Old 02-06-2005, 09:20 PM   #7021
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Default Re: xb-xa
Originally posted by Customworksking
can you tell me what it is you mean xb-xa because its 1c b a x what am i missing I wan t to try a few new set-ups
It goes D, C, B, A, X, XA, XB, XC, XD
Old 02-06-2005, 09:31 PM   #7022
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default abc
o i c.. ones outside of the kit ..i will get them ordered
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 02-06-2005, 09:50 PM   #7023
They are only avalible in the MS worlds upgrade kit at this time.
Old 02-06-2005, 09:55 PM   #7024
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
Default Re: squat steering plate -vs- stock plate
Originally posted by dawgmeat
DG
whats the advanteges using the steering plate for the normal 415?
KREATOR1 is offline   Reply With Quote
Old 02-06-2005, 10:07 PM   #7025
Default Re: Re: squat steering plate -vs- stock plate
That steering plate has adjustable ackerman positions, basically you can fine tune the throw going to the right and left wheels with different ackerman.
Old 02-06-2005, 11:16 PM   #7026
KREATOR1's Avatar
And this means the car car turn more with some adjust to the servo radius?
Old 02-07-2005, 12:04 AM   #7027
TRF Drive Hard's Avatar
Send a message via AIM to TRF Drive Hard Send a message via Yahoo to TRF Drive Hard
Im guessing it has something to do with the response time.
TRF Drive Hard is offline   Reply With Quote
Old 02-07-2005, 12:10 AM   #7028
You can have the same steering radius with different amounts of ackerman, ackerman just adjusts how the steering response or "feel" would be.
If I remember right, if the ackerman is spaced more rearward (making the steering link straight) the wheels will turn about the same amount left and right. If you move the link forward (angling the steering link) it will make the inner tire turn more than the outer tire, giving a more aggressive feel. It's a really fine adjustment, but you can play around with it and might find something you like.
Old 02-07-2005, 12:14 AM   #7029
Sweet, now i understand first thing i learned all day
BTW, does this work also with the knuckles? cause there are 2 holes... i dunno if that has any type of advantage to tuning the amount of steer.
Old 02-07-2005, 12:40 AM   #7030
I havent played much with mounting on the knuckles, but all you have to do is pop the link off, and move it to the rearward hole and see if it changes the steering throw on either tire.
Old 02-07-2005, 12:41 AM   #7031
KREATOR1's Avatar
hey ted,
Normally i just file my C-hub to make my turning radius more .
but this will only work with the 414m2 .
the 415 steering arms just cant turn more like the 414m2.
the stock 415 steering radius if fix untill i found the solution that new steering plate can be adjust.
dawmeat, can you tell us whats the item number for the steering adjustable plate?
thanks
Old 02-07-2005, 01:05 AM   #7032
JimmyMac's Avatar
The Squat steering plate is part number s492. I currently have one on my car. I'm running the rear hole for smoother steering on our high speed carpet layout. I do notice a difference with it. I have yet to try out the aggressive setup. I probably won't try that out til asphalt season.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 02-07-2005, 01:11 AM   #7033
Hey KREATOR1 and KilRuf! cool to see you guys here
So squat makes that plate huh? ima have to see if KoE can get that for me.
Old 02-07-2005, 01:12 AM   #7034
hey ted,
thanks
Actually there is a way to get a tighter turning radius, drop your steering bellcranks all the way down on the posts and shim the ball nuts up 4mm, you can turn up the D/R a little bit more with this setup.
Old 02-07-2005, 01:16 AM   #7035
KREATOR1's Avatar
i kindda blur here, which part are you refering to? steering bellcranks? if you have some picture it will be great.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
