Old 02-22-2005, 02:42 PM   #7411
tweaking chassis
Anyone else have a problem with the chassis tweaking? Every run I take the wheels off and place the car on a flat board. Almost every time there's a slight twist. It's not like I bounce it off the walls, this is only from kerb clipping.
I was suprised at the amount of play in the top deck holes as well. Is that normal? Could that be the problem?
Any feedback greatfully received.
btw, it's the original 415,
Richard
urbanfox is offline   Reply With Quote
Old 02-22-2005, 02:53 PM   #7412
TRF415boy's Avatar
the "play" won"t change anything. You need to tighten your screws better.
TRF415boy is offline   Reply With Quote
Old 02-22-2005, 03:06 PM   #7413
rtypec's Avatar
In regards to the tweaking issue. Try loosening all upper and mid deck screws as well as the four screws for each shocktower. Put the chassis on a flat setup board and tighten the deck screws first. Then tighten the shock tower screws. Sometimes the shock towers can get tweaked and coupled with how they are mounted to the bulkheads which in turn is mounted to the lower chassis can put a tweak in your chassis even though you don't hit anything. I hope this helps.
rtypec is offline   Reply With Quote
Old 02-22-2005, 03:37 PM   #7414
koabich's Avatar
Send a message via Yahoo to koabich
I have never had a problem with chassis tweaking on a 415. I have heard of several people having the problem however. I run a double top deck however and they may help with the chassis tweaking.
You could have a bad chassis. This is rare but i have seen it happen.
I think the main thing is on how you assemble the car.
Personally, I tighten all screws in a gradual pattern....meaning that I do not put one screw in, torque it down and then install another. For instance, with the bulkheads, I linstall all the screws loosly then tighen them all slowely in a star shaped pattern.
Or try what some of us old Schumacher guys used to do: Place the car unside down (on it's shock towers) on a set-up board. Loosen all the screws on the underside of the car and then tighten each screw slowley (make more than one pass on each screw meaning tighten every screw a little and then tighten each screw a little more) in a star shaped pattern. This should let the chassis lay flat when you retighten.
koabich is offline   Reply With Quote
Old 02-22-2005, 04:17 PM   #7415
DickemDown's Avatar
Default Re: tweaking chassis
Richard
i had the same problem, and solved it w/ rod's (rtypec) method. i'd listen to him, he knows what he's talking about. when you start loosening the screws, you can see the parts start settling in. besides, i got the same advice from some of the faster guys @ socal : ertrachter, bitter, edgar fiallos - btw, big thanks, edgar for the tips.
even barely clipping a dot and the car gets tweaked.
it might seem like a lot of trouble, but i absolutely love drive this car.
DickemDown is offline   Reply With Quote
Old 02-22-2005, 05:20 PM   #7416
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: KAI PARTS
Originally posted by g4t2
Hi Dave (or anyone else in japan), I'm going to Tokyo in may and would like to know if any shops in Tokyo stock Kai parts for the 415? thanks
They usually deal direct.... via e-mail or they have a small.. very small shop/house in Sitama Japan.... Or your can pay BiG BuCkS for it here in the States .... not that it's that much cheaper in Japan
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 02-22-2005, 05:21 PM   #7417
Originally posted by Randy Caster
Did you read my post about raising the diff? It will put the pins more straight with the diff and help with the wear issue.
I look back for that post thanks
-Dave
Old 02-22-2005, 08:04 PM   #7418
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default randy c
I got my x blocks today what setup worked for you I looked back and back and back didn't find it
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 02-22-2005, 09:51 PM   #7419
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
did see that Speedtech in the states has received a second shipment
madjack is offline   Reply With Quote
Old 02-23-2005, 12:46 AM   #7420
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
can a Ta04 lightweight diff joint be used in 415?
KREATOR1 is offline   Reply With Quote
Old 02-23-2005, 01:21 AM   #7421
Originally posted by FW05R
dude how much?
I might be new to this game, but why do you need to spend money on a spool if you can just tighten the differential?
newbee_racer is offline   Reply With Quote
Old 02-23-2005, 01:28 AM   #7422
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Default Re: randy c
Sorry, I have been busy over the weekend with work, and I'm going to be gone on vacation until Friday. I'm going to take my laptop and hope I can use it at my hotel, but I'll get the setup over to TryHard to put on a sheet.
Old 02-23-2005, 01:29 AM   #7423
A tight diff and a spool are 2 different things...
Old 02-23-2005, 01:34 AM   #7424
You're right they are different, one cost money, while the other needs an adjustment. I read somewhere that you can just lock your diffs yourself... cheaper!
Old 02-23-2005, 01:59 AM   #7425
If you tighten your diff to where it's completely locked, you will break your diff screw. No tight diff will be the same as a completely locked axle.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
