Old 01-16-2005, 01:16 PM   #6511
dawgmeat's Avatar
Default Torque rods
Whats are the pro and cons of using this set-up
dawgmeat is offline   Reply With Quote
Old 01-16-2005, 01:20 PM   #6512
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
well, i think it does 2 things....
1, it keeps the correct caster angle, as some think the c-hub flexes under high traction hard cornering.
2, it also helps support the c-hub, and prevents some breakage.
at least, that s what i understand...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 01-16-2005, 01:22 PM   #6513
TRF415boy's Avatar
when we were using the 2 upper links on the TRF 414M, we'd take the second one out if we wanted to loose steering.
TRF415boy is offline   Reply With Quote
Old 01-16-2005, 02:06 PM   #6514
raffaelli's Avatar
I think a con might be that it will impede on the proper travel angles for camber during uptravel.
What is the deal with the sway bar in that picture?
24ITA
raffaelli is offline   Reply With Quote
Old 01-16-2005, 02:09 PM   #6515
Turbonium's Avatar
shouldnt impede the travel, as long as it is adjusted correctly.
the upper swaybar mount showed up on TRF414MIIWCReplica, as Surikarn used a fabbed mount like it when he won the worlds...
Wes
Team Novak
Old 01-16-2005, 02:12 PM   #6516
raffaelli's Avatar
It has to.....do the geometry. There are competing arcs that are not concentric. To what degree.....not sure. But it will.
24ITA
Old 01-16-2005, 02:14 PM   #6517
Turbonium's Avatar
through a complete arc, prolly....
on the car, the movement isnt near far enough to bind... IF the links are adjusted right. they were used on all the 414M series, and the TA04R as well.
Wes
Team Novak
Old 01-16-2005, 02:23 PM   #6518
TRF415boy's Avatar
Yes but on the 414M the likns were connected on a line parallel to the hinge pin on the chassis side, so travel wasn't a problem. This link though may indeed need proper spacing on the chassis stiffener side to work better. The gain wasn't provided by the castor angle being the same during suspension travel, but to the added stiffness of the C-Hub. It's like having a double wishbone suspension.
Old 01-16-2005, 02:39 PM   #6519
dawgmeat's Avatar
Default Torque rods part 2
Trying to support my LHS I order some Castor through his store and I guess he ordered the wrong part, well it had the castor blocks but it also came with the torque rods set up, so I either I loose it or use it, "USE IT"
Old 01-16-2005, 02:47 PM   #6520
TRF415boy's Avatar
he ordered the ones that were the option for the TA04, which came with the rods.
Old 01-16-2005, 02:54 PM   #6521
dawgmeat's Avatar
THE LAST TIME I EVER ORDER ANYTHING FROM HIM, PLUS IT TOOK 2 MONTHS GET, WORD TO THE WISE IF ANY OF YOU PLAN ON RACING AT HOBBY CHAMBER IN CT. YOU MIGHT WANNA GET PARTS AND FOAMS TIRES BEFORE YOU GET THERE
Old 01-16-2005, 03:31 PM   #6522
s2
s2's Avatar
Default blank lwt susp setup sheet?
is there one, i cannot find one on the tamiya site, am i just being blind? or is there not one?
stew
s2 is offline   Reply With Quote
Old 01-16-2005, 04:08 PM   #6523
TRF415boy's Avatar
Ed's got one on his website.
Old 01-16-2005, 04:14 PM   #6524
s2
s2's Avatar
ahh, so there is, that was the first place i looked, but totally missed it
thanks
Old 01-16-2005, 04:19 PM   #6525
SchuMi2's Avatar
Trader Rating: 34 (100%+)
Could someone post a link to the LW set up sheet please.....
SchuMi2 is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
