Old 01-10-2005, 11:15 PM   #6391
on the upper shock mounts what are the other shock parts needed to put the shock on to the shock tower??
ARC/HobbyWing/ Protoform/ Team Integy/ R1 Wurks/ACTIVRC
HEWITT is offline   Reply With Quote
Old 01-10-2005, 11:22 PM   #6392
Randy Caster's Avatar
Trader Rating: 46 (100%+)
A screw, 2mm spacer and 5mm ball nut.
Old 01-10-2005, 11:24 PM   #6393
do you know what part numbers those are?
Old 01-11-2005, 03:57 AM   #6394
PMR
Besercoe: Thanks for the very helpful tip. I will definetly do it now.
PMR is offline   Reply With Quote
Old 01-11-2005, 06:10 AM   #6395
TryHard's Avatar
Originally posted by Besercoe
on the steering rack i played with different spacers until it was slop free but did not bind, use the std tamiya spacers, as well as motor shims. on the steering posts add some axle shims to take up the extra play.
you wont get it all out, but i doubt anyone on these boards will notice the difference.
With the axle shims, you should only need 3 of the 0.1mm thick ones per post to take out most of the play. I still have the play in the rack, but i'f left that as is. most of my play is in the ball cups.
Regards
Ed
| THard.co.uk | Xray | MuchMore |
Old 01-11-2005, 07:24 AM   #6396
Trader Rating: 74 (100%+)
Default Re: Re: towers
Originally posted by Randy Caster
Hey Raul, any way you could take a pic of those towers stacked on eachother with the mounting holes for the bulkheads aligned, so we can actually see if theres a difference in shock height between the 2.
Randy,, I don not have the MS towers in hand, but I will soon.... Just hold on. In the pic's of Reinhardts car, and the photos of the parts, the towers looks lower frt and rear, but others are saying controversial statements. So TryHard may be able to shoot some shots?? Thanks.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 01-11-2005, 07:41 AM   #6397
Yes I am curious to see the difference. A stack photo would be great....
Anyone know if the is another option other than 4degree castor on the standard suspension (c-hub)
Whats the part number for the trf415 2.5mm lower deck? Is there a thinner upper deck too?
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 01-11-2005, 10:13 AM   #6398
TryHard's Avatar
happy to oblige....
First up, Front Tower, ill post this then do the rears.
Std on top of MS
Next, MS on top of Std
Close up detail, Std on top of MS
Finally, MS on top of Std
Looking at these it is obvious to see the MS has the holes about 1mm wider, with the holes also possibley being slighty (no more than 0.5mm) lower.
I reckonit looks lower on the car because the shape of the MS is subtley different to the Std one.
I'll post the rear ones in a few minutes.
Ed
Old 01-11-2005, 10:15 AM   #6399
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
top notch TryHard. A very informative post.
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 01-11-2005, 10:30 AM   #6400
TryHard's Avatar
Next up rear towers.
Firstly, Std on top of MS,
Next, MS on top of Std,
Looking at these, it is obvious to see that the holes on the rear MS tower are much lower than the Std twoer, by 1mm if not more (maybe 1.5 or 2). Width wise they appear to be in the same position. It's also easy to see the lower body mount position on the MS tower to.
Anywya, hope this cleasr up some confusion.
Regards
Ed
Old 01-11-2005, 11:03 AM   #6401
The blue ball nut is 53640, just use any 2mm thick shim, and a 10mm screw should work.
Old 01-11-2005, 11:06 AM   #6402
Thank you for the pics TH, no more guessing. I will propably pick up a set of the standard shock towers just to use as a very fine tuning aid.
Old 01-11-2005, 11:07 AM   #6403
What are the part numbers of for the MS shock towers. Just went on the Tamiya website and had a hard time finding them? Thanks.
Old 01-11-2005, 11:16 AM   #6404
51190 Front
51191 Rear
Old 01-11-2005, 11:21 AM   #6405
TRF415boy's Avatar
Hi all,
Been racing my TRF 415 for the first time this week end, and I gotta say I'm impressed, it's a much better car than my 414M/SSG was, and I was quite quick with it.
So far, I've been racing carpet/rubber (controlled tires/rims/inserts), using Marc's LRP TCM winning setup (apart from minor details like the outer shock tower hole and 2 toe in blocks instead of the 1 alloy ones). If you're racing on carpet with rubber, I suggest you try that setup, all I did all week end was put the car on the track and race, I haven't changed a single thing on the car, that's about how dialed it was .
This week end, will race on a totally different surface, so I'm making a spool (pinning my one way) and I'll probably start playing with setups.
One thing I noticed, the alloy turnbuckles are one of the weak points, and also the ball studs on the rear hubs .I replaced the turnbuckles with Ti ones off my 414M, and the ball stud by a ball nut/Ti screw like it has always been on the 414M.
TRF415boy is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
