Old 01-15-2005, 07:35 PM   #6496
linger's Avatar
Originally posted by Randy Caster
I've been meaning to make an order with them for a while now, do you know if their blue would be close to Tamiya Blue?
Hey Randy,
The Faster-Express screws have a matte finish. Tamiya is also coming out with their new blue aluminum screws and they are much shinier!
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 01-15-2005, 07:52 PM   #6497
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by linger
Hey Randy,
Most of the MS parts have a matte finish, I want to use aluminum screws on my TCS car, just make it as light as I can since its only 19 turn Im not really concerned much with strength.
Old 01-15-2005, 10:19 PM   #6498
raffaelli's Avatar
Has anyone dropped the sotck one way outdrives and the lightweight outdrives to see what the difference is? I think I can feel a difference by hand but I am not sure.
24ITA
raffaelli is offline   Reply With Quote
Old 01-15-2005, 11:02 PM   #6499
raffaelli's Avatar
What can be used as the servo saver instead of the Tamyia saver that comes with the kit?
Mine is just a couple of weeks old and it is starting to fail.
24ITA
Old 01-16-2005, 12:05 AM   #6500
JimmyMac's Avatar
Black Kimbrough Medium Saver. I think it's part number 201.
Anyways, ran the 415 on carpet again. Got even quicker. Ran 6 degree caster blocks. I even went down one rate on my springs with AE Purple/f and AE Red/r. I might go back to Yellow/f and Copper/r. Seems my chassis was rubbing on the carpet when deep into the corners. I don't recall them when I ran with the Yellow/Copper setup. I'll see next weekend I guess.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 01-16-2005, 06:42 AM   #6501
I am after those 6degree blocks. Do you know what part number they are? I think they are the stock tao4 ones....
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 01-16-2005, 09:17 AM   #6502
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
Originally posted by Dragonfire
DON'T DRILL THE SCREWS!!!!!
With counter sunck screws in the lower deck, the drill will remove all external parts from the bulkhead... leaving you a bulkhead fit for the bin.
Use a dremel and a cut of tool. I have done it befor, and even slotted my deck alittle, but I can handle a slot in my deck better than the cost of a new bulkhead.
All screws are drilled out. Yay!!!!! ......
the drill didnt touch the bulkhead at all, the just drill out anti clock wise..
ermm... anyone selling lower deck?hehehehe
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Old 01-16-2005, 09:41 AM   #6503
razzo's Avatar
Send a message via Yahoo to razzo
TAM 50870 TA04 front hub carrier
razzo is offline   Reply With Quote
Old 01-16-2005, 10:42 AM   #6504
kylehirano's Avatar
Trader Rating: 14 (100%+)
I am looking to buy a tamiya 415 for carpet racing with foams tires. does anyone know what modifications that are required for this, and where can I get a front diff?
kylehirano is offline   Reply With Quote
Old 01-16-2005, 10:46 AM   #6505
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Foams will fit the 415. If you have reversible suspension the car will be to wide.
Scroll up and look at forty6's signature for all the parts needed for a front diff.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 01-16-2005, 11:46 AM   #6506
kylehirano's Avatar
Hey Jack do you know if these parts are Tamiya hop-ups, or aftermarket?
Old 01-16-2005, 12:03 PM   #6507
Trader Rating: 74 (100%+)
Default carpet 415
Well, I have done a little more experimenting on carpet. I did the Reinhardt servo mod, along with lowering the rack... this is what I had tried.:
70 wt 2 hole pistons frt and rear.
a bridge- C block
arms shimmed rear with 1mm spacer behind arm.
1.5mm pro-dive
no sways
shocks one hole in from outer on 415 tower
one way, layshaft oneway
purple frt associated springs
droop at 6 on hudy
1mm spacer behind hex
Rear:
a block frt and rear
1 mm raised blocks
no sways
outer hole on 415 tower
yellow associated spring
droop at 6 on hudy
1mm spacer behind hex\
alloy rear hubs ball in center, spaced 1 mm up
cyan/magneta tires.
Parma Alfa
102/29 Genesis Binary 2 ROAR stock.
Car as progressively getting faster as the night went on. It will only get better.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 01-16-2005, 12:14 PM   #6508
TRF415boy's Avatar
Default Re: carpet 415
Marc lowered the steering but used 4mm of spacers between the carbon plate and the ball nut where the steering turnbuckles goes.
TRF415boy is offline   Reply With Quote
Old 01-16-2005, 12:19 PM   #6509
Default lowered rack
This is what I had done also...
Old 01-16-2005, 12:32 PM   #6510
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I actually used to work in the electroncs dept at Sears, and when it was dead I'd just come on here. 10k of those posts were done by march of last year, I've only done the other 1400 since then.
And I thought I had a good amount of post but Randy is the man at the top I would suspect. I have a mear 5K.
ST Racing Concepts (STRC)
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
