Old 01-10-2005, 10:59 AM   #6376
Send a message via AIM to croy
Originally posted by Dragonfire
Hi guys...
Wat is the difference between shock towers on the standard 415 and the MS?
can someone post a pic of them side by side? (front vs frontMS, rear vs rearMS)
Part No. 50985 is a 4degree c-hub for the standard suspension. I belive there was another outhere. I'm sure I had a 6degree when I had my 04R. Anyone know wat the castor was and the part number?
Thanx....
The front shock tower is the same except for material removed that the LW suspension doesn't use. The rear shock tower is lower. I had to move my rear body mounts up one hole when I went to the MS.
croy is offline   Reply With Quote
Old 01-10-2005, 02:52 PM   #6377
Trader Rating: 74 (100%+)
Default towers
415 tower
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 01-10-2005, 02:52 PM   #6378
Default towers
ms tower
Old 01-10-2005, 02:59 PM   #6379
Raul,
What's up dude? You gonna go to January Jam at Madness this weekend?
Jamie Corrado is offline   Reply With Quote
Old 01-10-2005, 03:08 PM   #6380
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Goon, looks like you answered your own question. Jamie you going?
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 01-10-2005, 03:10 PM   #6381
Carl,
I will be there? You?
Old 01-10-2005, 03:12 PM   #6382
Jamie, Call my cell 201-788-5525.
Old 01-10-2005, 03:17 PM   #6383
TryHard's Avatar
The front tower also has the holes slightly wider. I place my MS one over my std one this evening to check the differences between them. I agree with the rear tower, I can run an extra mm of droop with my std shock length now (something I couldn't do with the std tower).
Regards
Ed
| THard.co.uk | Xray | MuchMore |
Old 01-10-2005, 06:43 PM   #6384
So the holes are wider on the front MS tower... but are the same on the rear MS tower (abit lower tho)????
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 01-10-2005, 08:14 PM   #6385
Default Jan Jams
Originally posted by Jamie Corrado
Raul,
Sorry Jaime, cant make the Jam's. My finacial situation sucks right now. Hopefully that will soon change. I will be at HC on thursday. See you , if not good luck if you go..
Old 01-10-2005, 08:18 PM   #6386
Raul,
I will see you at the Chamber Thursday night. New layout, very open and flowwing.
Old 01-10-2005, 08:29 PM   #6387
Default hc
Definetely!..Fast, see you then. I will be there early. Mad some major changes to the car-no its wasnt to a Xray.
Old 01-10-2005, 08:46 PM   #6388
PMR
Lightbulb
Just finished assemblying the Ms kit but I notice there is a big steering slop. Here are the causes I noticed:
STEERING ARMS & CARBON LINKAGE PLATE
According to the manual you have the option to use the BE1 spacer (3x1mm) in place of BE2 (3x0.7mm). With the BE1 you get alot of up/down movement but with a BE2 it was minimized but theres still a signifcant amount of movement.
STEERING ARMS & POST
With 3 pcs of BD6 (5x2mm) spacers there is still a considerable up and down movement.
Combine this two I get twice the amount of slop in my car. I went over the manual 3 more times just to double check my assemble but the problem still presist. I have built a fair number of kits from serpent/yokes/hpi/AE but this would be my first for any Tamiya kit so my question is:
Did you experienced this sort of problem?
Is this normal for the Ms kit?
Did you guys use spacers to set it right?
PMR is offline   Reply With Quote
Old 01-10-2005, 10:12 PM   #6389
on the steering rack i played with different spacers until it was slop free but did not bind, use the std tamiya spacers, as well as motor shims. on the steering posts add some axle shims to take up the extra play.
you wont get it all out, but i doubt anyone on these boards will notice the difference.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 01-10-2005, 10:36 PM   #6390
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Default Re: towers
Originally posted by Raul Garcia
415 tower
Hey Raul, any way you could take a pic of those towers stacked on eachother with the mounting holes for the bulkheads aligned, so we can actually see if theres a difference in shock height between the 2.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
