Old 01-20-2005, 12:17 AM   #6616
Trader Rating: 23 (100%+)
Originally posted by Hebiki
is the blueberry done yet? are you gonna make it this sat?
blueberry is running. all systems are a go for Sat.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 01-20-2005, 03:11 AM   #6617
Default Re: just a quick question...
Originally posted by s2
what is the largest 64dp spur that will comfortably fit the 415?
thanks
I normally use a 112. You have to fill the rear mid deck a bit to allow clearence when changing to this spur. Its also good to file and angle on the lower deck so it isn't too close to the deck. That way rocks don't get caught.
Has anyone tried the tamiya ti axles before? How do they hold up?
Also... Anyone know how long acer racing takes to send out orders? I ordered a kit for my 415 a few days ago... would like to know if it will be here soon.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 01-20-2005, 08:18 AM   #6618
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Mark you crack me up...so did you walk in the house, lock yourself in the lab for 5 hours straight for this MS build?
will you be testing spool or one way this Sat.?
madjack is offline   Reply With Quote
Old 01-20-2005, 09:22 AM   #6619
Arun's Avatar
As far as wearing out diffs...
Have any of you tried greasing the dogbone pins? I use the AE black grease, which is fairly slippery. It allows the dogbone pin to slip against, instead of notch, the outdrive, while also preventing it from heating up (in which case it wears even faster).
It is my experience that black grease works better than the Tamiya AW grease, because the AW grease is too sticky and does not allow the pin to slip. I re-grease the pins fairly often, about every 4 or so runs; this does not require dissasembly.
http://nexusracing.com
Arun is offline   Reply With Quote
Old 01-20-2005, 09:29 AM   #6620
rtypec's Avatar
Lol...I run my outdrives (front/rear) dry It doesn't attract dirt like a magnet BUT wears a tad bit quicker.
Wanna know a little universal something something? Go to a motorcycle shop and pick up Maxima chainlube spray. Build your universals dry using blue loctite on the set screw. Hang the universals by taping them to a corner of your table. Fill the axle "cups" with Maxima and let dry (couple hours). When dry, you can use motor spray on a rag to clean up the excess residue off of the axle and bone. Work the universal so that it doesn't feel too bindy; some bind is okay but not like stuck bind hehehe. Works grrrrrreat! and does not attract gunk like other stuff.
Psst...Mark/John, do you think the we'll be able to sneak in some timed practice runs this weekend since the computer may be up for F1RL?
rtypec is offline   Reply With Quote
Old 01-20-2005, 10:04 AM   #6621
madjack's Avatar
lets hope..I would love to get a guage on some of those changes from last week.
Old 01-20-2005, 10:21 AM   #6622
koabich's Avatar
Send a message via Yahoo to koabich
Default Re: Re: just a quick question...
I just ordered their set of ceramics for my 415. It took about a week and I placed the order during the holidays!
koabich is offline   Reply With Quote
Old 01-20-2005, 10:53 AM   #6623
Randy Caster's Avatar
Trader Rating: 46 (100%+)
there wasnt a calculated plan other than to try the best shaft and best belt car on the market and find something of happy balance in between.
Have you tried the Evo 4 yet? That looks like it'll be just as fast as the Pro 4..
Old 01-20-2005, 11:00 AM   #6624
madjack's Avatar
Originally posted by Randy Caster
Have to tried the Evo 4 yet? That looks like it'll be just as fast as the Pro 4..
lets hope
Old 01-20-2005, 11:59 AM   #6625
I just countersunk my shock towers, upper deck, and chassis braces, and I gotta say Im surprized that a few of these parts werent drilled straight. The upper deck has a little angle on it, which wont make any difference, but both of the braces were drilled crooked as well, which means one camber link will be longer than the other. Kinda disapointed in that, almost wish I had left them stock so you can just push it straight with the little slop you have in the screw hole.
Old 01-20-2005, 01:09 PM   #6626
lol, that is a lot of presure to get this car fast quick. what time do the gates open?
TEAMORCA.SHOP
Old 01-20-2005, 01:32 PM   #6627
Trader Rating: 62 (100%+)
Randy, just flip them over so the countersunk side is down. F.D.
patrick is offline   Reply With Quote
Old 01-20-2005, 01:45 PM   #6628
Hebiki's Avatar
Trader Rating: 26 (100%+)
gates probably will open at 8am.. track wont open until 10am. not sure what time it opened last week. john do you remember? i got there late.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 01-20-2005, 02:44 PM   #6629
There would be such little contact area on the rear bulkhead, and then the front top deck spacers would recess in the countersink a little bit, not gonna happen. F. D.
Old 01-20-2005, 02:48 PM   #6630
Scho's Avatar
Send a message via MSN to Scho
you got a pic with the countersinking done?
Scho is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
