Old 02-24-2005, 03:33 PM   #7471
Ill Factor's Avatar
Default TRF
Why is this car not placing at any of the big races since the Worlds? I am very interested in this Kit but do not want to spend $400 plus for a car that no one else seems to drive in big races. Please give me the 411 and tell my why i should buy this car. Any help is appreciated.
Ill Factor is offline   Reply With Quote
Old 02-24-2005, 03:43 PM   #7472
TRF415boy's Avatar
Default Re: Tamiya shocks
Originally posted by dawgmeat
Are this springs short or long?
Tamiya Super Hard Spring
Part #: TAM53635
Tamiya Ultra Hard Spring
Part #: TAM53636
These are long
TRF415boy is offline   Reply With Quote
Old 02-24-2005, 03:47 PM   #7473
TRF415boy's Avatar
Default Re: TRF
What about winning the GP World Cup in switzerland, a 2nd place at the Yama Yama cup, a 3rd place at the recent TITC, good results at the birds, and so on... Not to forget the car came second at the 2004 DHI Cup while Marc only had the prototype the week before, winning the 2004 Reedy Race, the LRP Touring Cars Masters, etc... What else do you want ?
Old 02-24-2005, 04:04 PM   #7474
Trader Rating: 37 (100%+)
What do people prefer on carpet w/ rubber tires...
415 stock suspension or 415 w/ LW suspension
I'm trying to understand the difference between the stock and LW suspension and why you would use one over the other.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 02-24-2005, 04:13 PM   #7475
TryHard's Avatar
Default Re: Re: Re: Rear Diff
Originally posted by Customworksking
Just wondering if you used the x blocks on carpet if what did u think ..
I've used the X-blocks on carpet, however this is with rubber tyres, so if you run foams it might be different.
Anyway, they make the car much more responsive, and also they give the car a fair bit more steering, almost too much.... at least when the grip is high anyway. At my last club meet I managed to do a quick comparison after a round with a car at standard width, my car deffiently felt like it was turning much better.... and that was againt a car with a 1-way in (i had a spool in mine)
At the moment, I have B/XA on the front, and XB/B on the rear. This gives 1.5deg toe-out (inboard) on the front, and 2deg toe in on the rear (i'm also using the alloy 0deg rear hubs).
I'm a little unsure if going narrower is the best thing for carpet, however if you like a responsive car, then deffiently get them
If it's a low grip situation however (and both myslef and randy seem to agree on this) it does make the car difficult to drive, so I wouldn't suggest using such a setup on, say, a wooden floor, it will just be too difficult to drive.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 02-24-2005, 04:22 PM   #7476
TRF415boy's Avatar
The standard suspension was originally developped for the TRF 414. It has made its way onto the first version of the TRF 415, and works very well on both asphalt and carpet (on which it's very good indeed thanks to its rigidity and strength). Don't forget, Karn won the 2002 worlds with a TRF 414M that had this suspension on.
The LW suspension seems to have been designed with rubber on asphalt in mind, and weight saving. Thus, the rigidity is not as good, and the fact that the bearing are smaller (and closer from each other) makes for some losses in the rigidity area, especially when running foam on carpet.
Personally, I haven't tried the car with the LW suspension on yet, for the very good reason that I only have runned it indoors, since I got it in december. The car with the std suspension on carpet / rubber is just amazing and I don't see any need for me to try the LW suspension.
Old 02-24-2005, 04:52 PM   #7477
litespeed-dom's Avatar
That's what I was told by Korey and Dan (Garber) about the stock susp, it'll be fine on carpet for now and durable for outdoor. If anyone remembers the Nats track at Portland, that's my club and that track is killer on arms/c-hubs/carriers.... if you do hit, you are going to hit hard, so I'm staying with my stock suspension instead of going to the lighter, less durable LW.
I'm a bit nervous about this Saturday running 19T rubber on carpet for the first time, seems like it requires quite a bit of "do this, do that" to the car to make it work on carpet, hopefully it'll turn out good. 415 is pretty much my interim car while I wait for the new XRAY.
Anyone got a real good carpet rubber setup with stock susp? Korey and Dan already gave me some good starting point, but would like to see what everyone's basic setup is.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 02-24-2005, 07:12 PM   #7478
maxepower's Avatar
Randy,
YGPM
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 02-24-2005, 07:16 PM   #7479
TryHard's Avatar
Litespeed,
Theres a few setups on the site on my sig, if they are of any help for you.
BTW, Marc Reinhard ran the car in pre much stock form at the 2004 indoor LRP race... I think you can find that setup on rczone.net.
To be honest all the little "do-this, do-that" bits mention are really only to get the last bits of performance out of the car (although there is probably still more ), stock settings are pretty damm decent as it is.
HiH
Old 02-25-2005, 01:12 AM   #7480
SpeedTech's Avatar
Hi Guys,
We are down to about half of the TRF415 spools left. To be honest there could be a delay after this batch of spools, so those of you that's been contemplating on getting one, now is probably a good time (especially those of you attending Reedy Race )
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 02-25-2005, 02:02 AM   #7481
Eirik's Avatar
Steve,
Will you make a light weight version of the spools??
Also, will you carry any Tech-Racing parts in the near future?
They have a cool chassis kit for the Pro4 and 415.
They also have a optional diff for their car that I think will fit the 415 as well....
Thanks,
Eirik
Eirik is offline   Reply With Quote
Old 02-25-2005, 07:56 AM   #7482
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default ty h
ok thanks ty I'm at trackside now and I am going to be running rubber 19 turn ..Tamiya TCS race I have all day so,I will try your set-up and check lap times ..
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 02-25-2005, 08:43 AM   #7483
koabich's Avatar
Send a message via Yahoo to koabich
If the track is tight and has a lot of traction, stick with the stock 415 suspension. If the track is long and flowing (not too tight) and asphalt, use the LW suspension.
koabich is offline   Reply With Quote
Old 02-25-2005, 09:53 AM   #7484
dawgmeat's Avatar
Default Re: TRF
Please tell me that your jokin' aound?
If not, go buy the Xray they kicked everybody butts in the B-main at the worlds
hey how about the TC4, I bet you could get one real cheap. Half the people who bought them, sold it and got a Xray.
Losi they have been everywhere and haven't won
really get the car that work best for you
Xray: carpet king
415ms: pavement king
just get the RDX they have 2 version
dawgmeat is offline   Reply With Quote
Old 02-25-2005, 10:03 AM   #7485
SpeedTech's Avatar
Originally posted by Eirik
Steve,
Thanks,
Eirik
HI Eirik,
We do not have a light weight version of the spools simply because the spool is not heavy to begin with (it is similar weight to the one-way unit with the outdrives on) Some drivers at the worlds even told us not to reduce the weight to being too light, because the rotating mass and the momentum it carry helped the cars carry more corner speed into the turn, which pull the car through the turn faster.
Tamiya is actually working on a diff for the front of the 415 so we should see that soon. Aside from using the Yokomo ZS-501 outdrives to make a diff, you can also use the ZS-502S if you wish to have a steel outdrive diff.
On the tech racing stuff, we tried, but it just seem like they are not interested in selling their products to us. But we will keep trying
Steve Wang
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
