Old 01-25-2005, 02:57 AM   #6736
KELVIN KHNG's Avatar
Trader Rating: 15 (100%+)
yes eirik...
my driveshafts really do shatter a lot..i thaught i build something wrongly as it wasn't the case for the one way diff...i rebuild it and the same thing of shattering shafts came again when i locked my steering...hmm..guess my questions are answered...the steel spool really gives the shattering shafts...but is there any way to correct it??like cut the drive shafts shorter or something>?
KELVIN KHNG is offline   Reply With Quote
Old 01-25-2005, 03:54 AM   #6737
TRF415boy's Avatar
Kelvin,
The reason why driveshafts shatter with a steel spool is because they are not real constant velocity (although they are called CVDs). So when you have a spool and you turn your wheels, the spool will provide a constant velocity to the driveshaft, but the joint will make the rotating speed of the wheel vary around that value (during one complete turn, the speed of the wheel will increase and then decrease, twice) which causes chatter.
Now about steel/alloy/delrin spool, a good point have been raised about inertia, but you also have to consider the stiffness of the spool. A steel spool will have no flex and so there will be a lot of chatter (especially with a brand new spool that gives no play to the driveshaft's pin). And a lot of chatter means a lot of losses in terms of grip.
A spool with delrin outdrives on the contrary will have a lot of flex (delrin is far from being a strong plastic material) and so the chatter will be minimal with that. An alloy spool will just be an in-between those two.
TRF415boy is offline   Reply With Quote
Old 01-25-2005, 07:36 AM   #6738
if thats the case....i don't think the steel spool is a good alternative for now since it has got this problem of chattering which reduces speed and produces hell of a lot of noice...how come the spools of the tc3 do not have this problem?
..what spool and by what make do you guys own..apparently i have super glued one of my one way diffs and it seems like it has got lesser of that problem of wheels chattering...maybe it is wise to switch to that then the steel spools.or do you guys have got a solution to it like after mayket outdrives or are you running with the chattering shafts?
Old 01-25-2005, 09:02 AM   #6739
TryHard's Avatar
I have a solid steel speedtech spool, don't really notice much chattering to be honest. It's pretty light too, probably about the same as the one-way
Ed
| THard.co.uk | Xray | MuchMore |
Old 01-25-2005, 10:56 AM   #6740
Arun's Avatar
TC3's do actually have chatter with a spool, but their "threshold" for staying smooth is a little higher, I would say. If you were to do the popular modification of installing team losi steering knuckles, you could definitely notice the chatter, as this mod gives the car more throw.
It also seems that losi has come up with a nice new universal to reduce chatter. You can see a pic of it in this month's Xtreme R/C magazine. They basically set up a universal with two pivoting points on the axle side (two universals in one). So, at full throw, both of the universals will only be pivoting at half the angle.
http://nexusracing.com
Arun is offline   Reply With Quote
Old 01-25-2005, 11:32 AM   #6741
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by Matt Howard
http://www.rcingreece.com/index.asp?...ing_comparison
Thank you Matt and Dave.
Old 01-25-2005, 11:38 AM   #6742
Im running the Speedtech spool as well, and did not chatter at all with it.
I'd like to try a milled down version of this spool, and spools out of different materials though just to see if steering will increase. RROC is coming up in 5 months and I want to have this car absolutely dialed with a spool or diff by then.
Old 01-25-2005, 04:47 PM   #6743
rcfiend's Avatar
Trader Rating: 30 (100%+)
JDM_DOHC_SiR - You got PM.
Keith
rcfiend is offline   Reply With Quote
Old 01-25-2005, 05:30 PM   #6744
JimmyMac's Avatar
I notice the spool chatters more in Stock than say 19t or Mod. That's just my observation. So I never run the spool in stock. Always a oneway. One idea I do have is to run Pro4 front spindles with Pro4 axles and IRS TC3 dawgbones. You'll have to enlarge the slots more in the spool. But the dawgbones should help reduce some chatter. TC3's do start out with some chatter. But once broken in... it mostly goes away. At least that's been my experience. I could turn the wheels full lock and spin the drivetrain (without motor) and it'll keep rolling smoothly as it would with the tires pointed straight. I have not been able to do that to my Yokomo SD or EvoIV with a spool.... yet.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 01-25-2005, 05:58 PM   #6745
raffaelli's Avatar
Raul!!!!! You out there!!!!
I need an A Bridge for Sunday!!!!!
24ITA
raffaelli is offline   Reply With Quote
Old 01-25-2005, 06:12 PM   #6746
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Keith
Back to ya Keith
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 01-25-2005, 07:08 PM   #6747
John Tag's Avatar
Trader Rating: 42 (100%+)
I would go GWB
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 01-25-2005, 07:19 PM   #6748
Trader Rating: 74 (100%+)
Default hahahahahaha
Thats funny!!!!!!!!!!!!!!! Was up Tag. Ready for the Mimi run. Sorry cant make it. N.C. huh? Wha happened?
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 01-25-2005, 07:20 PM   #6749
raffaelli's Avatar
Originally posted by John Tag
I would go GWB
LOL!!!!!!!!
How do I get my hands on a tag-a-fied 19T?
24ITA
Old 01-25-2005, 07:26 PM   #6750
John Tag's Avatar
LOL!!!!!!!!
Chris, When there in and done I'll give ya a shout
Raul, Yea NC come summer. Mimis yup friday,looking for good time win or beat to death We all needed changes
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
