Old 01-13-2005, 09:20 PM   #6466
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by forty6
That was what I meant. I saw that you've got a crapload of those already.
It never hurts to have spares in stock, especially when they are tuning options.
Old 01-13-2005, 09:21 PM   #6467
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by Randy Caster
haha, you got it, they are the only ones with this stuff in stock. I've had really good luck with them too, great customer service I gotta say.
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 01-13-2005, 09:28 PM   #6468
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
Default Re: re.help
Originally posted by C_O_jones
For rounded out allen hex screws;
With a Dremel And a worn down cutoff wheel,cut a slot in the head, then you can use a striaght head screw driver
Be carefull not to cut into the cassis
thanks guysss.
its 2 days before race day. should i do it before or after?
how long does it takes?
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Old 01-13-2005, 09:40 PM   #6469
stonedgti's Avatar
Trader Rating: 15 (100%+)
Great Ti screws on ebay.
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MESE:IT
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 01-13-2005, 09:42 PM   #6470
Default Re: Re: re.help
Originally posted by KREATOR1
thanks guysss.
It's just a 5 min job for all 4, just slot the head and unscrew it.
Old 01-14-2005, 04:10 AM   #6471
TRF415boy's Avatar
Default Re: Re: Re: re.help
Or if you have a good 3mm drill, as had been said before drill the head of the screw until it falls down and then remove the rest of the screw with a pair of pliers. This is a much nicer way of getting rid of screws, because making a slot in the screws will almost for sure end up with a slot in your chassis aswell .
TRF415boy is offline   Reply With Quote
Old 01-14-2005, 04:24 AM   #6472
KREATOR1's Avatar
will the 3mm drill will effect the bulkhead threads? i dont want to loose a bulkhead just because of 2 screws.
Old 01-14-2005, 04:40 AM   #6473
Send a message via ICQ to Cobra81li200
No because the screw is 3mm, so the head will fall before you even arrived at the thread. If you're scared about that, you can try to drill a bit and then pull the bulkhead a bit (or any way you can find to put strain on the screw), as you'd have drilled the screw's head, its strength should collapse and the head will fall.
Cobra81li200 is offline   Reply With Quote
Old 01-14-2005, 04:42 AM   #6474
TryHard's Avatar
Nope shouldn't do if your careful, the screw head shold fall off a few mm before the drill hits the bulkhead (chassis thickness).
Personally I use a Tungsten Carbide bit to get mine out, it was bloody expensive to get hold of, but worked very well in getting the stripped screws out.
Ed
| THard.co.uk | Xray | MuchMore |
Old 01-14-2005, 08:31 AM   #6475
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
I think Im covered
The first set is goin to the machine shop tomorrow to get lowered 1mm, the second set is standard, and the 3'rd set is Evo IV 1mm higher
Randy...your starting to scare the hell out of me!
madjack is offline   Reply With Quote
Old 01-14-2005, 08:44 AM   #6476
DON'T DRILL THE SCREWS!!!!!
With counter sunck screws in the lower deck, the drill will remove all external parts from the bulkhead... leaving you a bulkhead fit for the bin.
Use a dremel and a cut of tool. I have done it befor, and even slotted my deck alittle, but I can handle a slot in my deck better than the cost of a new bulkhead.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 01-14-2005, 09:31 AM   #6477
TRF415boy's Avatar
You obviously didn't understand the whole point of drilling the head of the screw, otherwise you wouldn't say that.
THINK before saying what you are sayingo, if you drill a 3mm screw's head with a 3mm drill, what happens when your drill arrives at the end of the head (and start of the threading) ?
The head will fall long before your drill had any chance of going into the bulkhead, and you won't end up with a slot in your chassis.
Old 01-14-2005, 10:20 AM   #6478
rraden's Avatar
Trader Rating: 235 (100%+)
Default DON'T DRILL THE SCREWS!!!!!
Make this easy on yourself. Go to you local Sears or hardware store and buy an "easy out" bit. They cost about $3 and don't damage any part of the car. You just put them in a drill and run it in reverse. They dig into the screw and pull it out safely. A good tool to have in your box with these types of cars.
rraden is offline   Reply With Quote
Old 01-14-2005, 10:46 AM   #6479
Peter Busch's Avatar
R/C Tech Charter Subscriber
Default Re: DON'T DRILL THE SCREWS!!!!!
Bob Villa to the rescue.
Peter Busch is offline   Reply With Quote
Old 01-14-2005, 11:32 AM   #6480
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
This is completely off yopic but I just had to bring this up.
Randy Caster is the Ultimate RCTECH guy. Over 11,393 posts since March 2003? Guys here on the east coast are amazed. Based on my calculation you averaged about 495 posts per month, 16 posts per day. That's a lot of typing.
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
