Old 01-16-2005, 04:28 PM   #6526
s2
s2's Avatar
http://www.thard.co.uk/rc/TRF415/TRF415pages.html
both blank sheets and some other setups at the bottom of the page
s2 is offline   Reply With Quote
Old 01-16-2005, 04:38 PM   #6527
SchuMi2's Avatar
Trader Rating: 34 (100%+)
Much appreciated...
SchuMi2 is offline   Reply With Quote
Old 01-16-2005, 04:52 PM   #6528
razzo's Avatar
Send a message via Yahoo to razzo
Originally posted by TRF415boy
Yes but on the 414M the likns were connected on a line parallel to the hinge pin on the chassis side, so travel wasn't a problem. This link though may indeed need proper spacing on the chassis stiffener side to work better. The gain wasn't provided by the castor angle being the same during suspension travel, but to the added stiffness of the C-Hub. It's like having a double wishbone suspension.
er... even with out torque rods, 415 and 414 already have double wishbone suspension.
Used torque rods back in 414M days, till I kept on breaking the knuckle or hub carrier on light impacts (2x4 wood barriers) finally said heck with them, no more breakage. With super stiff a-arms, nothing was giving out during impact. C-hubs are molded from flexier plastic then rest, so it would give a little with out breaking.
razzo is offline   Reply With Quote
Old 01-16-2005, 04:58 PM   #6529
TRF415boy's Avatar
nope, this is not double wishbone, this is wishbone/upper link, which doesn't give the same kind of stiffness than real double wishbones.
Never had any breakages with the two rods on the 414M and I did have big crashes.
TRF415boy is offline   Reply With Quote
Old 01-16-2005, 05:21 PM   #6530
TryHard's Avatar
Originally posted by s2
ahh, so there is, that was the first place i looked, but totally missed it
thanks
Now now stew, you should know about these... after all one of your sets is on there! hahaha
BTW there isn't a blank one for the std suspension on the page, however it is buried in the site, I've just yet to update the page... direct link here.
http://www.thard.co.uk/rc/TRF415/set...tup%20Sheet%20(std%20arms).jpg
Also, the LWT one i've literally just updated on the site, it's had a few font changes, and some of the numbering systems have been correct. minor changes, but brings them into line with the MS sheet. (same has been done with the Std suspension one)
Regards
Ed
| THard.co.uk | Xray | MuchMore |
Old 01-16-2005, 05:25 PM   #6531
razzo's Avatar
technically... our cars don't have 'wishbone' suspension.. it's single A arm with upper control link. These cars use single arm for lower linkage, with hinge pin, not a single lower and upper pivot at c-hub point like 'true' wishbone suspension... To use the term 'wishbone' suspension loosely (like real cars, ie Honda) our cars would be 'double wishbone' Anything that's not strut based suspension can be loosely called double wishbone or double A arm. My old Honda and Audis had one upper control link, but they were still called 'double wishbone'
Only 'real' wishbone suspension in RC I can think of is T-maxx front end, and 1/8th scale gas pancar front end where you have 2 pillow balls holding up the c-hub.
Old 01-16-2005, 07:12 PM   #6532
RCGaryK's Avatar
Well, I ran my 415 for the first time last night and I must say I was disappointed and impressed all in the same evening. The car was wickedly loose through practice and the first 2 qualifiers (I only turned 10 laps in the 2nd heat because it was so loose and undriveable) but managed to get the car dialed in to qualify 3rd. I made a gamble on setup, motor, and gear for the main (hey, if you're gonna crash and burn might as well make it spectacular, right?) and managed to take the lead 2 minutes in and hold on for the win. This is only the 2nd time I have ever won the first night out with a car (the other was my F103). The one thing that I was curious about was on my other chassis when I have shortened the wheelbase by moving the rear arms forward, this has normally tightened the car up. On the 415 this actually freed the car up. Has anyone else found this to be true?
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 01-16-2005, 07:20 PM   #6533
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Default Re: Re: carpet 415
Marc lowered the steering but used 4mm of spacers between the carbon plate and the ball nut where the steering turnbuckles goes.
I didnt know why he did this mod, but Patrick had figured it out, and ran it today and loved it. Using 4mm of spacing under the ball nut raises the nut over the bellcranks, allowing a little further steering travel. It also came out to have nearly 0 bumpsteer like this, drive really well on outdoor asphault.
Old 01-16-2005, 07:27 PM   #6534
Default Re: Torque rods
Originally posted by dawgmeat
Whats are the pro and cons of using this set-up
I tried it personally on my old Barracuda R2 and will never do it again. Honestly I just could not get the car to work with those on, but when I took them off it would instantly get good.
So in my view, there are only cons, which is running those links makes the car suck.
BTW, this was on asphault, dont know if its any different for carpet, but I do know I will never try it again.
Old 01-16-2005, 07:32 PM   #6535
eeyan's Avatar
Send a message via AIM to eeyan Send a message via Yahoo to eeyan
Originally posted by RC Driver Gary
Well, I ran my 415 for the first time last night and I must say I was disappointed and impressed all in the same evening...
Mr. Katzer... congrats! You finally fixed the tweak Chris has been battling on that exact chassis for a looonggg time... (jas kidding!)
BTW, what class did u run?
TAOB Racing Team (1999 - 2011)
eeyan is offline   Reply With Quote
Old 01-16-2005, 07:38 PM   #6536
RCGaryK's Avatar
Stock rubber. The top 2 qualifiers are towards the tops in points in out state series we have going on right now....one is the current point's leader and a top 5 finisher at the Novak race in Stock Rubber too. Just need the car to have some more low speed steering.
HorizonHobby.Com
Old 01-16-2005, 07:54 PM   #6537
I played with the torque rods heaps when I had my 04r. You could never get full sus travel from full droop to level with lower deck without binding. Removing them improved the car in many was but best was that camber changes were very quick and hassle free.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 01-16-2005, 07:59 PM   #6538
raffaelli's Avatar
Originally posted by Dragonfire
I played with the torque rods heaps when I had my 04r. You could never get full sus travel from full droop to level with lower deck without binding. Removing them improved the car in many was....
Exactly, non concentric arcs.
24ITA
raffaelli is offline   Reply With Quote
Old 01-16-2005, 08:11 PM   #6539
dawgmeat's Avatar
Default 415 parts
Man if anyone has this part I will pay a pretty penny for it new or used
dawgmeat is offline   Reply With Quote
Old 01-16-2005, 08:40 PM   #6540
Neil Rabara's Avatar
Gary, I just got my 415 ready also. Haven't broken the virginity on the track yet, that comes later this week.
Neil Rabara is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
