Old 01-23-2005, 06:46 PM   #6706
linger's Avatar
Originally posted by SchuMi2
I am looking at trying the D/ A bridge on the front but would like to know the full effect this has. Does it just increase the aggresiveness on initial turn in or does it have an affect in the middle to exit of a turn also.
It's a compromise. A slight decrease in turn in, but more steering mid to corner exit.
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 01-23-2005, 09:06 PM   #6707
PMR
Default Gritty Diff. Any tips or mods?
Any of you guys experience problems with the rear diff? I ran my bnew kit for 10 runs and the rear diff became very gritty. I rebuilt the diff and again after about 4 runs it became gritty and inconsistent again. I have a Yoke and an Hpi and I must say the diffs are very smooth and they last forever. Any of you guys have tips or mods for the 415s diff.
PMR is offline   Reply With Quote
Old 01-23-2005, 09:17 PM   #6708
PMR
Thumbs up Aluminum rear uprights
By using the aluminum uprights you eliminate the wobbling of the axle. Try moving your rear tires left and right by hand and you'll see what I mean but with the upgrade it is almost eliminated and would also prolong your 950 bearings. Also it elimiminated the gritty feeling when the axles are turned. The upgrades are very smooth and perfectly aligns the bearings and the axles. Two thumbs up!
Old 01-23-2005, 11:39 PM   #6709
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Default Re: Gritty Diff. Any tips or mods?
Within the last 10 pages of this thread there should be a lot of pics from different people that made diff shields to keep debris out of the diff. I havent done it myself, I just run ceramic diff balls and delrin outdrives and it stays smooth.
Old 01-23-2005, 11:58 PM   #6710
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Re: Gritty Diff. Any tips or mods?
ATLAS Racing Japan makes 415 Dust cover shields/seals for the Rear diff... ...... just a thought... . . Steve-"W" might be able to help you out on this one..??
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 01-24-2005, 08:58 AM   #6711
dawgmeat's Avatar
Default Re: Re: Re: Gritty Diff. Any tips or mods?
-Dave
make sure you lightly sand the diff outer walls, it amkes it stick better. This is my front diff
dawgmeat is offline   Reply With Quote
Old 01-24-2005, 09:37 AM   #6712
dawgmeat's Avatar
Default Re: Re: Re: Re: Gritty Diff. Any tips or mods?
front and rear diffs, it's a pain in the A$$ to make sure their centered so they don't hit the diff halves
Old 01-24-2005, 09:44 AM   #6713
KELVIN KHNG's Avatar
Trader Rating: 15 (100%+)
hi..i have got a relatively good setup on a double one way with my 415 ms but i thought that i should also try out the spool setup...have you guys got any idea how shuld i setup the car for a spool as i swap my one ways for the spool and the car just understeered badly...are there any setup sheets for the spool?
KELVIN KHNG is offline   Reply With Quote
Old 01-24-2005, 10:08 AM   #6714
Eirik's Avatar
If you have a steel spool there is not much you could do, it will always have very litle steering. Going to a delrin type spool will give you much more steering!!
You could always try Anti-Squat, this will give you more off power steering and softer front springs.
Eirik is offline   Reply With Quote
Old 01-24-2005, 10:47 AM   #6715
TRF415boy's Avatar
Advices provided by a top Uk driver who used to run the 415 with a spool : Use the A bridge along with the D block on front (1.5 in board toe out), use less spacers under the front camber links, use anti-dive on front (0.7 mm under the D-Block for ex)
All this should help, and as has been said, use softer springs on front than with a one way (if you were using white go for blue).
TRF415boy is offline   Reply With Quote
Old 01-24-2005, 12:58 PM   #6716
Default Re: Re: Re: Re: Re: Gritty Diff. Any tips or mods?
Looks like they do a pretty good job of keeping it sealed though, and gotta be easier than making your own.
Old 01-24-2005, 01:00 PM   #6717
Is there anyone that makes a delrin spool that is avalible for sale?
Old 01-24-2005, 01:07 PM   #6718
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
I thought TiR made a spool... MR used it at the Worlds recently (thought I saw it at Speedtech?)
I would be question how durable this was however?
madjack is offline   Reply With Quote
Old 01-24-2005, 01:08 PM   #6719
I got the impression that wasnt a production piece, and I also heard he broke an outdrive.
Old 01-24-2005, 01:10 PM   #6720
TRF415boy's Avatar
Durability of the TiR spool with delrin outdrives in Mod = 0. It's more suited to stock and super stock racing. A friend of mine used one in mod in his pro4 and eventually broke about one outdrive every two runs or so... He went back to a proper spool.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
