Old 02-27-2005, 10:35 PM   #7561
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Default Re: Re: Re: mip cvd
Originally posted by V12
Is the chatter just with spools? Never had problems with chatter with the 415 until now using a oneway.
It's just a little chatter if you have your wheels turned to full lock, it happens on every kind of drive axle except Losi's new design.
Old 02-28-2005, 06:53 AM   #7562
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default TCS
Back from track side took 5th 19turn got taken out by a lapper cost me 3rd ..got 3rd in mini cooper...I had a great time for my 1st 19turn race and 1st time to track side ..... Tcs races wow they put in a good show cant wait till the next TCS race
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 02-28-2005, 07:42 AM   #7563
Originally posted by TryHard
Hey rick, who'se the Big name Last time i heard jimmy was running a Pro4... wonder why he switched.
Ed
Said he did not like the HPi. The other one is only know by the people that were there..........
Rick Draper is offline   Reply With Quote
Old 02-28-2005, 07:46 AM   #7564
Hey Rick, also being there at the weekend and know the person your thinking of. Probly best though that its kept quiet for now. People will find out in time.
P.S well done for the meeting.
Rob
Robz is offline   Reply With Quote
Old 02-28-2005, 07:56 AM   #7565
hey all wats up ok ive kept quite long enough!
ok yes i will be driving tamiya this year the only reason i was runnign the hpi was just to keep me going while i made the switched.
i run the car which i built friday night and ran very competitive times with it i then made some small chnages which made me feel more confident with the car.. which i then tqd... i had some real bad look in finals being punted off the track twice in both A 1 and A 2 but took 3rd overal which i was happy with just get ready to see tamiya take its first national championship this year here in the uk..
just like to say a special thanks to my sponsors too
ING racing , much more, integy, team BR00D, Inpole, MRT, AND TEAM TITEN.
thanks jimmy maddison
Team AME/Orca
jimmy_maddison is offline   Reply With Quote
Old 02-28-2005, 08:27 AM   #7566
RCGaryK's Avatar
Hey guys, thanks for the help and the suggestions with setup. I did get the car settled down quite nicely, actually too much so and it pushed . One of the biggest things I did was to raise the drive frequency on my VFS-1, and that compensated for my less than smooth throttle finger which was making the car squirt around on power too much. I ended up adding front droop, removing some rear droop, moving the rear shocks in one hole and dropping the spring 1 rate. All in all I was pretty happy and looking forward to running this car again in a couple weeks in the final race of the Midwest Touring Car Championships.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 02-28-2005, 08:39 AM   #7567
TryHard's Avatar
Good news jimmy, I'll be looking forward to your thoughts and ideas your trying out on the car
You going to be making along for the final round of the BIWS?
| THard.co.uk | Xray | MuchMore |
Old 02-28-2005, 08:50 AM   #7568
TryHard's Avatar
Originally posted by RC Professor
Ed,
You claim that dropping the rack reduces the bump steer to zero, right? How does this affect steering and handling?
To be quite honest, I'm not entirely sure what it did to the car... I stupidly did that mod at the same time as changing a load of other things... Still I've kept it, and it does seems slightly responsive on the steering. However don't take that as read, as I haven't done any back-to-back with std rack position (just haven't had the time), I'm just running it on the reasoning, if it's good enough for Marc R, it's good enough for me... oh and that i'm lowering the CoG
Old 02-28-2005, 09:05 AM   #7569
litespeed-dom's Avatar
Originally posted by litespeed-dom
Want to find out the difference when you flip the graphite plate on the steering rack? I notice it'll move the inner ball stud either forward or backwards. I'm terrible when it comes to ackerman....
Dom
Ok, the 415 gurus out here that have more than 2000 posts, know anything?
Sure hard to get questions answered on this thread.
TIA
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 02-28-2005, 09:15 AM   #7570
TryHard's Avatar
TIA
Dom
Sorry litespeed, I don't have a clue about this... ackerman stumps me too
Old 02-28-2005, 09:18 AM   #7571
TRF415boy's Avatar
TIA
Dom
Stock setup is with the ball stud backwards. Moving it forward will reduce ackermann, thus the car will be less agressive entering the corner, but will have more mid to exit corner steering.
TRF415boy is offline   Reply With Quote
Old 02-28-2005, 09:19 AM   #7572
rtypec's Avatar
Dom, you want to use the on-road hard spring set. It's the one with the longer springs and kind of a darker color. I don't use the short springs, and the flourescent spring set is older and softer.
In regards to flipping the steering plate, I have never done that so I wouldn't know how it affects the car. Also, I have not lowered the steering rack and spaced the balls up. It's something that I believe won't help much unless I want to play with bumpsteer (which I don't ) When this was done at the Worlds, it was because it was the Worlds. Everything was placed as low as it can go for a low CG (every little bit helps) not because it will magically give you more steering.
About the two holes on the steering knuckles (C1 and C2), it's easier to remember it this way. Inner hole, more steering. Outter hole, less steering.
rtypec is offline   Reply With Quote
Old 02-28-2005, 09:39 AM   #7573
Thanks to TryHard, 415boy and Rod!!!
I guess I'll do some comparison on the steering plate this Saturday.
So safe to say that the tuned springs set I got that has the red, blue, yellow and white are the long ones then.
thanks again guys!
Dom
Old 02-28-2005, 10:15 AM   #7574
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Wellwell, any things to look out for when building a 415? I should get mine on wednesday
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Savx - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 02-28-2005, 10:34 AM   #7575
not really, just make sure when setting the layshaft pulleys that they do not rub on the bulkheads
ukmaxx is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
