Old 01-28-2005, 11:05 AM   #6841
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
here ya go randy
Socal has them in stock, ( CS Stand $14.00 and of corse the tamiya sticker of your choice hahahah)
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 01-28-2005, 11:21 AM   #6842
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
its a take off stand
Roberto Falcon is offline   Reply With Quote
Old 01-28-2005, 11:31 AM   #6843
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Re: Question re 415 w/ Stk Arms!
Originally posted by JRRobiso
Quick question re 415 w/ std arms. Does anyone run sups blks D/A & C/D for the stk arms & rear hub? Reason for my question is, I currently run my ride outdoors (asphalt) w/ spool/fixed pulley & w/ susp blks C/A & D/D. Thanks for the quick reply.
jun.. when i HAD my 415. i ran D/A up front and A/A in the back. A/B sometimes depending on track conditions. this was for outdoor asphalt, blown/swept, no sauce on CS-27s for stock.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 01-28-2005, 11:32 AM   #6844
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by TryHard
Hey randy,
How you getting on with the Narrow Xseries blocks? Have you managed to try them yet?
I managed to pick up a world champ set pretty cheap (main reason being for the Alu rear hubs), so I'm thinking of changing the front blocks from D/A too B/XA, just making the car narrower at the front (and the same width as at the rear). Any thoughts on this guys?
Regards
Ed
I will be testing with them on Tuesday. I have an X-XC Combination in front so it will have sweep, and a double XB combo in back. I ditched the 0 degree hubs for this trial setup, and bought some alloy Evo 4 1 degree hubs.
Old 01-28-2005, 11:36 AM   #6845
Originally posted by JasonC
here ya go randy
I wish it were closer to Tamiya blue, but I have one coming anyway. I've been using my digital caliper case as a car stand for too many years lol
Old 01-28-2005, 11:42 AM   #6846
TryHard's Avatar
Originally posted by gonad
Wow, excellent and fast reply. Thank You. I run outdoor asphalt.
I ordered the MS from Tower Hobbies 10 min. ago.. I probably could have found a cheaper source but on the upside I'll have the car in my hands tomorrow. Thanks again for the response.
No prob, hope you enjoy the car, you should, it's awesome
Ed
| THard.co.uk | Xray | MuchMore |
TryHard is online now   Reply With Quote
Old 01-28-2005, 12:25 PM   #6847
The MS is the only car I've had that was competitive out of the box with the stock setup, so I'm sure you'll like it gonad.
Old 01-28-2005, 12:33 PM   #6848
Bflat's Avatar
Default 415ms
$510.00 at tower hobbies WOW!
Bflat is offline   Reply With Quote
Old 01-28-2005, 12:42 PM   #6849
Anyone know where I can get a 360 Modena and a Raybrig NSX body in one shot?
Old 01-28-2005, 12:57 PM   #6850
$510.00 minus $25.00 coupon plus $30.00 overnight sat delivery
instant gratification "priceless"
$600.00 loss of company time while I'm typing on message board
gonad is offline   Reply With Quote
Old 01-28-2005, 12:59 PM   #6851
JasonC's Avatar
should have gotten it from steve, ( the advertisers keep the forum alive ) would have saved you some $$$ to boot
Old 01-28-2005, 01:35 PM   #6852
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Here you go Randy. He has both available.
Modena Body
Raybrig 2003 LW Body Parts
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 01-28-2005, 01:44 PM   #6853
Randy you might give Kevin or Brett at Burien a call
1.800.654.6456
Last I saw they had both on the shelf and might be able to still ship today
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 01-29-2005, 01:08 AM   #6854
PMR
So far Ive tried the XA/XD in front and 1A/1C at the rear(rear upright 0 degree) and instantly noticed the responsiveness of the steering. Eventhough it really didnt help much with the mid and exit it really is not necessary since the MS kit has tons of mid and exit. Still need more steering though cuz I run a tight and twisty med to high traction asphalt track.
Still not satisfied, I realize that the car pushes when entering a corner. I experimented on the throttle trim giving it a little drag brake off throttle to loosen up the rear a bit and it did help a lot. So what I did to substitute this effect was to increase the toe in from 1A/1C to 1A/1XB (rear upright 0 degree) to give the car a bit of drag off throttle and WOW perfect combi...good turn in and at the same time very stable. Kinda wierd though since we all know increasing toe in for the rear will decrease steering.
Anyway for those who find the MS kit too stable below are the changes I made from the standard set up.
Springs:Rayspeed red springs around with rs caps
Front stab: none
Rear stab: Blue
C hub: 2 degrees
Front blocks: flipped Xa/Xd with 2mm spacers
Rear Blocks: 1XB/1C with 1mm sapcers
Hopes this helps.
PMR is offline   Reply With Quote
Old 01-29-2005, 03:37 AM   #6855
TryHard's Avatar
thanks for that PMR, I'll probably give them a try soon, biggest problem i have is i don't drive enough at the moment.... If i want to work on the car, i have to sack the results at club meetings and make changes for each run....
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
