Old 01-18-2005, 01:34 AM   #6571
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally posted by Randy Caster
Yes, they suck, lol.
That being the case, did you switch back to the stock black one? Or do you just keep replacing them?
jeffreylin is offline   Reply With Quote
Old 01-18-2005, 02:53 AM   #6572
V12
V12's Avatar
Originally posted by Besercoe
Yes the wear on the outdrives is atrocious, i added Xray blades to my car recently and so far things have been going well. You need to dremel the diff slot wider to allow for the width of the blade, a flat cutting disk did this easily just go slow until thet are wide enough, the xray blade need a little bit of modification as well as they are "Taller" than the tamiya driveshafts, put them on the dogbone, squeeze the ends with a pair of pliers, and hit the connecting piece of the blade with a flame from a lighter, this will shape the blade so that it fits snugly.
so far zero wear on the outdrives or the blade.
The Corally blades work much better for the Tamiya cars than the Xray. Its just a direct fit.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 01-18-2005, 03:32 AM   #6573
I might try those corally blades, keep the evil x-ray parts off my tamiya.
Did they fit the dogbone and the outdrive ok? I would figure that the outdrive requires mods.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 01-18-2005, 04:03 AM   #6574
V12
V12's Avatar
Yes the outdrives need to dremel as Besercoe wrote.
But the Corally blades seem to be perfect for the Tamiya dogbones at least work the best from all blades available.
I was told this from Jrgen, the guy who makes the aluminium diffs for the 415. I also have the parts here but had no chance to check since now.
Old 01-18-2005, 05:42 AM   #6575
well at least the xray comes with a battery strap, and the inline strap works very well on the 415, re the corally parts i will have to have a look at them, but i dont know if i could put an ass car part on my beautiful 415.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 01-18-2005, 05:52 AM   #6576
V12
V12's Avatar
Yes you really have to use other brands parts sometimes.
Im using the Xray battery strap also.
Old 01-18-2005, 07:03 AM   #6577
I picked up a batt strap on mon. I'll stick it to the deck with some of the cassis braces as I don't use them anyway.
Powered by Falco
Old 01-18-2005, 07:20 AM   #6578
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
one of the guys here ordered the Corally strap.. ill keep ya posted on the fitment.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 01-18-2005, 08:11 AM   #6579
Leini's Avatar
man, thats ugly!!!
Leini is offline   Reply With Quote
Old 01-18-2005, 09:10 AM   #6580
TRF415boy's Avatar
V12, since you have some contacts with Marc, do you think you could get him to give us his exact setup off the worlds ?
We already know that he used HPi silver springs, Alex Racing rll bars, pro4 rear hubs, but what we'd really like to know was where he used the new blocks. I saw on his car there's a flipped block on the front, would also be interesting to know what block that was and how many spacers he used.
TRF415boy is offline   Reply With Quote
Old 01-18-2005, 09:32 AM   #6581
s2
s2's Avatar
and his DHI setup?
s2 is offline   Reply With Quote
Old 01-18-2005, 09:39 AM   #6582
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I keep replacing them just because I also had bad luck with the black ones, I felt like they didnt let the diff rings sit flat, the diff never worked well with them. I'm out of replacements now though, so I'll propably just go to a new set of plastic outdrives.
Old 01-18-2005, 09:45 AM   #6583
Ive gotta get a set of the HPI silver springs, if they are right between yellow and blue, that would be perfect.
From what I've found at SoCal, yellow is very drivable, but not as fast as it can be. Blue makes the car very loose and hard to drive, but when done right it's extremely fast. Hopefully the silver will make the car a little loose so the back end rotates easilly, but a little easier to drive than a Tamiya blue spring.
Old 01-18-2005, 09:45 AM   #6584
rtypec's Avatar
Randy, how many days of practice and racing have you put them through? From previous experience, the delrin outdrives get notchy quick. I still have the same black outdrives in my car from the Roar Nats...I also have the same black ones in my test car. Once I run out of black ones...I may just try the delrin ones, but I have a feeling that I'd go back to the black ones...they hide dirt REALLY well
rtypec is offline   Reply With Quote
Old 01-18-2005, 10:01 AM   #6585
Surprizingly the white ones dont get very dirty at SoCal, they stay pretty white I'm only running mod, but they are basically good for 1 raceday before you have a ton of slop and a nice notch.
I've got a lot of new black outdrives, so I'll just mix and match until I find a set that seems really smooth, but then again, it could have just been 1 bad outdrive that I got origionally that wouldnt run smooth.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
