Old 01-19-2005, 04:13 PM   #6601
JimmyMac's Avatar
What chassis are you talking about? I have used a 112 spur before in the 415. That's the largest you can go. The spur is level with the bottom of the chassis. I dunno about the MS because the chassis is thinner. So a 112 may protrude from the bottom. Right now I use a 101 xenon spur from SpeedtechRC.. It gives me the ratios I need for 19t. But it also gives me what I need for Stock as well as 10x1 motors. I'd probably switch to a 104 if I went with a 7x1.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 01-19-2005, 04:33 PM   #6602
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by madjack
MDAWSON...are you out there?
Check the Pro4 thread, you'll have a better chance
Old 01-19-2005, 04:36 PM   #6603
The 104 tooth is barely above the bottom of the MS chassis, I wouldnt go any bigger just in case you should run into a rock. The smallest pinion I've used is a 24 tooth which had no problem reaching.
Old 01-19-2005, 05:08 PM   #6604
Trader Rating: 23 (100%+)
You are wayyyyy funny. Building the Blue Monster right now. I like to call this on Blueberry. The other one is Grape.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 01-19-2005, 05:16 PM   #6605
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
sounds good...let me know when you will be up for a test day at TA
madjack is offline   Reply With Quote
Old 01-19-2005, 05:24 PM   #6606
s2
s2's Avatar
sorry should of said it is the regular 3mm chassis
thanks for your help
s2 is offline   Reply With Quote
Old 01-19-2005, 09:48 PM   #6607
PMR
What's the biggest spur for a 48 pitch we can use for the MS kit?
PMR is offline   Reply With Quote
Old 01-19-2005, 10:03 PM   #6608
SchuMi2's Avatar
Trader Rating: 34 (100%+)
PMR.....81T spur is the max
SchuMi2 is offline   Reply With Quote
Old 01-19-2005, 10:08 PM   #6609
PMR
Just got from the mail the MS world champion parts set. But I need your help here. For the rear suspension I know it would increase or decrease the toe angle and its effect in steering. However for the front, it would also increase/decrease the angle but what puzzles me is the effect it will make. Say if I use the std front 1A block with 1XD (-2.5 deg) what effect will it give me? If I use the 1A block with a 1XA (-1.0 deg) what will it give me. Thanks in advance.
Randy: Thanks for answering my question regarding the rear belt adjustment . I appreciate it.
Old 01-19-2005, 10:54 PM   #6610
B&O
B&O's Avatar
For the toe out angle in front, you will get a quicker first respond. But the middle and exit corner, the car tends to push out ... I think.
B&O is offline   Reply With Quote
Old 01-19-2005, 10:56 PM   #6611
Korey Harbke's Avatar
Did you get a 415??????? Or are you just putting your old 414 back together???
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-19-2005, 11:21 PM   #6612
-Korey
a new 415ms, the 414 is ready as well. email your latest and greatest when you get a chance.
TEAMORCA.SHOP
Old 01-19-2005, 11:32 PM   #6613
I didnt expect that move, thought you were lovin the Pro 4. Is this here to replace it, or just a TCS ride?
Old 01-19-2005, 11:57 PM   #6614
Hebiki's Avatar
Trader Rating: 26 (100%+)
is the blueberry done yet? are you gonna make it this sat?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 01-20-2005, 12:17 AM   #6615
there wasnt a calculated plan other than to try the best shaft and best belt car on the market and find something of happy balance in between.
TEAMORCA.SHOP
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
