivers use the MS (with this suspension) on ashpalt, so that would probably be best.... Although thats not saying the standard suspension wil be crap on ashpalet, it's not, just the LWT is slightly better.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 03-07-2005, 09:56 PM   #7712
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Originally posted by Sparx
Hmm, rotate the bearing holders in the bulkhead?
I ran my first race with the 415 this weekend and it's insane, managed to end up in 5th position in A-main modified from a 7th starting pos. Joel Myrberg where 6th after some problems, Jonas Andersson in 4th and Viktor Wilck 2nd, 1st and 3rd was more of some kind of locals :P Magnus Vassmar in first and Alexander Hagberg in 3rd.. I'm quite happy with my results, just after 10 packs through the car i'll see if i can post my setup later..
Another thing i thought of when buying some stuff from Rainbow Ten, which parts seem to break more often in a crash? I have one extra set of A-arms so those should be ok.
ok thanks will try that today
buboy28 is offline   Reply With Quote
Old 03-07-2005, 10:02 PM   #7713
Burlap's Avatar
Send a message via MSN to Burlap
Originally posted by TryHard Main differences are the 2.5mm chassis of the MS v 3.0mm of the std car, and the suspension. The MS uses the Evo4/lightweight suspension, the std car the 414/Evo3 suspension.
HiH
Ed
Thank you. I'll give it a try with the normal suspension (while I save more money) and get the LWT as soon as I can.
Burlap is offline   Reply With Quote
Old 03-07-2005, 11:58 PM   #7714
maxepower's Avatar
Default Will the 415 reign supreme?
O.K. I'm sure everybodys heard of Surikarn leaving Tamiya and going to HPI and I'm sure you heard that HPI is coming out with their own version of the 415, so if both Surikarn and Hara run the new HPI and Rhinhart and Spegetti runs TAMIYA 415 who will be at the podium in the first big asphalt race of the year ie REEDY?
Excuse me butchering the names!
In my opinion 1st. Surikarn, 2nd Hara, third Baker. Not a Tamiya in sight! Hey, I own a 415 so there is no favoritism here just my 2 cents
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 03-08-2005, 12:17 AM   #7715
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Hey guys.....
I currently have been racing my almost fully hopped TB Evo IV in stock and I've been very competitive with the car so I am moving into Modified. Unfortunately the Evo IV is really not suited to Modified running nearly as much as the 415 so I have pretty much decided to sell the Evo and get a 415MS.
If I were to get a 415MS, are they any sorts of parts that I need for the car for reliability and things like that?? Also..... what roughly are the size of the spurs/pinions that you use for the car in Modified?? Obviously there are quite a few parts that I can use on the 415MS that I have been using on my Evo IV and I have listed them below. Is there anything that I should be getting?? And.... what parts break the most?? I figure pulleys and belts, but this is my first belt car so I really don't have much of an idea of what breaks and what doesn't. Any help will be greatly appreciated!!
Tamiya Evo IV Ti Screw Set
Tamiya Low Friction 5mm Adjusters all round Evo IV
Tamiya Ti Turnbuckles all round Evo IV
Tamiya Evo IV Stabilzer Rod Set
Tamiya Blue Stabilizer ends
Tamiya Evo IV Aluminium Servo Mount
Tamiya Flurine Coated Suspension Balls
Tamiya Rear 1 Degree Alloy Uprights
Square Front Uprights Alloy
Square 4 Degree Alloy C Hubs
Plus.... I have quite a few different 415 toe blocks as I was using them to lower the suspension on my Evo IV.
Thanks in advance!!
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 03-08-2005, 03:18 AM   #7716
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
If the inner ratio on the MS is the same as the regular 415, you would probably need in 64p is 102 and 100 spurs, 26 to about 30 in pinions. Maybe a few lower on pinions
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Savx - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 03-08-2005, 03:20 AM   #7717
F. Alonso's Avatar
okay, has anyone actually got a gearing chart for the car at all?? Like in Excel or anything??
Simon Feigl
Old 03-08-2005, 03:27 AM   #7718
Actually, when you say it, Tryhard has one on his site.
Link
Old 03-08-2005, 05:24 AM   #7719
NOZ69's Avatar
Link
Thanks Sparx..
Just got myself a 415.. after along break from the hobby, & i`ve been after some set up guides , & these from "Tryhard look great.
Thanks again for the link.
Cheers
FT TC4, LRP TC Sphere, LRP X-11 13.5
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
NOZ69 is offline   Reply With Quote
Old 03-08-2005, 05:26 AM   #7720
F. Alonso's Avatar
Thanks for that, TryHard and Sparx!
Simon Feigl
Old 03-08-2005, 08:21 AM   #7721
dawgmeat's Avatar
Default Kai model chassis
Anybody using the kai chassis besides me?
dawgmeat is offline   Reply With Quote
Old 03-08-2005, 08:53 AM   #7722
Originally posted by NOZ69
Thanks Sparx..
Cheers
Hehe, no problems. Im quite new with the 415 too, only run 10 packs through it, and it's a dream to drive. If you run carpet with rubber tires (sorex 28), try my setup that was posted some page ago
Old 03-08-2005, 08:59 AM   #7723
koabich's Avatar
Send a message via Yahoo to koabich
Originally posted by F. Alonso
Hey guys.....
Thanks in advance!!
Just curious, but why is the EVO IV not suited to modified racing?
koabich is offline   Reply With Quote
Old 03-08-2005, 11:08 AM   #7724
raffaelli's Avatar
Got a loaded EVOIV never been on the track for sale.
24ITA
raffaelli is offline   Reply With Quote
Old 03-08-2005, 01:49 PM   #7725
Sorry for asking the question if it has already been answered else where but I am about to get a 415ms and wongering what the gear pitch is normal 64dp or tamiya 0.4 ??
Bryan D is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
